american lockpicker
Oooooooooooh... now I see.... cool! I wonder what the POO is on that.
Good comment.
thanks monte! you also reminded me I "need" a wera bitratchet...
Also good to see wera promoted Ralf Joesch!![]()
Also was any of the dewalts there made in Germany? I've been looking locally and couldn't find a German Dewalt XRP like Moose has.
Wera had that new ratcheting screwdriver at SEMA a couple of weeks ago. I like the push button at the handle base to expose the bit storage and the overall feel and balance. However, I wished the screwdriver would accept differen blade lengths instaed of just the one length.![]()
Do you have a pic of your router ?
Cantause,
Is this file handle made in Italy? Your Vallorbe one is identical to the older Nicholson file handles which, quite surprisingly, are made in Italy.
BTW, nice purchases.![]()
@Cantause
Where did you buy the files ???
What does the "Warning" say on the clamps ???? Warning: Don´t use the clamps ??
No, but you're close, it's
Haaa german quality...
) and asked for a few more floor jack's prices Yes you need it !
Ralf who ???![]()
Hi! I can't be 100% sure but I think it's made in Switzerland, it has "Swiss" on the handle but no "made in...". I know that watch-maker can only put "Swiss" on their products when they're made in Switzerland, or at least when a specified minimum of manufacturing process are done there. I don't know if it's true with any other products, maybe a swiss member could help us, or GeorgeK could ask to his nephew who works for Vallorbe???![]()
Hi Servito,
As others have mentioned, great avatar.It got me wondering if it was Knipex's crest from decades ago.
If you haven't read it yet, here's one of my earliest posts dedicated to the Kompakt driver: http://www.garagejournal.com/forum/showthread.php?t=28001&highlight=kompakt It should give you a better idea of the quality.
Over the years, I've used it on several occassions to make adjustments on household hardware and assembling some furniture. The bayonet, in full extension does have some play, but it's at a level that doesn't annoy me or hinder me from completing the job at hand. I'm sure Monte, who has the Wiha System 6 ....or 4? can chime in as well. He actually measured the amount of play on that, and IIRC, it had minimal play.
The composite material is robust enough; I've never been worried about the strength of the gripping area. The only thing that annoyed me was when, some time earlier this year, I hit the "PRESS" button and the thing opened up only half way. I had to manually assist it to open all the way. I did spray some dry PTFE spray to reduce friction between the peices and it's since been working fine.
The SEK is made by the same company that makes the Wera version. I don't have the receipt in front of me, but I think it was around $20 with that red case and a super low-profile PH#2 bit. I don't have a picture of it, but it's even shallower than the Anex PH#2 pictured below. FWIW, I don't use the Wera BDC (diamond coated) bits anymore, unless I know it's going to be a stuck fastener--the coating wears off with not much use on it.
I've also used this guy for dis/assembly of some furniture and a couple times in an automotive setting, and it was fine (low torque usesage). I'm very happy with it.
, I would just need some pictures from older Knipex tools. Thanks for my avatar compliment.Isn´t "Taurus" from Aldi ???? Found some posts about Taurus at Aldi......
i thought you might have some Virutex tools![]()
Surprisingly there are only 2 Virutex tools on ebay.es !?? Not very common in Espana ?
I didn't know that the diamond coating wore off easily, I have six of those bits (new), but as I'm plenty of other bits, I feel I'll keep them new.
And for the ratchet, I have just ordered a couple like yours but from Gedore; hope it will handle better than Wera counterpart.
It's good to see a stubby driver w/ a proper handle... good stuff!
Festool.
I just bought this Bosch, made in the Swiss-land! I was considering the metabo counterpart; perhaps the latter is not German made? The Bosch sure grinds smooth.
Kress makes some interesting die grinders, but it doesn't seem that the brand is sold in the USA. Does anyone have a source for them?
Monte,
Are those Wera shanks 6mm? or 1/4"?
A while back in time , I sold a lot of Wera and USAG. They were 6mm hex shanks of course and wouldn't swap/fit our 6.3mm common stuff.
I liked it better anyway thoughStill have some.
Rob
new screwdrivers :O
Rebadged Meister -> Sora (now i got some in blue and red) and Technocraft-> Athlet. Cheap eBay stuff that smells like smoke of one million cigarettes ...
Not yet, but I'll take some pics next week-end! Actually it has its place in this thread, it's made in Belgium! Probably my only belgian tool...
I got them from Axeminster in the UK, it was the only place in europe where they were available online and at affordable price (around 6-7€ for 250mm)
Here is the direct link to their hand files
If you plan to buy some files there, I don't recommend you to buy Vallorbe's handles, they're quite expensive (6,67€) and have nothing special except that you screw the file in it. I bought 3 of them just to try, they're quite small (and I don't have big hands). I prefer the Axeminster's wood handles (125mm are perfect, 150mm are too big for me), files are well tightened and they're cheap (0,8€), if I had known I would have bought more files and only wood handles...
