Between 705 & 1200 SQ/FT The Texas Barn in PA
madison069
Monroeville, PA
After a 2.5hr work period of cutting measuring, finding tools, soldering, and testing I finally got the water line sorted out that went from the house to the garage.
I replaced the old shut off valve that was here with a new quarter turn ball valve.
Outside I made the connection to the pex line and also raised the spigot to make it more comfortable to work with and put a new spigot.
And look at that! Water coming out of the spigot on the garage!
I had to shut the house water off since I needed to install a toilet shut off valve, so figured I would get this checked off my list of things to do. Just need to get some masonry sealant to seal the hole where I passed the pvc conduit through the cinder block wall for the copper pipe to pass through.
madison069
Monroeville, PA
Got some concrete silicone filler and sealant for the cinder block wall to seal the gap where the water pipe went through.
A little finger action to ensure it’s sealed.
Then I got the inside wall too.
I guess I can call that little project complete.
Nothing else was done except clean up the house a little.
madison069
Monroeville, PA
I got the rear hubs installed on the oldest’s car and so far it sounds better I think, but I’m waiting for a pair of ears.
Here’s the new hubs in.
I even cleaned to floor, it cleaned up nicely with a little simple green and paper towel.
Could use a sweep and mop.
madison069
Monroeville, PA
Well I talked to my concrete guy and he has me in the rotation. He’s busy but will try to get started within the next 2 months. If he can’t do the whole project at once, he will atleast get sections of the project done when he can. First area is the spot between the house and barn.
Need to figure out a path and pad design that will provide a walkway to the bunker opening, designated grilling area, open walkway between the house and barn, and make it look nice.
The current narrow walkway will be ripped out and a 3ft wide sidewalk will be installed from the porch steps to this area. The original red pad will be left alone, just saw cut to clean the joint that’s close to the barn. A 5ft wide sidewalk will be installed to the right of the barn to provide a path to the front of the barn. That’s really the only details I have at this time as I keep thinking of how I want it to look here.
Then it will be the driveway to the left of the barn when looking at the back that will be poured so I can park the car trailer and boat beside the barn.
madison069
Monroeville, PA
Some progress over the weekend.
I got the shower done in the basement bathroom.
Those sliding glass doors are heavy.
Got the American flag up in the porch post for 4th of July. In the end I’d like to put a pole up, but this is nice for now.
Went to a Kid Rock concert Saturday night, he was very patriotic and entertaining for a guy that’s been doing this for a long time. I would go again to another concert if he came through here.
Sunday before church I got the baseboard around the toilet installed and then put the toilet back in the bathroom. I still got some small details but it’s functional and can be used.
Wife wants to play with some colors around the sink so I put the sink install on hold for now. But atleast the sink is out of the living room for now.
Then after church I started cleaning the house. I’ve been by myself for 2 weeks while most of the family have been traveling to Uruguay and Argentina. Hence why I’ve been working on a lot of projects.
Filled in the hole by the retaining wall with some 2B gravel and then a piece of landscape fabric before I put topsoil and grass seed down. Here’s the yard after I cut the grass.
It’s not 100% grass, but coming from West Texas I’m happy to have a green yard!
Then I got the bunker semi organized, now I can walk in the bunker and find stuff without tripping over stuff.
The gray cabinet and the totes are all empty. I need to figure out if I even need the totes before I toss them in the trash.
Overall I got a lot done so I’m happy with the progress I’ve made. Everything still needs more attention but that can wait another day.
Happy Father’s Day everyone!
madison069
Monroeville, PA
Not much has happened the past week except softball tournaments and spending time with family.
I did sneak in a little garage time.
Using the new paint markers, I marked the cut point for the uprights on these shelves. Seeing how I was recommending these paint markers figured I better tryout the new ones. They seem to work well, time will tell.
Here is the shelves assembled in the bunker.
Now I can move the shelves around in the bunker without hitting the I beams. Need to clear out a spot and start organizing stuff soon.
madison069
Monroeville, PA
Oh look! I got the other shelf assembly cleared off.
Put most of the stuff on the shelves in the bunker.
Then once I got the other shelves assembly cut down, cleaned, and moved I put all of the camping related gears on these shelves.
Now to keep clearing out and sorting stuff, get the 4 mowers I have in the garage repaired and sold.
madison069
Monroeville, PA
I have been researching the garage door opener world and after comparing and checking prices, I decided to get the RJO101 by Chamberlain. From what I’ve found comparing parts and numbers, these lifts are the same under the cover as the Liftmaster 98022. The difference between the two are Liftmaster is more geared toward professionals installation, has a fancier wall mount door opener, and has three buttons remote. The Chamberlain has a no lcd wall mount, single button remote, and is geared toward residential install. Warranty are the same but per the fine print Liftmaster models are supposed to be worked on by professionals but as some people have mentioned on here, they were able to call the company up and get the parts themselves after doing troubleshooting with the phone rep. Otherwise it’s the same warranty time period, same company ownerships, and same motor/control board/software between the two. Also the Chamberlain is $160 cheaper each.
