Retaining Wall Advice
rockcrawler
Dallas, TX
We live East of Dallas, TX and have need of a retaining wall, which I’m guessing will need to be about 4’ tall. The yard on one side of our house is very steep which is causing quite a bit of erosion. It seems that over the last few years, it is getting steeper. There is grass, but it does not grow very well due to the rate at which the water runs off. I will need to hire someone to do the work as I will not have the time nor the help to get it done myself. When I have contractors come out to give quotes and explain how they will build it, what should I look for? Is there a specific block that must be used? What are the best ways for the wall to maintain the best structural integrity? I’m terrified of this entire process as we have had very bad luck with contractors over the last 5+ years. I just don’t want to get ripped off and end up with a crappy wall that is going to fail in 10+ years or less. We live outside the city limits, so no permits are required. Should I hire a structural engineer to design the wall, or is that something the contractor will/should do?
JuncleJohn
Omaha, Nebraska
How long will this wall be? I built 6 walls where I live over 20 years ago and they’re all in good shape. Very little movement even with the freeze and thaw we get up here in Nebraska.
I would insist on an compacted rock or gravel base, and use blocks that weigh 75 lbs or more. The first block should be buried at least half way below grade.
John
larry4406
Northern Virginia
Google segmented walls.
You will see they have details involving geotech fabric and gravel.
Drainage is very important as is the tie back via the geotech fabric.
Where I live retaining walls with more than 36” exposure need a permit. I know you said permit not required where you live.
Generally walls 36” and less in exposure are just gravity walls whereas the taller ones get the geotech fabric tie backs.
Wood retaining walls also get tie backs and are often called deadmen.
R
rockcrawler
Dallas, TX
John
Not sure on the length yet. It will have to taper down on both ends. We also have to consider lower areas next to it that may hold water. We are going to have to consider some water flow options as well (French drains, etc.). Our pipe fence will also have to be modified to run along the top of the wall or up against it. Right now it is 10’ pipe pushed in 5’ and then all welded together and horse panel also welded on.
R
rockcrawler
Dallas, TX
I put "retaining wall contractor in dallas tx" in Google and got a few promising looking hits. I would call a few and get quotes from them.
We have started that process, I just don‘t know what all to look for to ensure we are getting a wall built correctly.
I have an appointment next week for one guy to come out and look at our project. This is what he sent me after our phone conversation this morning.
“concrete footing, steel reinforcement, concrete masonry units and a drainage system designed to relieve water pressure behind the wall”
 Excavation and preparation of a stable foundation area along the approved wall alignment.
 Reinforced concrete footing sized for the verified wall height, soil conditions and site loading.
 Vertical and horizontal steel reinforcement tied into the footing and wall system.
 Concrete masonry unit (CMU) wall construction, grouted and reinforced where required.
 Wall cap or finished top detail selected to provide a clean, durable appearance.
 Compacted backfill placed in controlled lifts to create the desired finished grade.
 Topsoil placement and final grading to support landscaping or turf installation.
Drainage is a critical component of the project because trapped water behind a retaining wall can create hydrostatic
pressure and contribute to movement or failure. The preliminary drainage approach should consider:
 Washed drainage aggregate behind the wall to provide a free-draining zone.
 Filter fabric or separation fabric to help prevent soil migration into the aggregate.
 Perforated drain pipe installed at the base of the wall with a positive discharge location.
 Weep openings or other pressure-relief measures when appropriate for the selected wall system.
 Finish grading that moves surface water away from the residence and prevents concentrated discharge onto
neighboring property or vulnerable areas.
Stuart in MN
Minneapolis
I'm guessing the type of block used is sort of a regional thing, and contractors will tend to use the same type over and over for most projects since they're comfortable with it. You may have already done this, but driving around town and looking at existing retaining walls in people's yards will tell you what's typical in your area. If see styles you like, take photos with your phone and show them to the contractors when you solicit bids.
firebirdparts
Kingsport, TN
I am very opinionated that retaining walls should lean. They should not be vertical. To me, that is fundamental. People simply cannot lay CMU's or bricks leaning. It can't be done. So you need to be looking for material designed for retaining walls, which means you really don't want a mason.
rlitman
Long Island
Drainage behind the wall is the biggest thing here. Most retaining wall failures are due to poor drainage.