Axeminster's plastic/rubber handles with adaptors are nice too...
Concerning the clamps:
"Warning, using this clamp for clamping something will void warranty"Haaa german quality...
Seriously, it warns you about the injury risks when improperly used, such as pulling, lifting,...
Btw I ordered a Rodac oil pan this morning, an 8 liters models, 18€+vat (I'll take the 30 liters for the first oil change of my Ferari) and asked for a few more floor jack's prices
Would someone know some quality (if possible european) brands for middle size electric generators?
My brother needs 2 generators around 7,5 kva, I did some researchs but it seems that it's between small transportable units and large diesel generators. It's an auxiliary power supply for his servers in case of long blackout, so they must have an electric starter, they will have to start without assistance (they will be stored in a warm room though).
Thanks!
Maybe Monte will have some insight;
I was at Aldis on saturday picking up various junk for upcoming holiday, saw some combo wrench sets for like $5.99, "ToolCraft" if I remember correctly, no metrics so I didn't get them, but had the GS and a few other German safety stamps on the packaging, made in India - looked ALOT like Stahlwille "Stronger than any Bolt" combos... thoughts? I'll try to stop by and get a pick this week... Oh, and they had a three plier set w/ a monkey wrench that looks like a Kukko/Matador/VBW/etc..., a adj. channel plier that looks exactly like a Knipex gator, and a pair of needle nose that look like my bahcos... all made in tiawan... intersting stuff - the channel plier's similarity to Knipex was striking. The casting was down pat, I mean the only difference was the blue handle vs. red and instead of "Germany" cast into the neck it had "Taiwan"...
It was a joke, some guy was promoted to be overseas sales vp at wera, read it in the newsletter you sent me a link of when I asked about the knipex/were/Stabila joint venture... nevermind.![]()
Oh, one more: I assume KSTools are all made in Taiwan or where ever else, just not germany, right?
AND: http://www.cens.com/cens/html/en/news/news_inner_34390.html - pretty interesting report on Taiwan Tool Co's at the 2010 Automechanika Frankfurt Show.
I think you might not be right about Aldi and Taurus, it is not that I know that for sure, but after looking at the "Taurus Aldi" logo and the logo from the taurus which I mean (www.taurus.es), they don't seem the same; it may just be another brand.
I'm sad to disappoint you, but haven't got any Virutex tool, and don't know wether it is very common among wood professionals.
A couple things I got recently:
Some pics would be interesting
I´m not a fan of knock-offs..... I personally also don´t support these companies.... Quality is most often also not the same than the originator.
I also had these tools once, prices are good like 2.99 or 3.99 for pliers but they´re too disappointing after you have used NWS pliers for example, there is still someone who can do it better... at a higher price of course.
I agree.... I just thought it interesting that the packaging was in german/english, had a few german safety stamps on them, etc... I was going to pick them up for the novelty alone... i too don't subscribe to the cheap tool newsletter, unless in an emergency and no other options exist, or the product is the same sans the "name"...
Those Pferd handles are nice looking.
There's also the Bahco handles. I have a few of them and they're great; pretty cheap, too. Made in Portugal.
Will history will repeat itself?![]()
I think it's a beautiful design.
yes ! Pretty comfy too !
btw. Bahco: They have a new file handle design
For anyone interested in the Screw Gripper from Wera that Monte posted above, the part # is 05018501002. My last purchase from Chads (probably my last one from there) included that item. Cool little gizmo. Haven't had the need for it yet, but just had to have it.![]()
Comfy for sure, and it doesn't stink either.![]()
I think it'll be a while before I start seeing the new handles on store shelves here.
I would've bought that 4-in-1, dog-bone-like wrench, too. I cool peice of tool history. hrmm, Monte-X![]()
I, once, was about to make a purchase there, but after reading from other people problems, and the shipping costs, decided to opt for another alternative.
By the way, that Wera holder seems pretty expensive for a piece of plastic (or this is what it seems to me to be made of). Between 8-10€ is too much.
Why do you want to buy euro stuff in the US ??
the plastic holder should be around 3.80€ + sales tax
The 2 piece (red) VDE set 7.60€ + tax (one for small diameter blades (4,5-6mm) the other for larger blades (6,5-8mm).
That Bahco set just has to have been made in Chinermany or Swedewan.
I wanted to buy there because I was looking for some Knipex Cobra pliers (the smaller ones), and it was there, where it seemed to me, the best price was.
The best price, of course, in a web in English; I'm learning German, but at this moment it is still a bit difficult to me to read a web page all in German.
Weil ich eine Wasserpumpzange von Knipex (die kleinteste Cobra) gesucht hatte. Und war da, wo ich den besten Preis gefunden hatte.
Trotzdem war der beste Preis an deutschen Webs; aber es ist für mich, noch, sehr schwierig eien Webseite auf Deutsch zu lesen.
