1956 ford f-100 MAKE OVER
D
don long
southern california
An update on the truck: The exhaust headers have been modified to allow the steering shaft to split the tubes and ride between them on the driver side and go straight back on the passenger side, The front suspension is all fitted up and the motor mounts are positioned and welded in. The guy was bending the brake lines while I was there dropping off a set of corvette wheels and tires.
Jetfixr320
As someone who's broken their frame in half more than a couple times....
You are correct, that overly notched!
OP, you need to add more back or a bridge on top.
If you look at some other pictures, it appears to boxed in that area.
drivesitfar
Awesome work and when I saw you mentioned your projects were on hold I kinda knew it wouldn’t be long before they got traction and started again. Nice work.
Any cool blues or greens in your paint cabinet for your (our) ‘56?
Glss
Northampton County, PA
This style focuses on slamming the ride height, deleting factory trim for a smooth appearance, and installing large modern wheels. Builders frequently opt for deep candy metallic colors, gloss black, or satin finishes to accentuate the truck's famous fat fenders.
D
don long
southern california
Went out to check on the progress of my truck and pick up the bed and fenders so I can start preping them for paint. Was asked to pick up a new gas tank for the truck so I went on a short road trip ( 90 miles) to get the tank and return back to the truck. That shot my morning but this afternoon I did get most of the holes in the firewall welded up and ground off.
