Shop Press Support Block Plate?
seagiant
Hi,
Has anyone ever used one of these for knuckle, hub, bearing work???61uHy+5u6iL._AC_SL1500_.jpg
djbmw
Ottawa, Ontario, Canada
Hi,
Nah, I just use several deep impact sockets placed under the piece Im working on, if needed, to make it level.
If the blocking plate is cheap enough, and those pins wont shatter, then it could also be a good addition if you're frequently pressing odd shapes.
landstuhltaylor
I bought one years ago, don't even remember where. It was the only thing I could find to get a Mazda hub set up straight in my press. I very very very rarely use it but it has been good to have around.
OccupantRJ
Eastern North Carolina
Being a machinist type fellow I keep an assortment of steel blocks, pipe sections, round stock and such all painted yellow to keep up with them in an old school steel hand tote tool box sitting on the base of the press. If something not there is needed, another one gets cut to size or machined for later use.
seagiant
Hi,
Interesting set up, never saw a press with the Bottle Jack that way?
I think I can do the Knuckle Job, with what I have, but saw this Jig, and thought it interesting, and was wondering if I was the last guy to see it???
OccupantRJ
Hi,
I have never seen the device but would feel more comfortable without it. It has some adjustability but does not make me feel warm and fuzzy with it supporting tons of pressure. If I was doing many presses of the same shape part I would build a devoted fixture.
In relation to the design of my press, I do not care for underslung jacks in a press. I built this press in the early 80’s along with helping a friend build one of his own. Here is a thread where I recently drilled additional support holes and painted it.
joecon
I do not have one but people who do have said they work great. Plus, it should be safer than using some untested random pieces you have laying around.
seagiant
Hi,
Trying to start the strip down of my Press...
Still 300 degrees, in Florida, so not pushing it to be honest.
Going to replace, the bottom angle iron, with something stronger, with some 5" Casters, and leveling feet.
Put in a Winch System, to help move the Table up and down, make some Tooling for the Ram, and give it some paint for the rust...
