The Harbor Freight PASS/FAIL Thread...
thedrivel
Louisville, KY
Has anyone tried one of the Cen-Tech levels?
http://www.harborfreight.com/72-inch-box-frame-level-93014.html
KU_MechE
Vern X-100
Raleigh, NC
I never had a problem with the one i have here also, i have a new one i just bought ( could not find my old one ) and they both worked great
RE: Rivet Gun
Well, it's still a FAIL in my book. I removed the broken stud from the tool and tried it one more time. It's really good at two things: failing and adding weight to the scrap pile.
:D
mikebramel
WI
13 drawer red tool box update
The lock fell off today. pretty embarassing. good thing i dont need it
hoffmand
Austin, TX
Whatever level you buy, make sure you check it in the store first. Even high dollar levels can get knocked around in shipping and unpacking. Just find a reasonably flat surface and note where the bubble is. Turn it 180 deg. (like a record) and the bubble should be in the same spot. If not, put it back and try another one.
sanddrag
Black & Orange Bar Clamp/Spreader
FAIL - Used about half a dozen times. The other night, it was about 40F in the shop, tightened it, and the end snapped right off.
bmxr4life87
Bixby Oklahoma
#2745 oversize low profile creeper PASS
got on sale with coupon and couldnt ask for anything more i weigh about 275 and am kinda broad and it fits me comfortably we have a very rough floor at work with dips and uneven surfaces and normal hard plastic creeper wheels just dont last more than 6 months max plus most creepers are too short leaving my *** hanging off if i slide down at all well this new creeper got nicknamed "the sled" when i carried it in it COMFORTABLY fits me and with my head on the headrest will stop a few inches away from my knees (im 6'1) ive been using it about a month now and it still rolls like a dream the wheels are semi soft rubber they still look new the headrest can be unbolted and recovered/replaced easily there just isnt anything to not love about this creeper, it will stand up on end so it doesnt have to be leaned against a toolbox, its very comparable to a lisle jeepers creeper or napa creeper that goes for $80+ (have both at the shop)
3 at 8
N. E. Ohio
RAYJAY
UNION DALE PA
motoguy
MO
Tried the bottom one, second or third time I removed a wrench, it broke. The plastic was just too stiff and brittle. Replaced it with Ernst, and I am pleased that I did.
I second this. I purchased a couple of the units on the bottom, and wish I hadn't. Hard to get the wrenches in / out, and mine also broke. The plastic seems brittle.
motoguy
MO
Tried out my newly purchased 1/2" deep well SAE socket set (purchased on clearance for ~$12), as well as the wobble extension set (item # 31203)
http://www.harborfreight.com/9-piece-wobble-extension-set-31203.html
I'm mildly disappointed with both. The wobble set has a very poor, cheap looking finish, but I'm ok with that (as long as they work). I used them a few times tonight, with both 3/8 and 1/2 impacts. The retention slots in the extensions are -worthless-. The extensions I used were literally falling off the end of the gun. I replaced the retention o-ring / steel ring on my 3/8 gun last week. It works WELL. Maybe too well, as I've had to pry off a socket or two (Craftsman). These extensions, however, just fall off the gun. I HATE it when sockets / extensions fall off my ratchet / impact gun.
They did give good wobble action, and the 1/2 held up to use with my SO MG725, so those are positive points.
Regarding the socket set, again, more disappointment. Unlike most deepwell sockets that I've used / owned, these impact sockets do not maintain the "nut / hex profile" for the full length. Instead, at a point slightly deeper than "regular" sockets, these sockets close up and go solid, (with a hole drilled through). I know it's a bad description, but it's 7:10am, and I got home at 5am from a 12 hour shift. LOL
The point is, if you have a nut with a bolt protruding, the bolt will "bottom out" on the socket, much the same way it would on a "regular" depth socket. And, unfortunately, "deep well" or not, these sockets will let a bolt bottom out at about the same depth as a regular socket. They work ok for extensions, but they just don't have enough depth to work well on nuts with protruding bolts.