The VDE is almost 11€ in Amazon.de, a bit too much, I think.
Good translating program !!!![]()
just look at ebay.de
http://shop.ebay.de/i.html?_nkw=kni...HNEIDER&_osacat=0&_trksid=p3286.c0.m270.l1313
or here
http://www.wuppertools.de/KNIPEX-Zangen/Wasserpumpenzangen-Rohrzangen:::295_306.html
cheaper than to import from the US
or ask them if they can order the 125mm (?) version for you
http://www.ferrshop.es/index.php?op...ver&marca=400000383&fam=&subf=&txt=&indice=20
(no translation program at all has been used
Taiwan you mean ?![]()
It was on my list about 2 months back until I found out it was Taiwan. It looked like a nice set but could not bring myself to buy it. The Bacho 3/4 set is also a nice looking set but also Taiwanese made.
I have Kobalt(lowe's) box cutter that is exactly the same(blue instead of orange), the weak part seems to be the rivets on the belt clip.
That bessey knife is interesting! I have a Sears Craftsman version; they sold for awhile, just like it! I wonder who the OEM is?
only one belgian tool ??? Time to change that![]()
www.polet.be
i would buy these handles anyway:
from "Pferd" (Ruggeberg). Also available from "Hase" files and "Elora" in black/yellow. (and cheap too € 1.49 to 2.14 net)
Whats about the store you mentioned ?
Here's something a bit different: a typical Japanese style garden shear that i've owned for some time. I've used it for its intended environment, but I've also noticed that it cuts rubber hoses cleanly, so I also keep one in the toolbox.
Hmmmmmm, thank you for the compliment, now I'm more "selbstwebußt"; if you are able to understand what I have written in German, it means I'm not doing so bad![]()
Thank you for the links, but I finally got it here in Barcelona; I found it in two stores, in one it was about 19€ while in the other about 27€ (what a difference).
By the way, I took the plunge and made some tool shopping through Amazon.de; in the SMDV shop (where I found the best prices) bought some Knipex pliers and Wera Rapidaptor holder; and through e-bay, some NWS pliers. There is nothing that hasn't been posted here (pictures), but I will post them here anyway.
Yes please post them pics !!! Thats what this thread is about Monte or anybody else (of course), do you know how good those pliers are?
Because I wanted to get a pair of those.
I had never heard of Polet before... Mostly garden tools so I will tell my mother! But with the political situation we have for the moment in Belgium, she doesn't want to spend her money in flamish tools (I'm from the south part of Belgium, wallonia)![]()
These files handles are nice, is there a place where they can be ordered online? I like wood handles but I'd prefer something with more "shape", these seem to fit!
Concerning the floor jack I'm a bit lost... The store I talked about which sell original Mega's has prices higher than all the prices I've seen before
So now I consider 2 options, buy the Mega T2X (48mm) from UK for 400€ delivered or buy the Facom T2 (75mm) from my local Facom dealer for 360€.
Facom's is proportionaly more expensive but it has been a long time since I've done a "real" tool purchase from my local dealer.
They're always very nice and helpful when I ask for small annoying parts and bits, I would be "happy" to give them my money, even if it's not the cheapest price I can find... Another nice thing is that I buy from them since I'm 16 and they always considered me as a real customer, it's something I appreciate!
T2 is a bit more common but I don't know if the I really need an extra-low jack like the T2X, plus I don't like the idea to spend 125€ to ship a 275€ jack from the UK to Belgium, especially as I go quite often there and could pick it myself...
I think I'll go for the Facom T2 (I like the gray colour) and buy an Abco T2X next time I go to the UK!
Jack's are like any other tools right, you never have too many of them...![]()
A bit off topic but as I've seen that the forges of Saint Juery restarted production after some inactivity time, it made me think about Sambre & Meuse vises...
I heard some time ago that after being bought by Dolex, they stopped the production of *** vises as Dolex already had their own vises, would someone know if production started again?
Here are some pictures from my electric drill
And this is close-up (macro) of some Wera Diamond bits
And this is an alternative for what Monte posted, for holding screws, but this one is for power tools.
yeah the Wera bit holder with "Ringmagnet" is nice ! Maybe the "Weihnachtsmann" brings me one ! (If the chimney is not clogged)
why the last one ?
(This goes to Servito as well)
I wish not to speak about it here.It'll be to off topic for this thread
Only thing I'll say is that there were several email communications in order to sort out the order. Overall, it was just a hassle.
Couldn´t pass it up with that name
! And much better than the new fancy 1000-in-1 dogbone ratcheting toys
No kidding! Have you seen the pics Stuey posted over at Toolguyd on the newest Kobalt Multi Drive Wrench? : http://toolguyd.com/2010/11/how-well-does-the-kobalt-multi-drive-wrench-fit-hex-fasteners/
It looks like it's a locking type too, similar looking to the Hi-Five locking flex.
I agree with you, very pretty, simple design, might make a nice mother's day present![]()