So here are the two openers in the box.
I laid out one and inspected everything.
After reading everything I realized there was no printed insulation pages. Instead you had to download an app called BILT where they provided a 3D step by step instructions on how to install the opener. Overall I had no issues with using the app and it made understanding the instructions better cause it had short videos as they installed the parts.
Currently I got the first one installed but I didn’t mount the wire on the wall. I will install the other opener and them I’ll secure the wiring to the wall once all of the wires are in place.
Overall it’s functioning properly and with finding tools, reviewing the instructions several times it only took me 2hours to install it. The second one should go quicker now that I got all of the tools gathered and know what to expect.
OutlawDrifter
KS
Install looks good Cody!
If I ever start over, I'd definitely prefer the wall mount! That's actually what I had spec'd for the shop, but they installed the wrong one, and after explaining my displeasure, he ended up eating the cost of the opener rather than install what I had asked for...at the time it seemed like a good idea, but there have been times I'd rather have the overhead space.
When the screw type in the Mrs.'s garage went out, they had a model that dropped right in, so it made sense to replace it with the same updated model.
pima67
Tucson, AZ
Haven't lately but on the way to the Tucson airport one passes by a large building labeled Chamberlain and Liftmaster.
Builder installed 3/4 hp LMs on both doors. The small door opener died and had it replaced with a 1/2 HP LM ( no control board available due to age).
When the large door one failed I had it replaces with the 98022 so a future owner could install a lift.
At my age not a DIY job for me.
madison069
Monroeville, PA
Thanks! If you have any experience with cable staple guns let me know, as I am looking into something to help ensure a clean install when stapling the wires to the wall. I don't think I currently have a cable staple gun, but I need to dig around in the attached garage where the staple items are located.
I can understand with just rolling with what they installed, they did give it to you so it's hard to justify changing it out when it's working.
Seems like Chamberlain and Liftmaster is owned by a bigger corporation which isn't unusual these days. With the goal of installing a 4 post lift in the garage, that's the main reason why I went with a wall mounted garage opener. Granted I have to keep the door down when I raise the car on the lift, but atleast I have that little safety clearance with the opener not being in the ceiling.
madison069
Monroeville, PA
I'm thinking the Arrow T59 stapler with the insulated staples is going to be my best bet for a cleaner install compared to trying to hold the cable and staples with my hand while I try to hammer the staples in that came with the system.
OutlawDrifter
KS
Cody, I have no advice on this topic. I did mine the old-fashioned way with the hammer and a bag of "u clips".
pima67
Tucson, AZ
To run the control wire on the ceiling from where the center opener was to the LM on the side next to the door, I used a single nail clip similar to what is shown above. Put the wire in the u shape plastic thingy and only had to hammer one nail. Didn't require a big hammer. Also had them on hand from some forgotten project. The installer was new to installing the 98022 and had to call his boss a couple of times. I had to suggest how to run the wire.
madison069
Monroeville, PA
Took me an hour to get the second door opener installed and programmed.
Here they are both opened and adjusted to open to the same height.
Closed with the lights on.
And lights off.
I ordered the T59 staple gun and insulated staples. I figured it would get used in future projects so it was worth the investment to not smash my fingers.
Now that they are both installed and working, it’s time to mount the wires in their place.
larry4406
Northern Virginia
Nice on the jackshaft operators!
Did you have to install any helper springs to push the doors in the closed direction when up so as to keep tension on the drums, or are your tracks tilted slightly downward towards to the torsion spring?
I want to install 2 of these at current house.
Last shop 13-15 years ago I had Liftmaster jackshafts installed and the tension on the drums I guess was not enough and had some birds nests they fixed and tilted the tracks. Was not aware of the helper spring option then.
madison069
Monroeville, PA
****Thanks by the way! ****
You got me to thinking and so I checked to see how the track was directed as I had a garage door company install them both. They tilted the rear of the track upward toward the ceiling. They adjusted the doors for the garage door openers as they knew I wanted to install the openers, and so I guess they had it set where I wouldn’t have any issues. The tension cable were never loose when the door was open or closed so they must of done something right, What was it I don’t know. But I know they were great on the price of the doors and installation that I couldn’t justify doing it myself. But when it came to the door openers, they were pretty high even if I was to installed the Liftmaster 98022 they wanted to sell me. High enough that I saved $1,000 by installing these chamberlain and did the work myself. I guess it’s to cover warranty work if needed?
madison069
Monroeville, PA
Here are the insulated staples.
Before stapling the wires in place I made some pigtails curls in my wires to have some slacks for any reason needed.
Are the wires tight against the trim, not really.
But they are close enough that I don’t see them 20ft away. But up close it’s obvious.
I’m not sure how I like these wires going across the wall. Now that I think about it, I could have put them on the man door trim and run them down and then back up the garage door. I’ll let it be for now, but I do have extra wires that I can do it later.