Water behind the wall can cause hydrostatic pressure on the back-side of the wall. Freezing wet soil expands. But then there's the likelihood that he's in the land of expansive soil. Lots of people install drip irrigation around their foundations in the Dallas area to keep the soil from shifting their houses. I have no idea how you'd handle that with a retaining wall, but you'd better be prepared for it.
Copymutt
Colorado
I’ve built 2 over the years, The 3’ x 50’ wall of PT timbers built in 1983 is C shaped to lock it from leaning. It has perforated drainage w/ fabric cover daylighted to a pond. The 4’ x 25’ of Doug Fir is protected w/ ice & water shield on the soil side and has numerous deadmen. No drainage on this one. No run off & we get less than 10” of rain per year.
Lynden
Southern California
If you are uncomfortable dealing with contractors, hire a civil engineer to design the wall and inspect the contractor's work during construction.
carlaisle
You don't need an engineer for a 4' wall, but it certainly won't hurt you any to have one. The guy whose comments you posted above sounds knowledgeable. That does not mean he will deliver quality work, but it's a good start. I will say I have never seen a block retaining wall that didn't fail over time. What are the aesthetic requirements for this project? Are bunker blocks an option? They're fast, cheap, and basically idiot proof. If the look is found somewhat wanting, veneer them. You could also go with large stones somewhat like the below. They're just held in place with gravity and their own mass. 4' is no sweat.
R
rockcrawler
Dallas, TX
We have expansive soil here and last year I installed a drip line around half of our foundation to assist in keeping it from drying up and causing shifting. The side of the house where the yard is very steep, still has openings in the soil at the foundation even with the drip line. There is a lot of erosion on that part of the yard, thus the need for the wall.
R
rockcrawler
Dallas, TX
There is someone in our neighborhood that did a small wall like this on one side of their house. We will be looking at something more refined like a light colored block with a textured face. This style will match our house.
larry4406
Northern Virginia
I like the wall @jpcjguy built.
rlitman
Long Island
Yeah, I had a feeling from your location. I've got a friend dealing with his house settling due to it. A quick search found me this:
"Another method is used for the backfill behind retaining walls. The expansive soil mass surface behind the wall is cut back to at least 45 degrees from the horizontal, so that as it swells, it will not impose loads on the wall. The remaining backfill material is made of nonactive, free-draining material, and a system of weep holes and filter-protected drains is installed at the base of the wall in the backfill (Figure 7)."
I'm not in any way recommending any particular construction method (and have no idea if the document I linked points to the current best practices), but what I do know is that your difficult soil conditions make retaining wall designs that work fine elsewhere in the country a recipe for a dangerous failure against expansive soil.
Lynden
Southern California
Another idea is to use two 2-foot high walls instead of a 4-foot wall. Place the higher wall on the property line and the second wall at the toe of the slope with a gently-sloped landscaped area in between. Instead of a civil engineer you could hire a landscape architect to design the wall and do the construction inspection. A picture of your yard's sloped area would help.
A second idea is to use a standard retaining wall design and have a civil engineer approve it. I live on a hillside lot and the retaining wall along one side of my driveway is a standard Caltrans wall. What county do you live in? I noticed Dallas County has a retaining wall design in their standard plans. Perhaps your county does also.
MongoTA
CT
Everything in your Post #6 sounds proper.
I mortared up a stone wall back in 2022, it's about 120' long and about 3-1/2' high.
I dug out a slope to level a part of my back yard, all the rocks in the wall were unearthed while digging. Thank you Connecticut! It's built on good draining subsoil over shallow trench filled with stone. Most of the subsoil I dug out was screened, all the small stones from screening were used to backfill behind the wall, the larger stones became the wall. Front face of the wall leans back a bit from plumb. Wall is about 2' thick.
First photo from Fall 2022 when rough work was mostly done. Planted it out the next year in 2023:
Second photo from a few months ago, three years after planting, photo taken from pretty much the same vantage point as the first photo:
R
rockcrawler
Dallas, TX
Very nice!!
larry4406
Northern Virginia
Fantastic!
drivesitfar
RC: I’ve only been to Dallas once but as I recall there are hundreds if not thousands of small ponds I saw from the plane. That said I’m guessing water will be your biggest issue to keep it from pushing over your retaining wall.
