hacksaws?
Union Hardware Co., Torrington, Connecticut No. 10 hackwaw
* this saw is missing the original wing nut *
59Sled
Santa Clarita, California
Picked this Eclipse no.55 saw today. Only bought it because how odd it was. Strange that it has a hacksaw blade on the bottom but is like the size of a coping saw. Also not sure the age of it IMG_6530.jpegIMG_6529.jpegIMG_6528.jpegIMG_6532.jpegIMG_6531.jpeg
59Sled
How did you get the handle so shiny.
I lightly sanded the rust off with a red scotch brite pad.Then I use foam backed polishing pads. The pads are 2 inch by 2 inch squares and starts at 320 grit all the way up to 3500 grit. I start with 320 and cont up to 3500; after that I take it to a buffer wheel.
Leviton
Oregon
I found a Consolidated Tool Works No. 27 pistol grip hack saw with a composite grip. It was part of their Pilot line. It was in their 1923 "Miniature Catalog" that they published in Hardware Age and Hardware World.
(I need to do a little surgery to provide a more correct front blade holder - I'm working on that.)
@d42jeep previously posted Consolidated's handle tensioning version...
I found a handle tensioned wood handle hacksaw from a company I hadn’t run across before. Consolidated Tool Works Inc. New York USA. From what little I could find on the Internet, they were around in the ‘20s.
59Sled
These key hole jab saws are becoming a little addictive.
They are cheap and they clean up and polish well.
Picked these 3 up over the weekend for restoration.
Millers Falls 525
Allway Handy Saw No.100 Aluminium handle.
Unbranded but looks like another Allway. The handle on this one is steel though.
59Sled
Also picked this up last weekend.
Don't see any markings on it. But the handle is very heavy.
Unfortunately someone destroyed the blade on it. They cut it up to make it a key hole blade.
Not sure how old the handle is or why its heavy steel.
Some say it could've been a ice saw.
Either way I like it and for the price I had to grab it.
Picked up this close quarters Craftsman hacksaw.
Did a quick little clean up on it this past week. Nothing too over the top on this one.
That’s an awesome hacksaw I like that very much, I do have a slightly more modern Snap on tight space one and also a load of eclipse hacksaw blade holders being from the uk I don’t find craftsman tool apart from the odd socket in mixed lots
This could be a docking saw handle.
Built for heavy use docking boats, you use the teeth to bite into the teak and pull it to the dock.
Actually built for docking heavy beams in mines, and other gross jobs where a wood handle may not last long.
59Sled
Two more saws cleaned up that I posted earlier.
Ultra MFG. saw.
Basic clean up on this one. Did a little blueing on the handle to give it some patina age look still.
This one I gave it my signature by smoothing out the foundry casting rib line on the outside of the handle. Then polishing it up.
Oregon rock crusher
West of Salem
Here is one I didn't find in a search of this thread. I picked up this cast iron framed Disston at a swap meet in central Oregon today. Maybe it was intended as a dehorning saw. Ed.
