10x16 shed question
sofasurfer
This shed is not for great weight bearing. Just storing tools, generators, power washer and saws and some space for a small bench and work area. I'm using 2x8-10 footers and 2x8-16 footers for the perimeter with 2x6-10 footers at 16" on center for the joists. Putting perimeter up on deck blocks at the corners and in the middle of the 16 footers. Floor will be 5/8" plywood. Do I need the official deck blocks or are plain solid 4x8x16 inch concrete blocks ok?
Uncle murph
Harford county
This post doesn’t make sense to me and I deal with this stuff every day.
sofasurfer
O geez! I used the word "footers" in place of "ft".
Can we continue? I guess my question is, do I need to use deck blocks with the slots that the 2x8s sit in or can set them on concrete 4"x8"x16" blocks. I assume the only difference is that a tornado force wind could slide the shed on the flat blocks.
Joe Reed
Cordova TN
Tuff Shed put my 8x12 on normal concrete blocks. Same for every shed I've built in the last 50+ years. Never had an issue. Probably a gazillion sheds out there built the same way.
