Here are some more "new" old photographs from Nov, 2005 and I'll show contrasting current pictures of the same areas where possible.
This is in the north room addition looking toward the front of the shop. The bright spot in the background is the front door open, a work bench to the left. If you notice it's sunny outside, the door has light streaming in and looking to the left you can see bright sun through the window above the bench. Now notice how very dark it is inside the shop and the poor lighting. That's a big reason why I couldn't get more interior pictures. I was using a 35 mm camera and it just wasn't up to the task of lighting a large, dark space. My daughter was using a digital camera for all these series of photographs and most of them worked out well enough. You can see the narrow pathway through the shop that I've talked so much about. The vast majority of the interior space was used for storage of "material".
Pretty close to the same vantage point. Use the window to orient yourself, it's the same one as above.
A slightly different view of the same area, just panned slightly left. This gives you as better view of the main workbench in the shop. Look toward the far end of the bench and you'll note the old vice. These benches were just hopeless, that's why I replaced them all. Oil soaked and a true fire hazard among other deficiencies. That's a valve grinding machine I believe on the near end of the bench below the head gasket. It was taken by one of the sons.
Same perspective. I'd say the main contributing factor to making the shop a proper place to work, besides cleaning it out, was better lighting. Note in the 2005 pictures the area anywhere above the top of the window level is a black void. There was no ceiling, it was just open all the way to the bottom of the roof. All the interior lumber has soaked up welding smoke and from earlier times, forge/blacksmithing smoke which darken all the interior surfaces. Installing a ceiling and using highly light reflective material on all the interior surfaces with ample, good quality light fixtures made a dramatic difference as seen.
This picture is just in case you wanted a close of the bench. I just cannot work like this, can't do it, not happening!!
If you were standing at that bench in the previous picture and turned around this what you saw. To the right, the bright strip is sunlight reflecting off the right side of the doorway into his then, coal room which is now my 1/2 bathroom. Foreground the key making machine and behind it the only heat source in the shop an old furnace which just heated the area right around it.....after a fashion. In reality it just gave the illusion of heat. I have to admit it did take the chill out of the air but it was still cold working in there in the dead of winter. It didn't help that there were air leaks everywhere either. That's the furnace that almost caused the building to burn to the ground in the late '70's. Left is the masonry chimney that served the furnace and forge.
I think this is better use of that space. The doorway is the best way to compare them, this picture is pretty close to the exact same spot.
This picture of the fabrication room was taken a few weeks later than all the ones we've seen up to now in this particular post. I include it to help you orient in the below picture. Note the aluminum ladder hanging on the wall. The bench top in this picture has been cleaned up a little, but is the next picture...
....it hasn't been touched. This is deep into the fab room. There is the aluminum ladder hanging on the wall in the background. I haven't done any cleaning when this was taken. Best to notice the vice in the right foreground. It's bolted to the cast iron bench which itself is piled high with, ah, er, mmmmm......"stuff".
You can also see brazing rod (it's coated with white flux) piled front left. At one time the cast iron bench is where all the brazing work was accomplished.
This should help out. Same space, same cast iron bench, same vice...... different work space philosophy.
That of course is Mr.Johnson's red Lincoln arc welder on the right. The welding bench itself is hidden by more.... well, OK for the lack of a more accurate term, "junk"- there, I said it! The white object above the welder is a 5 gallon plastic jug. Attached to the jug is a 4" round pipe which was used as his exhaust system. The wide side of the jug was cut out and connected by the pipe to an exhaust fan mounted on the exterior wall. There was a flexible joint in the pipe which allowed it to be positioned right over the work area.
His welder is still nestled in it's same spot. If you look closely you'll see an old black hose installed on the top handle. That's an old universal flexible radiator hose that he used to insulate the metal handle of the welder.
In this photograph from about 1968, look closely at his welder. See that same radiator hose is there, even back then, 42 years ago. I don't know when it was first installed, but it's been there as long as I can remember. Once I cosmetically restore his welder I'll leave that hose in place. It's one of those touch stones that I cherish so much. To me that is part of the welder, part of the shop and part of the heritage found out there. Those little things are important to me.
Thomas
