Vise Info Thread
jreb10
Westby, WI
I spotted this Hollands 23 in an online auction too far away for me to think about acquiring it. But I did notice that its Vise Info Spreadsheet entry links to photos that show an example without the swivel base. So here are two photos of a Hollands 23 with its swivel base.
CRSINMICH
Southeastern Michigan
Outlaw: I was a bit puzzled that you didn't think of Bonney Vise and Tool as vise makers. I was so focused on the vise part of their operation that I completely forgot that in 1921 there was a name change and a manufacturing change. Thanks for the second hand reminder.
Just always been seeing their wrenches and such and never really paid much attention to their ads and full company name.
Also, why would they duplicate that iconic Parker jaw mount?
micahd1997
This catalog is long after the company’s “rapid transit” days, but still…
CRSINMICH
I have found no information about that except that Bonney's Rapid Transit ads don't clearly show Parker style jaws until 1891 - well after Parker started. Also that seems to be the only Bonney vise that did. Does anyone else know anything about that?
KMScott
Thanks Sky. If you close the vise and take a measurement of the square slide‘s length then I’ll have the max opening to record. Here is a 5” Rock Island jaw drawing to see if it is the same as your jaws. Thanks for the great pics and your lucky to own this vise.
KMScott
Columbian 605-M2. 5” jaws that opens to 8” and weights 70 lbs.
Just finished restoring this one for a vise collector on the island. New jaws, handle’s and Bronze wear washer.
SkyPuncher
KMScott, the measurement for the Samson of the exposed slide when jaws are shut is 8 inches. The measurements of the jaws you provided are almost spot on if not for some wear and tear.
twagler
Ottawa, Canada
Mystery Vise (unknown manufacturer). 3-3/4” jaws that opens to 8-1/4"” and weights 73 lbs. Swivel base, with center below the bench swivel release. Plain iron jaws, no replaceable steel jaws, no cast-in-place steel jaws.
I have this posted over on the big vise thread where I had asked for help identifying it prior to purchasing. I ended up buying it, but the manufacturer and model number is still a complete mystery since there are no markings on the vise body. I'll post a few additional pics here, now that I've cleaned it up a bit, hoping that there might be some key identifying features that someone recognizes.
As-found condition: (very rusty, badly pitted on the right side, must have been left lying in the mud for many years to get this bad. Sold at auction from a homestead property in very rural countryside near Ottawa Ontario Canada.
Condition after cleaning and electrolysis: The jaw towers have a bit of a bevel cut to them. Screw retained by a front collar plate. Both of these features remind me of Parker, but it isn't a Parker since all of their vises were very well marked.
Markings: The only markings whatsoever are found on the main nut (made of bronze, same as the collar) and on the base plate for the swivel mount. Dual-marked as 4 and 4-1/2, so I'm assuming that these items were shared by the Model 4 vise and the Model 4-1/2 vise made by this manufacturer (whoever it was). The base plate is of the less common type for below the bench swivel vises, in that its hold down bolts are exposed on the periphery rather than being hidden under the vise body which was a much more common style.
Plain iron jaws: This is the first vise I've ever owned that doesn't have additional hardened steel replaceable jaws or hardened steel cast-in-place jaw inserts. Not sure if that is the sign of an older vise, or just a cheaply made vise. It definitely rules out Parker as a manufacturer since even in their oldest catalogs, their vises all had steel jaws. On the other hand, the plain iron jaws seem to have held up reasonably well in service. I think this vise might be what manufacturers used to advertise as "semi-steel". This vise is extremely heavy for its size (73 lbs for only a 3-3/4" jaw), and I think steel is denser than cast iron. The casting quality of this vise is also extremely poor, with some bad voids and lumpy surfaces on all pieces, which apparently is another characteristic of semi-steel compared to cast iron. in that it poured poorly and often didn't fill the mould perfectly.
Square, plain styling: I've ruled out many possible manufacturers because the styling of the stationary on this vise is very squared off with nary a flying buttress (Parker) or front edge rounded protrusion (Reed) to be seen.
Odd main nut design: Rather than the typical dovetail shape for holding the main nut in place, this bronze main nut is square bottomed, except for two short square wings at the rear only that fit into matching square undercuts. This was a bad design, since the two wings broke off of the main nut, and now the nut is very loose. (I'll have to figure out a way to fix it if I want to make this vise a user). Another odd feature is an internal tower that sits in front of the nut to take the force when clamping tightly.
Thanks for looking. Hoping that someone might recognize a manufacturer for this vise, although I'm guessing it might just have been an unmarked vise made by a local foundry back-in-the-day.
Thanks, Tom
F
FMC1959
Montreal, Canada / Upstate NY
Thanks, Tom
The pitting on it is incredible, it looks like it spent years at the bottom of the sea. If it was mine, I would keep it as a user, just to respect all that it has been through. Nice find.
gearhead1960
I just finished rehabbing my Craftsman 5242.
This will provide another reference pic for the spreadsheet.
Jaws: 3 1/2 niches wide
Capacity: 2 inches before the slide is no longer completely outside the vise body
Weight: 20 pounds
@Shiftless Just recently acquired one of these, seen here, and would like to restore like yours. What paint did you use to repaint and how much did you do in prep? Interested in your procedure...TIA
KMScott
Charles Parker 378 Swivel Jaw. 4-1/4” jaws that opens to 5-1/2” and weights 42 lbs.
