What's on the other end?It's from a 1998 Frigidaire washing machine, "FHP Motors" on the tag.
Regular wrenches nowadays are usually proportioned for hex head fasteners, so the jaws would be too short for that fastener.What's on the other end?
I'd think an impact would zip a nut off no problem, and if it spins a small open end wrench ought to hold that tab...
Regular square fasteners will not seat in many open end wrenches nowadays, because the open ends are proportioned for hex fasteners.More made up facts from you?
It's a bolt on a washer motor, not like some high torque application. I'd bet a 10mm or similar wrench will hold that just fine while he zips the nut off
Probably “FRP Motors”.It's from a 1998 Frigidaire washing machine, "FHP Motors" on the tag.
Fractional horse power?Probably “FRP Motors”.
“Factory Replacement Parts”, I believe.
The rest of that thread may be beneficial to the OP too:
That was the correct tool.
That was a good work around.
Hemostats?Pretty sure he used vice grip too
Hemostats?
I'm firmly anti-plierwrench and I agree.Finally an actual application for a plierwrench.
Why, they work better than any crescent wrench. Some times grip better than an open end wrench.I'm firmly anti-plierwrench and I agree.
But I see the OP already solved his problem.
