fourjeepin
Atlanta, GA
Vevor 5-drawer drill bit / tap cabinet $46.82
Build quality is pretty comparable to new Huot.
Huot has dimples on top to facilitate stacking.
Vevor doesn't, but a non-skid pad does the job.
Vevor is about 1/4" wider/deeper so it sorta stacks with Huot.
Vevor has ball bearing drawer slides, Huot doesn't.
Vevor partitions are full depth, welded steel, immovable.
Huot partitions are plastic, removable (with effort), partial depth with bulk storage behind.
https://www.amazon.com/dp/B09987LKFN?tag=atomicindus08-20
These are great. I wanted one of the Huots for years, then discovered the Vevor and couldn't pass it up for the price. I recently made inserts for mine (see the 3d print thread) as the square bottoms making fishing bits out of the edges difficult.
xjfish
T45
Put one in my cart to check the price...and was deleted by amazon 30 seconds later....sold out.
There's "no coupon" because it was only for when amazon selling them, and it went away the moment they sold out AFAIK.
rockbaron1
I find there is a metric equivalent for most common SAE sizes (external, not hex), but not the reverse. I believe I read this is because the 1mm gaps in metric sizing are within the tolerance of SAE size jumps. You can see on the chart below SAE is covered, but common metric like 9mm, 12mm, 15mm, 17mm and 18mm are not covered by SAE. So if I don't know for sure if something is SAE or Metric, I grab the metric set. But I prefer to use SAE when I know the item is SAE (electrical as several people pointed out). But my SAE tools no longer reside in the primary tool chest. The same way JIS drivers work well on Phillips but the reverse isn't true.
I kind of view SAE like I view flathead screws in modern equipment: it exists, I just don't know why.
I find that 11/16 and 17mm are usually interchangeable
Madjik Man
I bought Gearwrench brand and I've been happy with them the handful of times I've used them.
I found a completely unused Kimball Midwest set at the pawn shop years ago. Never heard of them but they’re Made in USA. Only used one once so far and it did the job well.
wire
Available for preorder, release date Oct 1
  • INCLUDES: VERSASTACK Case 3/8 in. Ratchet 3/8 in. Drive Extension Bar 3 in. 1/4 in. Dr. Mag Nut Driver 11-Piece Bit Set 3/8 in. Dr. 6PT Standard Socket 10mm, 12mm, 13mm, 14mm, 15mm, 16mm 3/8 in. Dr. 6PT Standard Socket 1/4 in, 5/16 in, 3/8 in, 7/16 in, 1/2 in, 9/16 in Extra 10MM Sockets (2) Bottle Opener Tape Measure Key Chain Magnetic Pick-Up Tool Stubby Slotted Screwdriver
12 Days of CRAFTSMAN Advent Calendar, Limited Edition Gift Box CMMT12426A
wire
Here's whats inside
NightSky
Southwest OH
12 Days? Is this some of that Shrink-flation I've heard about?
Cruzan80
Denver, CO
You never heard of the 12 Days of Christmas? Not a countdown Dec1-25, but rather Dec25-Jan5.
Thanks for the pics, trying to figure it out via description was a pain. Didn't see the CM playing cards listed, not sure if they are "trading cards" or 2-Ace.
NightSky
Southwest OH
Surely, but ISO/ANSI standard Advent Calendar consists of 25 days. They harmonized on that.
bryson
Utah
I ordered the grease gun and got a 27" monitor instead that sells for $99. The return will be interesting.
The good news it is still on sale. Cant wait to see what I get this time!
I once ordered a roll of masking paper and was shipped a shower head instead. Amazon let me keep the shower head and also shipped me the proper masking paper. I ended up installing the shower head and liked it so much that I ordered a second one (this time on purpose) for another shower.:LOL:
