LS STARRETT CO (and not a vise)
nadogail
Coronado, CA
I am of the opinion that Starrett is the "Gold Standard" in measuring tools. I don't own any Starrett tools, as good as they are I can't justify the expense for my personal use.
RoninB4
Under My House
-They make decent instruments but avoid buying the series 711 "Last Word" indicator, especially if it's used. There are often problems with the 711 Last Word and there are better choices than that one model.
NORTON'S SHOP
Upper Midwest
When I attended trade school we called them "Last Time" indicators. The first time you'd use one was probably the last time you'd use one. By time everyone graduated, most had replaced it with an Interapid or a B&S.
RoninB4
Under My House
-I don't like to knock that model but it was an old design where Starrett bought out the original company (H. E. Lowe) to continue producing it. There's a lot of older machinists that own these, have great sentimental attachment to them, and might find my comments to be offensive. Should any of you take offense bear in mind that the complaints about this model are legion and easily found on various websites from professional machinists. If yours still works that's great, you do you. For the Starrett collectors, there's better designed offerings from them than this one. For the beginning shop wanting to add to the unending tooling list, don't waste your money. I own a lot of different indicator brands but never considered this one for purchase after the ones I'd seen that others owned.
Found today in the ReStore, a Starrett 3/32" punch. I didn't even know they made those.
It didn't look like that when it was new.
I'm sure it looked a lot like a nail set when it was new. The 3/32" is a common nail set size. As a punch it will probably be fine, but it probably broke when someone tried to pry with it. It may now be beyond the heat treated zone, so it may not hold a point as well. But for making center marks in wood, or other softish things, should be fine.
RoninB4
Under My House
I can’t even figure out how to use these?
-The one in the middle is a depth micrometer. The other two are sometimes for scribing lines a set distance off a surface plate in laying out geometry on metal. They are often called a surface gauge. What those two are more commonly used for is holding a dial indicator, usually a lever or plunger type, to check dimensions (used with gauge blocks), to check flatness of a surface, measure location of a construction hole, check top/bottom for parallelism, spindle concentricity, or to check perpendicularity of top/bottom to the sides of a square or rectangle like a thick plate. A surface gauge with a mounted dial indicator is also used for setting other fixtures (Harig type head, radius dresser, etc.) to exact locations that require it. Surface gauges are mostly used with surface grinders or small OD grinding. There's other uses but this is probably more than you wanted to know already. I'll go sit down now....
Burt Shaver
Iroquois, Ontario Canada
Thank you, I can’t say I understand everything you said but I do appreciate you trying to explain it. It does give me somewhere to start searching.
RoninB4
Under My House
Burt Shaver
-It's machine shop gobbledygook, doesn't mean anything outside of a machine shop
-I can further explain things....but you'll be sorry you asked.
-Searching for what? If you're not in a shop why will you search? Just curious.
I just like learning and moving ahead slowly when it comes to stuff like this. I may never use any of it, but I like to know how things work. I’m all ears, so if you’re up to explaining more, I’m listening but I wouldn’t expect it.
RoninB4
Under My House
-So pick out what you didn't understand about what I wrote/typed in my reply. Evaluate which one(s) you might apply to what you're currently doing so you can use it. If none of it applies then pick the ones with familiar geometric terms. I need to bore someone else besides my own social circle.
searman
Recently, I went through my dad's tools looking for a Craftsman cotter pin puller that he had when I was a kid. I never found that, but I did find this drill and tap slide chart from what looks like 1955.
The supplier advertised on the front (J. M. Tull Metal & Supply Co.) is no longer in business, but a charitable foundation set up by that supplier is: https://tullfoundation.org/history/
Found a No.4 Thread Gauge today
I've got a couple of thread gauges, but.....since this is a Starrett, it moves into first place
That is the only Starrett tool I bought at retail, many years ago. Desperately needed it for a restoration project. Not sure if mine was the same model number tho. Still keep mine in the original box.
INSP380
Cleveland, Ohio
-No they are rather uncommon. I don't think I've ever seen one in 35+ years of machine shop work. The "Last Word" indicators aren't very well thought of but those are kinda cool because they're not often seen.