Here is the overall job done.
Overall I’m happy with it and so far I recommend these openers cause they were pretty easy to install and program.
We will see how they hold up over time.
madison069
Monroeville, PA
I mean...a guy could always smash a trough in that painted drywall with a hammer, over to the buttons, and then place a nice coating of mud over the wires after you lay them in said trough 🤔 ;)
Thats not a bad idea I suppose. I’d like to do a little mud work around the light switch so it’s a good excuse to do it.
bakmopar
Northeast Ohio
Anyone else saw the Big Boy 4014 that is touring around the Northeast?
It’s a steam engine and there’s only 8 that exist and this is the only operating engine currently.
Was pretty cool to see it.
I love your pics. Looks like you were up on a hillside above it.
I saw it this morning at a road crossing in PA, close to the PA/OH line.
madison069
Monroeville, PA
Thanks! Basically I was on a bridge that crossed over the railroad tracks. I was more on the entrance of the bridge to get that view while the rest of the family opted to be right over the track. We agreed my photos were better than the ones over the track.
I saw it coming into Reading last week, and again at the Philadelphia Navy Yard on Sunday, such a cool and awesome piece of history.IMG_5112.jpeg
It’s strange to hear of some of the people’s responses to the train. Some just don’t understand why anyone is interested in an old train, these are engineers saying this. While me and a buddy was fascinated by it and its history, but we are also nerd engineers I guess. Considering how much the railroad had changed the course of history it’s mind boggling!
madison069
Monroeville, PA
Today’s project was assembling a 1920’s Brunswick pool table for my father in law. He bought this table in pieces and he had restored the wood surfaces so far. His goal is to sell it once it’s completed. So we needed to see if there was any missing pieces.
Here is the beginning,
Three hours later, here is the stopping point for today.
I spent 40 mins trying to figure out how this ball catcher goes together since it was disassembled in pieces.
We identified a missing piece in a corner, so I used cardboard and tape to make a template of the other corner that had the missing part. Hopefully I can make something that this can slip over.
I got a bunch of wood I need to shape for him so once I get the truck brakes done, I’ll start on these wood pieces he wants me to complete.
RickP
Annapolis, MD
Those pictures of Big Boy are so cool -- I'm hoping I can see it in person someday.
My grandfather loved trains and traveled all over to see them. His job in the '50s was selling locomotive accessory equipment to the railroads, but that was for diesels. His hobby was the steam engines.
madison069
Monroeville, PA
I think I've seen Big Boy 3x now...and when it comes around for a 4th time I'll try and go again....just so damn cool!
Sweet pool table project!
3 times! If I had the chance to see it three times, I would have studied different locations for nice backgrounds!
madison069
Monroeville, PA
Big Boy stopped for a diesel train to get past him at a nearby station and when the diesel train came through you could hear everyone grown about it. The engineer in the diesel was just a smiling and waving! lol
thammel
Maryland
Amazing with the tubes that take the balls to the end! I have a Fisher brand pool table. It has a 3 piece slate top. I've moved it twice. On my table the balls run down tracks on either side. It's a very simple ball return system compared to that brunswick one!!
madison069
Monroeville, PA
Well I finally started on the 2012 F250 brakes today. I only got the front completed. The passenger side was done.
Passenger side pads was separated too.
Driver side wasn’t as bad, but I replaced it all too.
While disassembling the brake hose I found the break in the 4WD vacuum hose also. I knew there was a break in the hose but I couldn’t find it since the corrugated cover was hiding the break I guess.
Here’s the tools used during the job, using some Wright impact sockets. I still need to upgrade torque wrenches.
Here is the driver side assembly with new stainless steel braid brake hoses
And the passenger side
Fluid film seems to do a good job of preventing rust, but it’s nasty when working on the truck.
I need to reapply the fluid film though.
Tomorrow I’ll work on the rear brakes and then I’ll start bleeding the brakes and flushing old fluid out.
Once the brakes are completed, I’ll install the new 4WD vacuum hose harness to replace the old brittle stuff.
madison069
Monroeville, PA
What’s interesting is these tubes are made with what looks like cardboard tubes and is wrapped with something on the outside. I’d like to do a little repair on those tubes but I’m not sure how I will do it yet. This table is also a 3 piece slate top, we were debating if we even want to bring it up from the garage to the apartment above the garage. Still on the fence about that as they are heavy. But it took me awhile to get that ball return system assembled, I’ll provide some photos for the future owner!
OutlawDrifter
KS
Cody, I have a set of those brake line clamps that go over the end as well, they are awesome.
Nice work on the front brake R&R. The underside of that Ford definitely looks better than expected, proof is in the pudding.
Xti04
Just went back to see what you were talking bout. I have a set of Mac clamps made for brake hoses, but I really like that solution. Off to the jungle to harvest a set of those. And just like that, GJ claims another victim.
