Between 705 & 1200 SQ/FT The Texas Barn in PA
madison069
Monroeville, PA
I do like the concept of the clamps and they do work, but you have to tilt it just right to grab the flare nut backside. Maybe there are some out there with a smaller grove for the line to slide through. I think it was you Marc that I saw them from and I ordered a set for this job. But so far they been good at keeping the fluid from draining out of the system while I clean up the hubs and stuff.
madison069
Monroeville, PA
That’s called a “Brake fluid flush” and pays 1.5 hours flat rate! See the positive, ignore the negative! 😆
I hear ya! If it was the camaro I wouldn't be too concern about the brake system going dry. But the 2012 has that ABS and I am doing my best to keep air from building up in that thing. I don't have a scan tool to run the ABS to bleed it. Which is another justification for a scan tool.
madison069
Monroeville, PA
Today was miserable. Those two brake hoses that goes from the hard line under the bed of the truck to the rearend almost got me.
This spot is proof that an engineer jumped over 1000’s of virgin women just to screw a mechanic.
Getting that brake flare nut that’s closest to the frame started was a pain. The nut wouldn’t spin freely due to the plastic coating was interfering with it. I tried penetrating fluid, working the nut with a wrench, spinning the nut with a deep socket and battery ratchet, and it just wouldn’t spin freely by hand.
I ended up being squeezed between the rearend, driveshaft, muffler, and gas tank to reach this ******* while laying on the floor. I was coated in Fluid film and brake fluid during this time.
Overall it took 2.5hrs to change these two brake hoses and just an hour was spent trying to get that nut started on the hose!
The other end on the axle was a breeze to do, 30mins and I had both old hoses removed and the new ones installed.
The other end toward the bed was a challenge to get those clips off the hose and I had to work the ends out with a pair of pliers due to some rust there.
Maybe tomorrow I’ll get the rear disc brakes assembly replaced with the new parts. But I called it a night after those two hoses.
gearhead1960
I feel your pain on the brake hoses. I had similar issues getting the rear brake fittings loose on Ricky. After not too much F'ing around, I remembered I was replacing the hard and soft lines and just cut off everything. Same with the lines at the rear drums, I just cut the lines and fitted a 6 point socket on the fitting....easy peazy. Sorry, you don't have it that easy.....
Xti04
Fixed it for him, now it is easy peazy!
madison069
Monroeville, PA
Too late, I already have those two in my arsenal. 🤣😂
Luckily the fitting I was fighting wasn’t rusted, but it was that plastic sheath that ford put on their lines. Looking back, I bet I could have cut that plastic sheath off a little bit and it would have fixed my issue.
I also tried to thread the brake hose on the hard line, but due to the cramp space, I couldn’t hold the hardline and turn the brake hose at the same time.
Oh well, it’s done now. I checked the fitting after pumping the pedals and I didn’t see any wetness, so I call it a success for now.
madison069
Monroeville, PA
It did cross my mind to cut it. But the line and nut was still good. It was the plastic sheath I think that was causing my issues.
madison069
Monroeville, PA
Got the rear brakes done. It went a lot faster compared to the dual line job under the bed of the truck.
These brake lines didn’t really have a good mounting bracket for them so I had to pry the old mount wires off the old hoses and reused them. I will put some zip ties on the mount wires to secure them more.
Then I bleed the brake system using a Speedi-Bleed system, it’s a nice little setup but trying to purge all of the air out I was getting some weird air bubbles. If I opened the bleeders on the calipers a lot, there would be a lot of little bitty bubbles. Then when I would close the bleeders some I would get some big bubbles and then all fluid. But if I cracked the bleeders open some more, the little bubbles would return. I started thinking that the air was coming from the bleeders threads, but not really sure.
I took the truck for a test ride and did the brake pads brake in procedure. The truck now actually rolls easily and the brakes works good. I think I will bleed the brake lines again after driving it around some just to make sure I got all of the air out. I might even use Forscan software and see if I can active the ABS bleed procedure.
Before I parked the truck in the garage I cleaned up the garage and cleaned the floor. Was the garage floor 100% stain free after the brake job, no. But it cleaned up well enough that I am happy with it.
I can probably get it cleaner with a different cleaning product then just simple green and water.
Then I started the 4WD vacuum line replacement and just as I was worried about, I ordered the wrong line. I dug into the part number I got and it was for a F150, 🤦🏻‍♂️🤷🏻‍♂️.
The new line on the left and old line on the right.
