I combined the parts I liked best between a Speedi-Bleed and Motive pressure brake bleeders.
I really like the Speedi-bleed adapter caps and the small couplers it uses, but don’t like the small one-quart fluid bottle which you have to stop and refill at least once when flushing the brake fluid almost any car and 3 or 4 times when flushing my Motorhome.
I do like the two-quart tank on the Motive, and they also have a gallon tank if needed. I do not like their plastic adapter caps and the 1/4” NPT threaded connection to change pressure cap adapters. They do have some metal cap adapters and I bought a metal screw on cap adapter for my ’53 Willy’s Jeep and a metal cap for my Jeep Grand Cherokee. I also do not like the short hose on both.
I ordered a hose and coupler from Speedi-bleed and a 3/16 to 5/16 ID barb adapter to connect the two hoses for extra reach along with cap adapters for my motorhome and my wife’s Honda. I also had an assortment of stainless single ear hose clamps from HF and Knipex ear crimp pliers from a dishwasher repair I did in the past.
I also found that HPCouplers sells every variation of the Foster 2 Series couplers that Speedi-Bleed uses and bought multiple plugs with 1/8” and ¼” NTP and barbed adapters.
The cap adapter for my Willy’s Jeep was easy because the ¼” plug screwed right into it. I used Locktite 545 on the threads.
The cap for my Jeep required some machining to screw the 1/8” NPT plug into it
I used the barbed fittings to make hoses for topping off the master cylinder. when I flushed the brakes on my motorhome I used my motive to top off the master cylinder without a valve and had to quickly unscrew the tank lid to stop the flow, so I wanted a valve on the system.
I started with a small ball valve but found it cumbersome then found that Laboratory Pinch Valve Flow Control Hose Clamps work great for this application.
