I wanted to buy but the wife says NO
I bought a Matco floor jack 22 years ago and it has seen lots of use and has never failed me, I have never had to replace any seals or anything. Of course it was made in America back then like most things were.
Thanks for the post. Im in the market for a new jack an may consider this one now...
Prob. Been asked but cant search on my phone.. are these rebuildable?
Theres no doubt in my mind the seals can be sourced thru 1 outlet or another, There WONT be a Rebuild kit available as it will have to be pieced together....
Picked mine up Monday. So far its been great! used it to take the wheels off my Audi A4 to give them a good cleaning.
Gotta get some stands now....
Hello folks,
Curious to find out if everyone who bought the Costco floor jacks are still happy with them...
Any problems?
Would you buy another one?
Would you recommend one?
Thanks in advance!
Hey guys im in the market for a new floor jack an this one caugh my attention. Does anyone know if any of the stores around Columbus Ohio have them in stock?
Cuz I searched costcos website and nothing is poping up. So I take it that its an in store only thing.
THANKS
Sean Scott
THANKS
Sean Scott
Can someone who already owns this jack let me know if this cross beam adapter is compatable? The pin in the adapter is 1 1/8" diameter. http://stores.toolzunlimited.com/Items/LD-4002?CAWELAID=550045017
I have to use the adaptor to properly lift a Corvette.
Thanks, Rich
I have to elevate the back end (2000 C5) 2" to get my current jack and cross beam under the rear end. I too drive up on two 2" X 10" pieces. Although I've done it, the book (C5) says don't lift the rear with the jack directly under the differential. They want the weight distributed across the aluminum sub-frame. I like the look of the Arcan jack, but if the cross beam won't drop into the hole (after removing the original pad) it won't work for me. I'll just keep the 2 ton jack I'm currently using.Why do you "need" that to lift your corvette? What year corvette? Ive got a 94 and a 02 FRC and with that jack their is only 2" (max) between the jack pad and jacking locations of the vette. My 02 is lowered and I have to drive up on 2x10's before the jack and the billet jacking puck will fit under.
It would be very hard to get something like that in your link under a vette. C4 & C5 anyway.
I have to elevate the back end (2000 C5) 2" to get my current jack and cross beam under the rear end. I too drive up on two 2" X 10" pieces. The book (C5) says don't lift the rear with the jack directly under the differential. They want the weight distributed across the aluminum sub-frame. I like the look of the Arcan jack, but if the cross beam won't drop into the hole (after removing the original pad) it won't work for me. I'll just keep the 2 ton jack I'm currently using.
Does the pad lift out? If so how large is the hole it drops into?
Thanks, Rich
Thanks a bunch! Costco is 50 miles round trip for me. I don't think that jack will work for me as much as I'd like it to! The jack I currently use is a two ton and the pad lifts out leaving a 1 1/4" hole so my cross beam adaptor drops right in. I'd hate to buy a new jack and start modifying it.
Thanks again! Rich
The wife bought me aluminum racing jack 3 yrs. ago, but I certainly don't trust it. I like the Costco jack and they have 9 in stock for around $90 bucks. Maybe I'll buy it and modify the beam.
