Looks really good.
How did you get the handle so shiny.
I lightly sanded the rust off with a red scotch brite pad.Then I use foam backed polishing pads. The pads are 2 inch by 2 inch squares and starts at 320 grit all the way up to 3500 grit. I start with 320 and cont up to 3500; after that I take it to a buffer wheel.How did you get the handle so shiny.
Be careful--that can lead to drywall work!
That’s an awesome hacksaw I like that very much, I do have a slightly more modern Snap on tight space one and also a load of eclipse hacksaw blade holders being from the uk I don’t find craftsman tool apart from the odd socket in mixed lots
This could be a docking saw handle.Also picked this up last weekend.
Don't see any markings on it. But the handle is very heavy.
Unfortunately someone destroyed the blade on it. They cut it up to make it a key hole blade.
Not sure how old the handle is or why its heavy steel.
Some say it could've been a ice saw.
Either way I like it and for the price I had to grab it.
Beautiful work.
I think of the museums that build an entire dinosaur or animal from a single bone. You can do it, we have faith.like to think I can save almost any tool, but this one is beyond me.
Already pitched it. Too many other projects anayway.I think of the museums that build an entire dinosaur or animal from a single bone. You can do it, we have faith.
Correct, I believe the sway backs are dehorning saws also.Maybe it was intended as a dehorning saw.
