Tools from the old world
M.Jay
Southern Germany
I'm in 3. right now, the "others". Most of the prices I see on idealo I can't get because most German online shops wont ship outside Germany, or will ship to 2. only. Or they will charge 30-45eur shipping to 3. that makes it prohibitive to buy 1-2 tools.
Let me know when you need something, I will gladly help a fellow GJ-Member to satisfy his passion. ;)
Nobody-named-Olli
So the Pressol oiler kept weeping small amounts of oil after putting it back after each use. It was not coming from the nozzle/ drip catcher - and always accumulated around the base. I reached out to Pressol, they made me go through the supplier for warranty and today that package was picked up, as they wanted the, likely defective, oiler back. So they should have this sometime next week. Let’s see how that goes from here. The only other explanation I can possibly think off is that the oil is too thin for this type oiler. But I really don’t know how realistic that is and no one in the process so far asked what oil I’m using with it. So I did include the spec sheet. We’ll see I guess.
Kind regards,
Olli
So I received the oiler back today. I’m not really 100% happy at this point because it was as badly, or should I say carelessly, packaged as the first time it came and the nozzle penetrated the packaging. But it seemed dry all around. There was some oil inside the oiler, either mine, or theirs from testing. At this point I do not know what parts were exchanged or if something was repaired - I inquired about that.
However, after filling, the oiler was incredibly hard to prime/ get to function normally/ correctly which is another “let down” - and only time will tell if it functions properly from here on now, or if there is going to be more “messing around” needed down the road. We will see.
I’ll keep you updated along the way.
Kind regards,
Olli
YesIHaveAHammer
Bessey Classix F-clamps 160x80mm
How much pressure can you put on with this screwdriver type twist handle?
Every time I see someone using them (outside of woodwork), they're always cranking hard on them and it looks like this is the limiting factor rather than the structural strength of the clamp. They're rated for 5-6000N.
I'm looking for something that can squeeze harder than trigger quick clamp, to pull things into position. Looking at this F type screw clamps either with this type or handle or with sliding T bar.
KnurledNut
n/a
The Bessey lever clamps are very strong. I have bent the bar on one just using the mechanism.
YesIHaveAHammer
Knipex summer update
Mostly specialist professional stuff - full list in the video description. For general interest:
The high leverage diagonal cutter (at 0:40) 74 series in size 200mm and 250mm (not on the website yet), has been updated with 20% more leverage. I expect the design will trickle down to smaller sizes. https://www.knipex.com/knipex-diagonal-cutter
Below is the old version. Notice the relative proportions of the head vs. handle length. However, leverage is a trade off, so I expect the new ones require more handle movement for the same amount of jaw opening.
The timing of my recent purchase was unfortunate, so I got the new comfort grips but old mechanical design.
New Slim Knips 78 61 (at 3:30). Available with or without holster, and the holster is available separately (compatible with 125mm Super Knips)
Nobody-named-Olli
Kind regards,
Olli
So, final update/ conclusion on this:
The oiler does not leak/ weep anymore and does function. No more oily hands when picking it up and the tissue I put underneath is dry/ oil free. That is great.
I did try to get some more information, but by now having had 3 different customer service reps from the dealer answering my e-mails, the last e-mail I got was just plain *dumb* - as if none of the prior communication and actions had ever happened. I just quit - not worth it.
From what I can piece together, the oiler I received was/is a new one, who tested it, I don’t know and will never know.
After advising me to go through the dealer, Pressol “left the chat” and did not resume communication with me on their own/ after they supposedly got the defective unit through that dealer. I have to assume they are not interested in communicating with me, that is OK.
At the end of the day I got what I initially paid for and didn’t have any additional cost - so all good.
Kind regards,
Olli
DAustin
You should not have to go through all that BS to get a good product. I don't know what's worse dealing with stupid service reps right away or going through the "dial 1 for this, dial 2 for that, and after about a half hour dial 99 to talk to a person." I'm afraid I would have told them to stick the oiler where the Sun doesn't shine and bought another brand.
Nobody-named-Olli
I absolutely agree and would have absolutely wished for the whole process to have gone a lot smoother.
Neither dealer nor manufacturer will see any future purchases from me, that is for sure.
Speaking of “dial 1 for this, (…)” Wednesday of last week, I called a (new to me) supplier because of an delivery issue and went through the automated answering process, I pressed 2 because it fit the matter best: then the computer voice told me they don’t do that over the phone - and hung up on me. That almost caused steam to escape through my ears in that very situation & due to surrounding circumstances. …
Kind regards,
Olli
DAustin
Kind regards,
Olli
I went through the number dance the other day, dial 1, dial 3, dial 2, dial 8 to talk with a person. Thank God a person, turned out to be someone from India that I couldn't understand what they were saying. I said sorry I'm hard of hearing and hung up. Went back to the number dance and after about 10 numbers I got the info I needed.
lu787a
I'm interested in either the 74 05 200 or 74 05 250.
I don't see these available in the US. Will they be? Or what would be a recommended place to grab some imported ones in the US?
YesIHaveAHammer
I'd certainly expect them to start appearing soon, unless they are already in some places. Might be hard to find given the model codes are unchanged. You might need to check the photos and ask the retailer to confirm.
KnurledNut
n/a
Looks like they made the forged axle smaller. Seems to me these won’t have to open as wide to achieve a comparable bite to the original design.
I’d like to try them, but I have never been disappointed in the performance of the 74-250. Mine have been used and abused for years and just keep going. No other brand I have tried has been as reliable as these. The cutting edges have held up to everything I have thrown at them including 1/4” steel rod. I’ve had to stomp on the handle with my foot to cut that. The pivot design is incredible and stays tight. The handle ergonomics work.
If I do get the new version, I’ll go for the plain dipped grip.
YesIHaveAHammer
They do say something about this:
In what ways is the high leverage diagonal cutter better than the previous model?
Thanks to its optimised power joint, it cuts noticeably more easily than conventional diagonal cutters. Compared to the previous model, it cuts 20% more easily.
My guess is the 20% is from a combination of slight movement of the axle, slightly smaller axle, maybe a slight change of blade bevel angle, and smaller handle span to put your hand in a stronger position (not too wide open) for applying force.
This page gives cutting capacities 4.6mm medium-hard wire, 3.5mm hard, 3.0mm piano. Product pages still say 4.2, 3.0, 2.5 - and so do the handles in photos.
Annotation lines mine. New version on right. Both pliers 250mm.
NitroExpress
Texas
Ordered this extendible Hazet 1/2” drive ratchet March 15th. After a quarter of a year it finally arrived. Well worth the wait, this is a pretty stout ratchet. It will be going in one of my trucks. The locking mechanism is very positive and extends from about 16” to about 24”. Also picked up a couple drivers to check out as my first Heyco tools.
CGarage
United States/Switzerland
Where did you find the Heyco drivers?
I have been after one of the Hazet extendable ratchets for a while and I am glad it has a good review from you. It seems more stout than the Facom equivalent.
NitroExpress
Texas
Both the Heyco and Hazet came from KC Tool. I’ve not handled the Facom, but the Hazet ratchet is very heavy built. It’s rated by Hazet for almost 740 Ft/lbs torque, so they have quite a bit of confidence in it. I found it on sale, despite it being perpetually out of stock.
The Heyco driver handles strike me as being on the small side (I’ve big hands). The blades seem typically high quality German.
