Frank Mossberg Pressed Steel Socket Sets
chasinfram
Framingham, Mass
A spark plug socket, 1-5/32, with a closed top. Totally unmarked. Came with a mixed set of Mossberg, RAY and no name pressed steel sockets. Doesn’t quite fit the Mossberg ratchet, but you can adapt with an additional socket.
Any ideas of the origin of such a socket?
Also with the set was this socket spinner, 1/2” drive opening.
LesserSon
PA USA
I have a bunch of those sockets and have not figured who made them or when. They don’t seem as old as the open-at-both-ends type.
  • C.M.B. Wrench Co. Silver King SAE socket wrench set (patent 952435)(ebay 203770566950 01).jpg
After a quick search on the internet, Alloy Artifacts.org identified this as a flex extension made by C.M.B wrench company
A little further dig and I think that is a socket set from cmb
You nailed it, @Ayrhead!
I’m wondering if the sockets are Mossberg or perhaps a different manufacturer
Hard to tell from the angle, but chances are C.M.B., given the overall context, and you can just make out the telltale large raised (forged-in) fraction marking on a couple of them, which is a convention Miller liked to use in all the corporate iterations of his productivity, including my Syracuse and Charles Miller sets.
chasinfram
Framingham, Mass
Hello Dr. Lugnutz,
Is it ok for me to post a marketplace ad on the forum? It’s not mine, it the CMB ad that the guy won’t reply to me. Maybe someone in PA would buy this for themselves. It’s a good price.
I refrain, because I generally like to separate technical and historical discussion from buying and selling (and appreciate Ryan separating Classifieds from the discussion forums a long time ago), but I have seen other members post links for sales on ebay, FBMP, and other sites. I don't know if it's considered "okay" or not, though, and I am not a moderator.
chasinfram
Framingham, Mass
Thanks bro Tooler.
Cruzan80
Denver, CO
@chasinfram , you can always grab the pictures from the link (if there are others) and the title to post here. It would help others doing future research with more pictures, and if someone who is local wants to try and search for it, they can choose to do so.
chasinfram
Framingham, Mass
Hi all!
I obtained what I consider an anomaly (for me) in a random set of mismatched vintage sockets. It s this round pressed steel socket branded Mossberg. It doesn’t seem heavy enough to be from their beefier set. Somebody please educate me!
I’m showing it together with the same size from my #10 set.
MR.X
Nice little box. Kind of a mix of sockets.
Steven 33
Mossberg 331 T handle. For some reason I can't seem to find any others
I don't recall seeing another example. Only in catalogs. It was considered and marketed as an accessory, like the offset (or "L") handle and the speeder. There were a couple special sets that came with the offset and the speeder, but I've only ever seen the No. 331 in a large merchandising cabinet. Again, in catalogs.
Steven 33
I did a little digging and apparently it's In a newer no 14 set I believe. As well as the 422 that I have and a few other oddballs. I've been trying to identify these wrenches on the left. I'm told the numbered ones on the right are from a 1914 set
I see it now. In a No. 14 that came in the same style metal attache case that the No. 82 came in. The cool thing about that is the No. 82 was the Professional line stuff, when they moved to hot-forged cold-broached just before merging with APCO. That would be a cool set to find. With only the case (made by Kennedy - I didn't note that before, I'll have to PM that to the Southern Tool King I moved mine on to...) being in common. Talk about a transition period overlap, check out this ad from 1928, where they are still selling the old No. 14 pressed steel tools right alongside the newer compositions/constructions.
Steven 33
When I was doing some digging i also found this set. The T is definitely in the wrong place but I was thinking it's possible it did go with the set. Especially considering it's only 1 of 2 of the 331 T handles I found on worthpoint
Not sure how it can be "definitely in the wrong place" and "possible it did go with the set" at the same time... :headscrat :)... but I'm going with the former. I've never seen it advertised in a wood box No. 14 - or any other wood box set.
Steven 33
It actually looks like it fits okay there, but what I meant was that I would assume if it went with that case that it wouldn't be in the tray thing
