The Everything 3D Printer Thread
jayz66ragtop
SoCal
I've read mixed reviews about the actual run-times when going dual nozzle with a dedicated support filament vs a single nozzle setup and many report that they see no real world difference.
Something about the other nozzle not being able to run as fast, it's limitation when it comes to filaments, and whatever else I may be forgetting or haven't thought about.
I run a P1S and while there is zero reason to upgrade at all, I thought I'd look into getting a P2S or X2C.
I guess it depends on how much support material the print needs vs the non-support filament. If the print uses a considerable amount of support then the time can be greatly reduced. The bigger win is the amount of wasted filament due to purging. I have a tri-color print that took 19 hours on my X1C and wasted close to 1/4 of a spool of filament between the three colors due to purging. With some strategic spool placement, that same print on my H2C takes ~15 hours BUT the filament wasted fit in my hand with plenty of space left.
KwikFab
Central Valley, CA
True, regarding the support material vs non-support.
Only the H2C uses what I'd say, two normal nozzles that both can run at the same speed vs the X2C that uses their regular nozzle for the main, and a slower one for the secondary.
I guess I could wait it out to see when people start posting about their X2C.
Old tool guy
How long can you pause a print? Bambu a1 and petg. Long print job, at some point it thought there was a problem feeding the filament so it paused. Probably 2 hrs later I saw it, gave it a swift kick in the **** and it continued as if nothing had happened. Looking at the finished product I can’t see where it paused, looks perfect.
draco_1967
Utah
Isn't the most efficient way to use the second material just for the support interface, not the whole support structure? That way it isn't switching material every layer, just the interface layers. Unless there is a specific need for the dissolvable filaments for internal structures...
I haven't played with that at all, just going off of the little I've read about it.
Old tool guy
Correct, that’s how i do it, works well. Sometimes. Sometimes i use the same filament. The real time **** is purging every time it chamges filament.
signcrafter
p2s with AMS
IMO best bang for buck for general purpose
From a guy that has never printed anything and figuring out which printer would be best. The X2D with ams is only 150 dollars more then the p2s with ams I believe. I have no clue if the second head for supports is needed for what I want to print but my thought was I don't want to spend 750 for the p2s and then find out down the road the x2d would have been better. That extra 150 seems like a good idea to spend now and have the capability in case I need it. Is there any downside to getting the x2d over the p2s if you don't ever use the second head besides the price? I just hate when I spend money on something and later wish I had spent a few more bucks to have more features.
Old tool guy
Need a little help please. Just got a P1S, trying to use it for the first time. Did a test print, it’s ok. But trying to do a chair part i’m getting confusing data. As you can see in the picture, i have selected the p1s and the 0.4 nozzle. That agrees with what the printer shows on its on-board control screen.
But when you look down below, it shows a 0.2 nozzle on a x1c. And the x1c is the only printer available to choose. What’s going on?
KwikFab
Central Valley, CA
Just some standard preset - the X1C and P1S are pretty much the same.
I never mess with those presets, and have never had any issue. But again that's why you'll see "X1C", because you've got a P1S.
Yankeefarmer
Connecticut
Can’t help you specifically with your question, but that is the approach that I took when I selected the X1C over the P?S. I have absolutely no regrets.
Old tool guy
Another conundrum with my p1s. First print job. I know i set walls at 4 and infill at 15%, and i went back after i took this picture and verified. So why is this showing 2 walls and 10%?
duneslider
Riverton, Utah
At the day job we have seen an increase in the need to print things, I had been doing it at home. Talked management into buying one, since it wasn't on our dime...we ordered a Bambu H2D.
It is huge, I didn't realize how large it would be. It is also very quiet and very fancy compared to my P1S
Old tool guy
Next question. What is causing the voids on the corners? What test should i run to determine which settings to asjust? And going back to the previous question a little, i selected 3d honeycomb infill but it printed gyroid. Why?
duneslider
Riverton, Utah
You may want to hold off. The H3C might be coming soon.
https://www.reddit.com/r/BambuLab/comments/1wemnus
I am sure an H3 would be an upgrade but honestly, the H2 is pretty fancy. Maybe if the H3 is dropping the prices will come down on the H2.
