Is there a socket for this motor thru-bolt head?
PCustoms
VT
It's from a 1998 Frigidaire washing machine, "FHP Motors" on the tag.
What's on the other end?
I'd think an impact would zip a nut off no problem, and if it spins a small open end wrench ought to hold that tab...
neophyte
Pennsylvannia
Regular wrenches nowadays are usually proportioned for hex head fasteners, so the jaws would be too short for that fastener.
This is sort of the use case for vise grips, maybe with a couple shims to prevent marring of the faster, if that matters.
neophyte
Pennsylvannia
More made up facts from you?
It's a bolt on a washer motor, not like some high torque application. I'd bet a 10mm or similar wrench will hold that just fine while he zips the nut off
Regular square fasteners will not seat in many open end wrenches nowadays, because the open ends are proportioned for hex fasteners.
That fastener head is longer and narrower than a square headed fastener.
Whether the torque would be high enough to cause an issue for an open end wrench, probably depends on the wrench, and the wrench design.
That fastener head is designed for a wrench that looks like the one skinny open end from this GJ thread.
mm08822
Find a 6 point socket that just fits over the long dimension of the bolt head - metric or imperial .
Cut some finishing nails to fill the voids in the socket. Use caulk, silly putty or play dough to hold the nails in relative position while putting socket on the bolt head.
Zewnten
Are you trying to reuse it? If so I'd honestly try a spline socket, first time for everything I guess
KnurledNut
n/a
cgrutt
I'd try to make a custom socket using a sacrificial hex or double-hex socket that's close in size (large enough to fit completely over the head of the bolt) and some steel reinforced epoxy such as JB Weld or an epoxy stick such as Marine Tex. Spray head of bolt and surrounding motor housing with some PTFE dry lube or use Carnauba wax as a release agent. Pack the socket with epoxy and carefully press it onto the bolt head and wipe off any excess with acetone. Let epoxy to partially set up then carefully pull it off bolt head. Allow to fully cure before using.
bw77
Upstate NY
Something else I learned on this project.
I needed a long 5mm Allen wrench, longer than the L-key that I had.
It turns out that a T25 screwdriver works very well, fits snugly.
Google says use a T27, that's wrong, it's too big.