Bingo! I really wish I had the box to go with them. The box in the pic is waaaaay too new, but Will suffice till I come across the real deal. My love of the 711 is in part of it’s age. I have a few vintage Gems I like better. Very similar. Now if I’m using a test indicator, my Interapid or B&S are my go too…decisions decisions..😉
Steve
RoninB4
Under My House
-A dual faced inch/mm Gem was my first indicator in the later 70's.
-I've had a number of different makes/models of indicators from B&S, Federal, Mitutoyo, Ames, Mauser, and some disposables from China. Never really liked the dovetail mounting on some brands and they aren't all the same, requiring a dovetail clamp for JUST that brand. Too fiddly, too clumsy, too much time setting up some of them. My preferred make has always been the Interapids with the swing post. It also had a dovetail for mounting but I seldom needed to use it. No direction reversing lever needed, solid construction, with options for resolution, dial size, and orientation. They were always on the expensive side but were a daily/multiple time instrument for me. Never had a Compac, wish I'd had one. There are some other exotic brands but I stayed with Interapid for parts availability if repair was needed.
I read on some other forum or website they were often called Last Reading (or something similar) because they died so easIly and unpredictably. Of course i can’t find that link now.😞
So maybe that’s why it’s so rare.
RoninB4
Under My House
-You could be right in your speculations. I had some thoughts from the perspective of someone choosing/using it daily. To start with there's the resolution that narrows the customer base. Working to .0001's is a smaller percentage of work than most where you'd use an indicator, that cuts down on who needs one for what. If these indicators were made in the 60's - 70's there was even less machinery capable of holding that tolerance than there is today. Less machinery means less components designed with tight tolerances, less components means less demand for indicators with .0001 resolution. "If we build it they will come" isn't always true.
-My second speculation is the physical size of the dial. Without something for scale it's hard to determine the size of the dial but they do appear to be much larger than the standard Last Word I've seen for decades. That size, while it does make reading easier, makes it more clumsy/difficult to use for a lot of applications. There's plenty of times I needed to get into a narrow opening to indicate a small surface where the physical size of the indicator was a factor. Indicating something in a jig borer/jig grinder can present a limited amount of swing, which is why the extended probe (contact tip) on the "lever" type are offered.
-I very much like larger dials but the 1-1/2" is about the largest dial I'll go with unless the indicator is going to be used in an inspection/QC setting where it's used on the surface plate and there's nothing getting in the way. These indicators from @INSP380 may have been aimed at the inspection/QC segment of the market. Inspectors almost never buy their own instruments for the job and I doubt many company buyers would opt for the deluxe model of the Last Word as a company owned tool.
-There was a member here that called them something like that and it made me chuckle a little. Last Word indicators had a strong following because there weren't many domestic choices for indicators in the dark days of pre-internet. Starrett brand was also a "standard" of sorts for machine shop equipment and brand recognition carried some weight of opinion. I met more than a few older men that had those Last Word models and they were rather loyal to them. That may be because they were purchased early on in their career and the expense at that time created a certain level of buyer satisfaction. Toolmakers often get an opinion about equipment they use that is rather rigid. Last Word fell out of favor due to problems with sticky movement and crud getting into the delicate innards of the open body design. That was a problem, you might not know the inner mechanism was having trouble until after you ruined a workpiece because of a faulty reading. Repair facilities weren't big fans of the Last Word either. So when other brands like Interapid became more available with a better, more robust, design the Last Word was regarded by the younger generation entering the trade as a relic not to buy. That's how I regarded the Last Word, never considered buying one even when a retiring co-worker offered his at an attractive price. Never liked the non-adjustable tip, the reversing lever, or the way it had to be held either.
-They do have a certain aesthetic styling to them reminiscent of another era with the needle and the font used in the dial. I can see the attraction for some but I needed my indicators to earn my daily crust so I had a more pragmatic opinion. My entire post is just my opinion and preferences, I'm not the last word on much of anything.