I wouldn't mind something with 2 print nozzles though, this thing does two color pretty fast compared to my P1S. I don't know that I could personally ever justify a H2 though. The X2D is looking tempting though.
ER70S-2
Yeah, I have an H2D and I am most definitely not going to upgrade to the H3D no matter what its specs are. I only do functional prints and have not been limited by the H2D's specs yet.
Old tool guy
On the voids … that’s what happens when you install a new 0.6 nozzle and fail to update the printer via the on-board control screen. No matter how many times you select 0.6 on the slicer … it doesn’t take.
Still curious why the infill pattern didn’t change.
LeonardY
Southern California
Thinking of getting a printer to make some small parts for the bikes that are unobtanium, and some jigs for rebuilding speakers. I'm sure there are other things in the future that could justify the expense, and space.
I use my all the time for that sort of stuff. I just made a couple of spacers for Blink camera mounts. I could have cut them out of wood but a quick model and 30 minutes of print time and I was done.
WildBill
PNW
I just received my pre-ordered Flashforge Creator 5 Pro. Crazy fast with four separate hotends/heads, 6 second material/color switching, ability to print multiple materials into one object, and the ability to mix colors to make new ones. Can use a different material for support so no more support sticking issues, and makes for really smooth support removal areas. Zero poop pile. Full heated chamber and filtration system. About $850. Super excited, but probably can't touch it for a couple weeks as I'm knee deep in a big solar power install.
burger
Chester County PA
I think that’s where it comes in most handy. Not things you planned to print but as a solution. I had to bleed the brakes on my mountain bike. I bought the Shimano kit for my Shimano brakes and frustratingly it didn’t come with a stop block that was the right width. So I printed my own. I measured my gap and the dimensions of the stops in the kit. In about 20 minutes total I had the part measured, modeled, and printed.
gte718p
It is a function of pressure advance. Pressure advance increases or decreases the flow as the head accelarates or slows down. Its part of the printer being smart. It needs to know the nozzle size to properly calibrate flow. It really should take it from the meta data in the print file, but it doesn't.
Infill is entirely a function of the slicer. It is part of the path that the printer recieves. I'm guessing, going to have to go with user error. Did you reslice after changing the pattern?
Beelzeboss
Sydney
I just finished printing a Lab Rax 10" mini server rack.
The rack design is from Maker World, as well as the Multi Board side panels and the rack mount for the NBN HFC modem, but I designed the 2U mount for the Mini PC, 2xRaspberry Pi's, the 1U for the PoE switch, and the Multi Board mounted ethernet cable comb.
It's definitely the most complex thing I've printed but it was relatively painless, no print issues or design problems, it just worked.
gte718p
I'm assuming you are using Bambu Slicer. If you saved the project file, it would be interesting to go back and look at the layers. If you transferred the file manually, there are several program to reconstruct the print from the path.
Firebrick43
West central Indiana
Is there something that keeps you from bleeding brakes with the pads and wheel installed on the bike?
burger
Chester County PA
The caliper needs to dangle down and be the lowest spot in the system with the bleeder facing up. You could probably rig the pads/brake disc to do this, but the spacer makes it an easy job. If I didn't have the 3d printer I would have cut a scrap of wood.
Park Tools video on YouTube
Firebrick43
Thanks for the explanation. I have never messed with hydraulic bicycle brakes. They were starting to come out when I was an avid cyclist 20-25 years ago but not the norm
ER70S-2
Off topic, but I just needed to bleed my brakes and watched a half dozen videos. Most included ridiculous steps (including the official Shimano instructions) that made no sense. I then found this procedure that didn't include any nonsense and worked great.
duneslider
Riverton, Utah
Obviously, easy to design this yourself but there are already dozens of these already modeled in bambu's library and every other repository on the internet. I have printed a bunch of them. There are also some made for servicing the 4 piston brakes that let you just push out one piston at a time to clean them.