Confirming on the ford part online store I found the correct one and it will be at the house Wednesday. Till then I’ll have to lock the 4WD manually.
I cleaned up the tools and put them away and then broke down all of the boxes and put them in the bed of the truck to take to the recycling dumpster by work tomorrow.
DeeDubz
Socal
I replaced my vacuum line a few years ago. My truck would buzz for 30seconds after I turned the motor off. The only way to get the think to quit was to pump the brake pedal. If I remember correctly it's not too bad of an install.
madison069
Monroeville, PA
It wasn’t too bad To Take the old line off other than getting coated in fluid film.😒
zmotorsports
Northern Utah
Cody, I have a much, much older version of those clamps, but they are a just a squared, U-shaped piece of metal with a threaded fastener using a thumbscrew and the end that goes into the line has a rubber tip on it. Hard to explain, but I've had them for several decades and use them for brake lines as well as transmission lines and have worked very well, but not quite as convenient as the grip style you have.
Bingo Cody. The air is being pulled around the threads of the bleeder. Not a big deal because the air is not entering the actual system itself. Just more of a note to self when this is taking place.
jeffcoll
Before you vacuum bleed the brakes, take the bleed screw out and put a dab of silicon grease on the threads. It stop the air leaks, and also keeps some water out of the bleeder threads making them easier to loosen next time.
madison069
Monroeville, PA
I’ll have to remember that for the future!
madison069
Monroeville, PA
While working in the garage this morning, I started looking at my jack stands. Their old, rough, and one got bent. Before I started stripping them down to get ready for paint I decided to check into the whole harbor freight recalls. Well these particular model feel under the it’s not recalled but you can bring them in for store credit.
So I took all 6 in and got my store credit. Then I purchased 6 of the 6 ton Daytona jack stands and I only had to put 60 cents toward the gift card to complete the deal.
These new ones have a better foot print, looks to be better built, and has a safety pin as a secondary lock.
They should do good for what I do.
Then it was time to clean the garage some more. Starting with the stuff on top of this cabinet.
Eventually I was able to clear the majority of the cabinet tops along this wall.
This stuff is items I need to decide what will go on the walls. Obviously the deer heads, but the other stuff I need to figure out.
Now to keep working along the back wall.
Maybe I’ll tinker some more tonight, but I’m thinking I’ll just relax also.
larry4406
Northern Virginia
I have an orange pair that look like yours.
How did the recall/ exchange/ credit work if they were not the model listed in the recall? I am not sure mine have any stickers left on them.
madison069
Monroeville, PA
So when they did the recall, they had specific model numbers that were listed as do not use as they are highly skeptical to failure. But they also listed some models that wasn't really skeptical to failure based on report but if you want to bring them back, they will give you store credit or a refund. Mine fell under the it's not known for failure but can be brought back list and they were the 38847 model. Mine surprisingly still had the stickers on them so the model number was easy to find.
The red model numbers are the 100% stop using due to reported failure models, the black are up to you if you want to bring them in.
Here is the link to the details on them.
madison069
Monroeville, PA
I definitely like the new design of those jackstands that have a small footplate at each corner.
For concrete stains, don't know if it will work as well on brake fluid, but it works great so far for the tacky red I got on my pavers. https://www.amazon.com/dp/B0046O5YMA?tag=atomicindus08-20
Same, that little footplate seems to be a better design then just the sheet metal edge.
I'll have to try that stuff on an old oil stain that the tenant left on the concrete driveway by the house.
madison069
Monroeville, PA
So one side project of the day was getting the water hooked up to the fridge in the garage. The fridge has a water dispenser on the inside of the fridge at the top. I should have took a photo but didn’t, I’ll get this photo tomorrow. It also has an ice maker.
I started looking at the fridge water line and turns out everything was there to hook the line to the ice maker spigot that I installed when doing the plumbing of the garage. So I proceeded to hook the line to the ice maker valve and turned it on. Would you guess it, that the line started leaking under the fridge?
I found the leak on the filter housing. Seems this quick connect was busted and also hard.
So I looked into a replacement housing and they wanted $90 for that filter housing. Let’s say I decided I wasn’t spending $90 on a fridge that was free to me. So I went to Lowe’s and got a 1/4” quick connection **** deal to bypass the factory water filter housing.
First thing was to cut off the 5/16” stub that the factory pressed onto the end of this 1/4” line.z
Razor blade made quick work of that stub.
Here it is with the lines connected.