Here anything under 4 feet doesn’t need permits but we also need to make sure water and water pressure don’t build up behind it.
I’ve built a couple 4 foot walls here and once the footing is poured my favorite method is using 90 pound concrete blocks with fiberglass pins that stack easily and great exercise if you don’t mind hard work.
I’ll let others speak to their methods of drainage that might suit your situation but maybe you could post a few pics of your property and or the small hill you are trying to support.
R
rockcrawler
Dallas, TX
It appears that the first guy wants to build a CMU wall (about 85 linear feet) with filled block cores and vertical and horizontal rebar. All on a concrete footing with piers every 18” or so. Perf drain pipe at the bottom with drainage gravel wrapped in filter fabric. The wall would then be faced with architectural stone and a decorative cap. This seems like a solid plan. Of course there will be drains on the front. We will also be running the house gutter downspout pipes through the wall as well.
Shiftless
East Bay SFO
Are you sure you want all the rainwater from your downspouts flowing out onto one area at the very bottom of your new retaining wall? When I did a similar project a few years ago I hooked all the downspouts to a 3” solid plastic pipe and routed that down to a city storm drain. The perforated tube at the bottom of the backside of my new retaining wall also connected to solid plastic tubing and flows by gravity down to the same city storm drain. I didn’t want hundreds of gallons of rainwater from the downspouts spreading out over the new patio and possibly down to my house foundation.
Dig Doug
Pics of the area would be great !
Make sure the retain side of the wall gets water proofing
Here in California we have a regional standard masonry drawings not sure if Dallas has them - maybe google
get a minimum of 3 quotes
steer each contractor meeting so they all have the same direction & pricing will be similar
maybe write up a narrative
85 feet long CMU and footing size. rebar size in the footing and vertical/horizontal etc
Rock & fabric, french drain, waterproofing, pipe etc
NOTE - you MIGHT have to haul off/ export some dirt
example of drawing print out and review for a better understanding - terminology & Rebar size & placement
this is for San Diego, Ca.
your looking at below 5 ft 4 inch total wall height
if your land isn’t flat you may have a step or 2 in the footing in order to maintain your height - you want a flat top course without any steps
I hope this helps
if you have questions ask away
Dig Doug
I did a quick google search
some interesting information located here
This is just to educate - So you have more information
Click on that web site scroll down to
here
READ - through the next few sections after this section it deals with/ your area and the difference soil conditions, drainage, structural integrity etc
I found it interesting
R
rockcrawler
Dallas, TX
The other side of the wall will be where a shallow trench is between us and our neighbor. It’s already partially filled with large rocks because water flows through during rain fall and we were losing soil and had standing water. We will just have a liner and more rock placed down the full length the wall to continue the feature. All of that water runs into a culvert under their driveway and into a pond in their yard. All of the water flows down the hill and into the trench already, so we are not adding any water. We are in an unincorporated area, so there are no storm drains or any other kind of water mitigation features in the neighborhood. All water just goes where it goes.
R
rockcrawler
Dallas, TX
I hope this helps
Some good ideas here for sure, thanks. As far as dirt goes, we are going to need a ton of dirt to back fill and bring the yard up to where it needs to be. The builder had to construct a pretty tall pad for our house, so its going to take a lot of dirt to pull this off.
drivesitfar
You don’t have to say if you don’t want to because every part of USA and the world has different costs involved but I got one would be curious.
I think the last time I bought my 90 pound blocks that are 18 inches wide and 8 inches tall were $13 each. That said putting in a nice footing, and drainage for 85 foot long 4 foot high wall won’t be cheap if you’re not able or willing to do the work.
Good luck
R
rockcrawler
Dallas, TX
Good luck
We have not received a quote from either of the two companies yet. We also still have others coming out soon.
drivesitfar
I thought I’d mention some material costs cause I’m guessing your quotes could be a bit spendy. It’s great to have things engineered and permitted if necessary but sometimes simple works too. The nice think about the big blocks I use is that there are sometimes used for huge freeway retaining walls and since there is small gaps the pressure doesn’t build up as much behind them as it would with a solid retaining wall.
I’m not sure they sell keystone blocks in your area but I bet they sell something similar.
Good luck!!