I haven't decided if I'm going to take them both back, or see if workarounds can be achieved.
davidj
Georgia
Does anyone have any experience with the 9-1/2 wire crimping tool Item # 36411 or the 10 inch cable cutter Item # 40507 I hate my multi crimp and strip tool and want some crimpers and could use some cutters to cut the thick stuff like battery cables or whatever.
hedjhawg
Green Bay, WI
I have two of the 36411, and love it (I mean... them). Can't beat them for the price!
I have a MAC 10" cable cutter, so not much insight on the HF...
SCscoutguy
South Carolina
I have had the 36411 for probably 5+ years and it has gotten a ton of use and I have never had a problem with it. When I bought it 5 years ago it was closer to $20 so at that price I might just go and pick up another one!
sanddrag
I have a 40507 Cable Cutter (but with blue handles). I've only used it a few times, but it's been great.
mtkst19
blitzburgh pa
anyone pick up the extended reach cut off tool? if im not mistaken, this is a fairly new tool offering from hf. seen it advertised in November, but was never online or stores didn't have them. Now they are online--
http://www.harborfreight.com/3-extended-reach-air-cutoff-tool-67996.html
item number 67996
on sale this week for 49.99
that's an easy $150 off tool truck versions. probably will pick one up to give it a try--yet be nice if someone else has already.
southernfriedcj
Athens, GA
Pass: 800 lb capacity transmission jack
http://www.harborfreight.com/800-lb-capacity-transmission-jack-3185.html
It retails for $149.99. It was on sale for $129.99. With my 20% off coupon it cost me $103.99.
The cashier stated that the 20% off might not fly. I stated that it was not a floor jack (no coupons can be used on floor jacks), but a ****** jack. He tried to scan it and it worked.
I used it on the 300lb ****** in my F250.
Worked very well. I figure I got my money's worth on the one job. I was surprised that the big joints in my driveway didn't stop the small casters from rolling.
Simplespeed
Im sure its been mentioned but im not searching over 100 pages and the thread search seems to **** so, can someone link me to a review for the us general inner tie rod set? Thanks.
Simplespeed
Couldnt get it to work with words but your right, the item number worked. Only one review in this giant thread. Doesnt help much. Guess ill use it a while and review it.
SCscoutguy
South Carolina
I have the 2k lb version of that jack and man I love that thing. I have probably taken out 10+ transmission/transfer case combo's with it and haven't had a single problem with it.
http://www.harborfreight.com/2000-lb-low-profile-transmission-jack-4075.html
stricht8
I'm interested in this tool as well. I'll keep checking the stores as I prefer to see HF tools in person before purchasing.
item number 67996
zer0cell
The HF ad I saw showed that the following items I MIGHT be interested in getting would be on sale starting Jan 20th. I did not happen to see these reviewed here yet...
Can anyone provide some feedback on these:
Cost: $1
http://www.harborfreight.com/2-x-4-inch-phillips-screwdriver-94707.html
http://www.harborfreight.com/4-piece-pick-and-hook-set-66836.html
Cost: $2
http://www.harborfreight.com/25-ft-x-1-inch-tape-measure-47737.html
Yeah, they won't be much money and its a small risk but I'm a cheap skate when it comes to HF :bounce:
NWphotog
Cost: $1
Cost: $2
The screwdriver is a home run hit. The pick set does fine as you would expect. I have no experience with the tape measure.
Goobzilla
Wellington, CO
Another PASS vote for Metric Deepwell Impacts 34683. Plus they are on clearance for $11.27 right now. Must be transitioning over to the Pittsburgh Pro packaging.
jeffk14
GA
bmrisko
Huntsville, AL
I have that Pittsburgh Pro set and while they ain't Snap On or Matco (they feel a little lightweight), they've been good screwdrivers. At $5.99 for the set, they're certainly much better than you'd expect for under $1 each.:thumbup:
Agreed...I keep these inside as my "house" set and they have impressed me so far. :thumbup:
davidj
Georgia
Thanks guys, I know what im buying on my next HF run.