I just shoved the line back under the fridge and made sure it wasn’t rubbing on anything.
Then I did install an inline water filter but I forgot to get that photo too.
While cleaning the fridge up I heard the ice machine dump ice,
And here is the fridge cleaned up and back in its place.
Maybe I’ll wrap the fridge one day.
madison069
Monroeville, PA
Stopped at harbor freight to take advantage of their ICON 1/2” torque wrench sale. I also picked up some glove holders and some wheel cleaner.
The ICON torque wrench is going to replace the Storm torque wrench that was last calibrated in 2010.
Maybe I’ll test the storm out against the new ICON and if it’s close I can just throw it in the truck toolbox.
My other torque wrench is this Craftsman inch-pound.
And I got another in the middle torque wrench but I’d like to get something more compact.
I kept cleaning the benches and was able to clear some more bench spaces.
Look at all of these keys!
I don’t have anything for these keys and I think a bunch of them came from my dad and mom from properties in Texas. I might do a art project with them.
Oh and I got a lock collection too.
That’s it for the day in the garage.
madison069
Monroeville, PA
Here is the water dispenser in the fridge.
Along with the in line water filter. There is a rubber lined clamp that worked perfect to hold the filter but allows me to pull it out without removing a screw for easy replacement.
Now I have no excuse to not drink more water in the garage.
madison069
Monroeville, PA
Nice work on the water line hookup for the fridge. I have 2 fridges in the house garage and still to this day I have no idea why I have not hooked water up to one of them so I don't have to run back into the house while dirty. You have somewhat convinced me I should bump this further up the list.
Glad to be an influence on ya! Stay hydrated!
Xti04
Shinerbock, Bud Light Lime, and Busch Lite Apple is currently in the fridge.
If it don't rain, I might have a couple with a nice little fire outside tonight.
Glad to see you keep a proper beer in there amongst the AB trash!
madison069
Monroeville, PA
Tonight I got the air compressor hooked up in the bunker. End goal is to get a 60 gallon in the bunker, install air lines across the ceiling in the garage and put air hose reels in the ceiling.
But I’ve been missing the big air compressor for cleaning and using the big impacts on some of these projects.
So here is the temporary setup.
First thing was to get this plug off the side of the tank. A pipe wrench and a big hammer got it off quickly.
Went to Home Depot and got the black iron stuff I didn’t have. I had already ordered the flex hose from the internet so just the black iron stuff was needed.
I just installed a quick connect to the ball valve on the wall and routed the air hose under the bench.
It’s nice to have that back in working shape and it’s also nice how quite it is in the garage while the compressor is running!
Did some more cleaning and sorting but nothing much to report.
Fridge is doing good and has made its first bucket of ice!
And here is the fridge view, odd mix I know but it’s a nice variety for the kids and me. Plus a variety for mixers too!
The Busch Apple was a “why not try it” deal since a lot of folks liked it. To me it’s like drinking bud light while eating an apple jolly rancher.
Oh well, that’s it between normal day activities.
madison069
Monroeville, PA
That is an interesting lineup
Yea it’s part of my upbringing I guess. My dad and uncle were Budweiser fans, so they would buy them by the flats unless something was on sell. I started drinking Budweiser but switched to light for calories reason, it pleases the wife.
In Texas we also put lime and salt in our beer so the bud light lime fills the void without having to have fresh lime on hand all the time. Plus it’s a nice after cutting grass beer.
But I do alternate between Shinerbock and Yuengling as the primary relaxing by the fire beer.
madison069
Monroeville, PA
You able to get Shiner in the stores that far north or do you have to have it, uhmm.... delivered.
I have a beer distributor about 2 miles from the house that gets 4 cases of it a week, seems I’m not the only one here that buys it. If I come in the store and it’s not there, I just put my name down for a case and they call me when it comes in.
Ziegenbock on the other hand, that’s a beer I can’t get up here as it’s “Made in Texas for Texan” and they are only sold in Texas or nearby states.
txvwnut
Bedford, Texas
I had some friends come down from South Dakota many years ago and apparently you can't get Lone Star and Big Red up there. So when they left the Chevy pick up they and their two Harley's came in left with one Harley and plenty of cases of Lone Star and Big Red and one of them riding one of the bikes back to SoDak.
madison069
Monroeville, PA
Big Red, I do miss it. It was a cream soda flavor to me.
They had Cherokee Red here at one time but it was discontinued so there’s nothing to fill that sweet cherry soda void here either.
