Metal-cutting chop saw - question
tarbellb
Oregon
Good score!
A excellent, capable saw, one of the most versatile saw out there.
Ive been converted from dry cut to bandsaw over the years here on GJ, guys like Drclyde have made a good case for the pros and cons.
lis2323
SCORE! I just got the WEN that I mentioned in post #29, above. $150, great shape, extra blades....very happy!
I've only done a handful of test cuts, but I'm already wondering if I'll ever use the abrasive chop saw ever again!
Wow $150!! Congrats [emoji481]
seagull369
This will not work. These saws use universal motors. VFDs will only work with Induction motors.
I think you have that backwards. Those "chopper"/TRIAC devices work plenty fine with universal brushed motors, as long as the wattage of the tool doesn't exceed the amount the speed control is rated for. Choppers do not work well with the induction-type and will overheat them.
Brushed motors also operate just fine on modified sine or even square wave power provided by any given cheap inverter, though you wouldn't want to use that speed pictured control on those kinds of wave forms.
vanapplebomb
Holland, MI
No, you misread what I wrote.
I said a VFD will not work properly with a universal motor.
I know it was a longer post, but if you go back and continue reading to the bottom, I explain why this is true.
As for the universal motor speed regulator the original poster had in question, again, as I explained in my post, yes, it will control the speed of a universal motor, but at the expense of torque.
This is a double hit because the gear ratio of the abrasive saw gearbox is approximately twice the ratio of the dry cut saw, and the motor is powered down. The feed rate is going to be much slower as a result. There just won’t be enough grunt behind the blade for the carbide tips to really chew away at the material. It also will dull the blade faster and heat the part more because it is doing more rubbing and less shearing of the material.
seagull369
I took VFD's for meaning something else, sorry. One of the hazards of writing at 2 am.
The speed control mark-NJ posted in the original message is just a TRIAC, though, not a VFD, as I think you alluded to. To expound on your earlier statement, I don't think VFD's typically work well with single phase induction motors, as are found in most consumer equipment. They're more used on 3-phase.
tarmy
Nor Cal
This is why you get a good metal cutting band saw...
I was fooling around making a project and was needing to scrimp on material...these were the waste cuts. Year and a half old blade that was not a fine tooth blade either.
vanapplebomb
Holland, MI
Yup, the VFD, or Variable Frequency Drive comment was in relation to another post suggesting a VFD might work for the chops saw. I just didn’t want misinformation spreading and someone dropping money on a VFD only to find out it doesn’t work with universal motors.
You are also correct, you do loose efficiency with single phase induction motors pretty quick if you stray too far above the 50-60HZ range. They don’t like being sped up because of the impedance sharp impedance rise above 60 HZ. Although all induction motors experience a rise in impedance with increasing frequency, single phase induction motors are particularly vulnerable to lower frequency losses of induction efficiency. The offset winding in single phase motors relies on having a different inductance than the main stator to produce a phase shift and generate a rotating magnetic field. This small winding isn’t enough to maintain a solid rotating magnetic field as frequency drops significantly below rated frequency because there is less and less of a phase change between the two windings. When you go low enough, you essentially end up with them more or less in phase, and the motor fails to work. There phase motors don’t have this issue, and so it is much easier to produce torque at low RPMs with a three phase than single phase.
Deadsquiggles
Chesapeake, VA
I figured I’d ask here instead of starting a new thread. What’s everyone’s opinion on the Evolution R355CPS? It’s a “multi-material” chop saw instead of a true metal cutting saw but it claims with the standard blade that it’ll cut 1/4” steel with no issues. Anybody ever used one or should I bite the bullet and just up to one of the true metal cutting saws like the S355CPSL for $150 more?
pago cruiser
Tucson
Trick Tools advertises it for $2K
Awesome saw for $1K !!! Only miters to one side, correct?
Replying to a 6 year old post... but that HEM NG160 is now $3400!
Trying to find a similar capability Bench Top for less than the price of a used car...
This is nuts.:rolleyes:
tarbellb
Oregon
Hey @pago cruiser Bought one of THESE under the Northern Tools Klutch name (for less then half the Vevor price) a while back.
Its fine, cuts about everything ive thrown at it. For similar money standard issue 6x4" floor models are available.
Good luck
GeoBruin
I've been impressed with the Trajan saws sold by saw blade.com from what I've seen. They have a 6 inch capacity model for $1,000. Same blade length, similar power, similar capacity, miters 60 degrees in one direction and 45 in the other, variable speed, etc.
I owned a hemsaw and it was nice, but I don't think I would pay retail for one these days.
sawblade.com/machine/order-bandsaw-machine-trajan150?srsltid=AfmBOopEK2yP9dgfBuyBpV25OxNI_2uhNvxUDcoXxpFUzcTDpEkrJMpt https://share.google/tgJC90dKKQr7mH9px
pago cruiser
Tucson
Thanks gents. It is amazing how much some of these have risen in price (looking at you, HEM) and some have remained more-or-less stable - like the Grizzly and the WEN. The "inbreeding" between various manufacturers, as well as minute and major differences is also interesting. What a weird little slice of manufacturing. I ended up buying a Dake B5; primarily due to variable speed down to 82 FPM (I cut a lot of stainless) and 1.0 HP motor.
I'll make a new thread (as opposed to tacking onto a 6 year-old one!) on my eval and selection in the next day or so.
tarbellb
Oregon
That Dake B5 ($700+!) looks awfully similar to the Wen, Klutch, etc....
Keep us posted on the eval and performance.
Definitely interested to hear your research and ultimate selection process.
