10x16 shed question
sofasurfer
This shed is not for great weight bearing. Just storing tools, generators, power washer and saws and some space for a small bench and work area. I'm using 2x8-10 footers and 2x8-16 footers for the perimeter with 2x6-10 footers at 16" on center for the joists. Putting perimeter up on deck blocks at the corners and in the middle of the 16 footers. Floor will be 5/8" plywood. Do I need the official deck blocks or are plain solid 4x8x16 inch concrete blocks ok?
Uncle murph
Harford county
This post doesn’t make sense to me and I deal with this stuff every day.
sofasurfer
O geez! I used the word "footers" in place of "ft".
Can we continue? I guess my question is, do I need to use deck blocks with the slots that the 2x8s sit in or can set them on concrete 4"x8"x16" blocks. I assume the only difference is that a tornado force wind could slide the shed on the flat blocks.
Joe Reed
Cordova TN
Tuff Shed put my 8x12 on normal concrete blocks. Same for every shed I've built in the last 50+ years. Never had an issue. Probably a gazillion sheds out there built the same way.
sofasurfer
ok, I have resolved that question. Next question... LP smart Siding
Code:
https://www.menards.com/main/building-materials/siding/engineered-wood-siding/lp-reg-smartside-reg-3-8-x-4-x-7-grooved-8-oc-textured-engineered-wood-panel-siding/27806/p-1444438207001-c-5827.htm
Company says it must be primed or the building wrapped in Tyvek. I will not be building this until next spring but I found this LP Siding on sale for half off or better. Can I buy this and store in in my barn for that long without worrying about moisture effecting it? Should it be wrapped in tarp or will that actually trap the moisture?
I don't mean to sound neurotic but this is important information for me. I really want this siding but I'll never be able to pay the normal price.
mepstein
I would buy it and store it in your barn. It’s not like a lumberyard is going to store it any better. It’s a treated product and should handle indoor storage just fine. Grabbing materials when they go on sale is a great way to keep cost down. No tarp in my opinion. Let it breathe. But don’t have ground contact. Some wood stringers should do it.
couch67
Ontario Canada
agreed would be totally fine in the barn, off the ground. If you have the space, buy a few extra pieces for oopsies or future repairs. Always nice when you have it on hand and dont need to go hunting for a match
Sumboodie
AK
Mine was 2x8 12 OC, about 5 ft span and 3/4" PT ply floor.
I screwed up and didn't put blocking between sheet seams. My Ranger ended up going through. It was maybe 2500 lbs... 6 man diesel with a cab.
andyvh1959
Green Bay WI
First off, I built my yard shed on 4' sizing, meaning it is 12x16, less sheet cutting for plywood or T11 siding. The deck I make out of pressure treated 2x6 floor joisr and one layer of 3/4" pressure treated plywood. More than plenty strong enouhg to support the five motorcycle stored in there. SO, plnenty strong for a lwnn tractor or ZTR. I set the deck on a leveled gravel base about 6" thicj with concrete deck footers to raise the deck off the gravel. Its been solid andlevel, plmub through 21 Wisconsin seasons with no issues.
Skooterj
Indiana
I left a pallet of LP outside for 6 months under a tarp and it was fine. It was at a slight angle so the water ran off of it. And it was a nicer tarp. But it got snowed on and rained on and froze and was fine.
