I'll try to keep this as short as possible (probably won't happen).
In my RV garage, all the regular 3 prong outlets are 110v/15a except there is one 240v/50a 4 prong outlet. I have an Atlas 9koh 2 post lift (240v motor) that I use decently often and this 2 post lift usually stays plugged into the 240v outlet.
I recently also got an Atlas Pro8000ext 4 post lift. This came pre-wired from the motor with a regular 3 prong outlet plug and about 10 feet of cord. Issue i am now running into is "technically" the motor wants a 110v/30 amp outlet. ** It's really a 20.8 amp draw and when i called Atlas they also said max it will draw is 22 amps if ran for over 5 mins. total time to lift all the way up/down is between 1.5-2 mins. The 4 post im using more to help create some space and "worse case" id use the 4 post literally 1 time a month.
My queation is, could I use 1 of those adaptors for RV and houses that's a nema 14-50p (4 prong) that goes into a 20 amp (really 24 amp) receptacle. *here is a link from amazon
Here
Here
