Craftsman Tool Chest Restoration Advice
clcrabtr
Hey there!
I have a 2000 Craftsman Tool Chest that I got on Marketplace, and this seems to be the place to go for help with that. Pictures are included in a link below because that seemed less onerous visually. I've got the drawer sliders off and soaking and will probably just about leave the drawers alone - they're banged up and not sure it's worth wet-sanding or re-painting them (unless you suggest I do). I had several questions though:
  1. I'm going to sand down the rough spots on the chest to level and repaint. Painting/finishing has always been the bane of my existence (I'm a woodworker), so I wondered what paint/primer I might use to avoid/minimize imperfections. I've seen Rustoleum Hammered and bed liner paints recommended, but the colors are pretty limited. I was going to go with a dark green for the repaint - any suggestions? And do I need to prime the whole chest or just the parts I sand down to metal?
  2. It did not come with keys, and I can't quite make out the code. It's either 3, 5, or 8-111. If I order new keys will they simply fit? Will I need a locksmith to cut them?
  3. The casters are beat to hell. Any recommendations on good replacements?
I've read through a lot of the old posts of similar projects, but the advice seemed to be tough to really follow so would really appreciate some specific help. Thanks!
I would go to Easy keys, and see which number might be valid. If all are, contact them, see what they say. Or look at the pix, see if the long way ridges look right.
95% success rate buying from them, one fail was something like laser cut vs normal cut, per their phone support. Sent me out new ones cut the other way, worked fine
BTL-A4
Santa Clarita
Hey there!
I've done this to another tool chest. You want to sand the whole chest where you are painting it, not just some areas. 220 grit will be sufficient. You want to break the smooth surface and give the paint something to stick to. Primer the whole thing, then final paint. The primer will show any imperfections so you can fix them (Bondo or the glazing and spot putty works well) and re-primer them. With painting, prep is everything.
I used rattle-can paint, so the dents and dings were still visible, but I think the textured paints you mention will work fine to cover any imperfections. It takes practice to get them to go on evenly. If you really want to get fancy, use auto paint. You'll need a compressor and a paint gun (I used a HF cheapo gun to paint a car and it worked fine.). You'll also need PPE and some sort of enclosed area or a space outside away from dirt and wind. Look into it (go down the rabbit hole!) and see if it's an option for you.
Be mindful of the "oil can" effect if you pound out dings; the metal stretches and looks warped.
I go to a local locksmith and have keys made. Costs about $15 per lock and I get 2 keys. Take the locks with you.
Could you get Craftsman replacement casters? HF might have something that will work as well. Casters can get really expensive. How much are you going to move the tool chest around? On what type of surface(s)? Do you need them to lock? Do you want all 4 to swivel? That can dictate what you get.
Looking forward to seeing your progress!
C
clcrabtr
Thank you both, I’ll send some more pictures when I get the next steps done. I think I’ll go rattle can as well - I dont have an air compressor so I think doing otherwise would be more overhead than I need for how rarely I paint.
That’s good to know about the hammered paint, I think I may prefer visible dings over a bad finish, so I’ll probably just use a regular spray. The drawers are going to be visibly bent and dinged no matter what I do, so those kind of are what they are, I guess.
Hoping to get everything sanded during the week and maybe can start painting next weekend.
driftpin
I've bought casters online, I forget the exact name, something like casters only. I spent time to search for the exact size and weight-bearing capacity I needed, and I was happy w/the quality of the casters. They had a lot of options.
C
clcrabtr
Well, I went for painting today and it turned out…a splotchy, primer-showing mess. assume it’ll look marginally better when fully cured but really disappointed with how it turned out after a ton of prep work. Planning to knock down the too-heavy bits when it’s cured. My try a can of hammered black, but don't really want to waste any more money on this project. Really don’t know why I thought paint was going to go better for me this time, such a disappointment.
AEAdam
SE PA
I know you thought you did a lot of prep work, but all of us can see you didn't. That surface needs to look like glass before you paint color. If you want to get this right, leave it out in the sun and make sure it's 100% cured, then block sand with 400 grit. You'll find a ton of low spots. Bondo those, then block sand 80, then 120, then 220, then prime then block sand 400 again. Keep doing that.
Bondo
Then primer and spot putty. I sanded this all down with to 1200 grit sponges.
Then when you rattle can it, you get this:
Like you, I saw areas here where this wasn't good enough. But I just fixed those spots, didn't redo everything
Finished product:
Here's the point: YOU CAN DO IT. Just spend a little more time on the prep. Getting stuff flat isn't easy. It takes a lot of sanding. And use a block to help flatten your work. And then finer and finer grits make the substrate smoother but also flatter.
^ Always. When we sold spray paint, we made it a point to always tell the customer to put the can of spray paint in the sink and fill the sink with hot water, or set the can out in the sun. Cold spray paint just doesn't work.
C
clcrabtr
Another day at the cursed tool chest. Used a razorblade to knock down the heaviest runs, then sanded the worst bits of orange peel, etc back 280, 3?0, 400. Don‘t have access to a sander, so waiting on a sanding block to get here so I can do another pass through and level out all of these scratches, hopefully. Top is just going to be what it’s going to be, it’s getting liner. Drawers mostly came out well. Sides and front are the last meaningful hurdles. Will do 2(?) more coats of spray on everything but the bottom and then off to Craigslist barring a miracle.
C
clcrabtr
CL to sell, what are you going to list it at?
No idea until I know how it’ll turn out with hopefully better paint, and what others look like around here. Hopefully enough to make back the materials and original price. It’ll at least be cleaned up and freshly lubed with keys. Even if it turns out I’ll only ever see the paint flaws - that’s how some of them go though.
@clcrabtr -
Do us a favor:
HERE is a "How much is this box worth?" thread.
Rules here are: NO selling in the forums. Use the classifieds.
Now that's out of the way:
Once you get the thing SOLD, post a couple pics in that thread and let us know what you got for it.
A few of us were trying to get some rough idea of "market value", but prices are all over the map because of variables (is it Snap-on, Craftsman, or U.S. General? Does it come with any tools, or is it empty? Is it cherry, or all beat to hell and rusted?)
Currently I'm trying to unload four "top boxes" and about half a dozen little "carry boxes" myself (although the "carry box" is a no brainer: they're all $20 bucks a pop.)
Thanks.
BK
C
clcrabtr
@clcrabtr -
Do us a favor:
Thanks.
BK
Ah sure, not a problem, will do.
C
clcrabtr
Alright, saga continues. I sanded it back down to 150 and then back up to 400. Got it as smooth as I could with what I have available. I just put a light layer of primer back over the whole thing. Do I sand back the primer? If so with what? 400 and/or 600? I almost didn’t réprimé because I felt like too heavy primer is what messed up the texture last time.
^ I believe you want to allow the primer to fully dry, then wet sand it again with 400.
Did you see the link to the Amazon special on the pressure washer?
Karcher electric pressure washer $105 shipped from Amazon this week
https://www.amazon.com/Karcher-K170...ruPressure/dp/B01N20PROC?tag=atomicindus08-20
C
clcrabtr
I didn't, but it's not really an option. I live in a small apartment so this whole process has been moving the chest in and out of my little storage area every day I work on it.
