Arts & Crafts Garage
AgDieseler
The Willomet Garage
Howdy!
I wish I would have discovered the Garage Journal earlier in my build project. I've found lots of valuable information so far, especially the Made in USA threads. Here’s my garage.
Our Arts & Crafts Bungalow was built in 1917 and resides in a historic district in Dallas, TX, so when it came time to build our garage there were lots of rules to study. The short details are this: heavy duty slab on grade, 6” wood frame, wood siding – pine 117 and cedar bevel – and traditional Arts and Crafts trim, and custom carriage style folding doors. I’ve acted as my own GC, contracting out the foundation work and roof install. My girlfriend and I have completed the balance with significant help from our friends and family. Enjoy the pictures, and watch the seasons change from summer to fall to winter.
We hated doing it, but we had to sacrifice our 42 year-old paper shell pecan tree to make room for the foundation. I’ve kept and split the logs – good for smoking:
The foundation started with excavation of 24” of North Texas black clay, and replaced with select fill “cushion sand”. In our part of Dallas, one doesn’t have to dig more than a couple of feet to find bedrock. While the beams were being cut, the trencher was bucking limestone bedrock.
Beams are 12” wide and 36” deep, with spacing at 8’ on each axis. #6 steel for the beams, and #4 for the 5.5” thick slab. The green overspray is termite pre-treatment for the soil.
Concrete was a 3ksi pump mix.
Concrete contractor had a top-notch crew, and was very hands on – not a touch-and-go type that’s not present for form surveys and setback inspections. We kept a lawn sprinkler on the slab for 3 days as it cured.
With the help of about 8 family and friends, the walls went up in one weekend. We had 4 folks return, and the trusses were up the following weekend. In between the walls and trusses, I would lay the Turfstone (Acme brick product) over 12 tons of decomposed granite (DG). DG is a great composite fill. It packs in hard like a flex-base, and is very drainage friendly. We filled it back in with another 9 tons of DG.
After two weeks, the suburban parks on the pad for the first time.
I did hire a roofing contractor to install the decking, felt, flashing, and shingles. As my own GC, I competitively bid all materials separately from any labor, and controlled them separately to avoid contractors from having to pass on a 20%+ markup.
Tyvek, siding, and trim went on fairly quickly. The DeWalt 18V cordless finish nailer, which definitely gets the Most Valuable Tool award for this project.
I didn’t want to give up any vertical space inside the garage. My truck is about 8.5’ tall, and I want to be able to use a lift for a coming hot rod project. Carriage doors would seem like a natural solution, except the turn into the garage is somewhat tight and clearing an open carriage-style door would be tough. Plus, those kinds of doors are expensive.
My solution was to build my own carriage doors that folded over against the side of the garage using three hinges per side. The frames are 2” square steel, and skinned in lap and groove cedar. I’m not quite done with them, yet.
This is where we are right now – primer is done, and paint is well underway. The door trim is coming to a close, and after setting up some bar-locks and getting stain on the doors, we’ll be ready to close out our permit. Next steps involve getting everything inside organized so I can unload the storage unit I rent, and start on wiring and lighting the space. It’s been such a great experience, and we’ve had so much fun that I might be a little sad to finish. But, as I think about it further, I bet this project will be like most of my other projects – I never can leave them alone.
I do look forward to getting back to work on some other projects, and bending tube on my '55 1st series Chevy.
I’m glad to be on the board, and look forward to sharing progress and learning more from everybody else’s builds.
David
ambenz
NW Chicago Suburbs
Very cool garage!
I bet your wondering what you are gonna do with the inside after seeing all the interiors posted here on GJ, huh?
I know I'm wondering!
metal1313
clinton NJ
can you give more details on the doors? i've been thinking about making some for my tiny little garage
993James993
Very nice! Please post more, including the facade of your Arts & Crafts house if you would.
A
AgDieseler
Here are some more details on the doors.
The steel frame has three sections; all hinged using a pair of lift-off style ball hinges. Several 2x4s are integrated into the frame, and provide the mounting surface for the wood cladding. The wood cladding is cedar over a plywood base – lap and groove for the body and 1x for the trim details. Limiting straps (Strapworks.com) were installed to prevent the door from opening too wide and crushing itself. The sections tie together using DE-STA-CO latch clamps from Grainger.
The purpose behind all this: maintain 10’ of vertical space in the garage so a lift is effective on the already 8’ tall suburban.
This is the final door trim pattern. Stain (dark walnut), dead bolts, and a kustom door pull are next.
Looking for a current picture of the house, it occurred to me that I don’t have one. Here’s a quick one of the house during last year’s big snow in Dallas.
Regarding the interior, we’ll insulate the walls with R30 and use 8” pine shiplap to cover it all. I may leave open one or two of the spaces between the studs – they’ve proved to be handy spots to store 10’ sticks of DOM.
David
993James993
It's looking great David! You did a fantastic job on those doors. Your house is beautiful.
A
AgDieseler
James - thank you for the kind feedback. I've been reading your thread as well, and have found quite a few ideas to borrow.
Quick updates:
Body paint is complete, and we're on to trim. The doors are built and ready for stain. Sherwin Williams has a sale going, and I think we'll probably use the same dark walnut as we did on our house's front door.
I started with the steel frame in late November, and that took a few weekends to get both of them done. The layers of plywood and cedar took most of January since there are so many details to chisel and cope around the hinges and bolts at the edges. I've had my fill of trim work for a while.
I dug up my original design for the doors, and I made several bracing changes to save steel and weight. There's about 350 lbs in steel per door and another 100 lbs in pine and cedar, though you wouldn't know it since those ball hinges are so smooth once they are pumped full of grease.
I'm about to start fabbing the dead bolts for the doors. I figure 3/4" bar stock concealed within tubing and padlocked by Mul-T-Lock's Hockey Puck is a fairly secure locking method. I'll post more pictures of that progress.
David
SullyZX2SR
South MS
Very nice!
I like your Suburban too, what are the details on it? I had an '87 1-ton (former Louisiana DOT truck) that was destroyed by Hurricane Katrina, I've always had a soft spot for that body style.
A
AgDieseler
Sully,
I'm sorry to hear about you losing your truck. Fortunately, GM kept the GM200 platform for close to 20 years, so parts and platforms are everywhere when you want to rebuild.
The suburban is an '85. My dad bought it new in 1985, and it was handed down as my first vehicle. My dad and I have built it over the last 15+ years - one piece at a time. I love my CTS-V, but it will burn to the ground before I ever (or never) get rid of this truck.
- 6.2L diesel, balanced and blueprinted, MHI turbo, big pump and injectors: ~450 lb-ft
- Built 700R4
- Front D60, 4.88, detroit
- Rear 14 Bolt, 4.88, detroit
- BFG 37" MT on H2 wheels
- Terrible repaint done in 2000
- lots of other small details over the years: extended shocks, serpentine conversion....
I've got to get this garage done in time for late March - annual offroad trip to the central Texas granite!
David
SullyZX2SR
South MS
Sully,
- Built 700R4
David
Very cool truck. I saw the Banks sticker, figured you had some goodies on it. I didn't realize your CTS was a V, I'm jealous. I'm trying to talk my wife into getting a V wagon in a few years to replace her Equinox, I think the ice might be melting. :bounce:
I'll get another square body eventually, have some leads put out if they ever decide to get rid of them. One is a '79 dually crew cab in very good shape, the other is an '87 RCSB. They definitely won't be offroaders though.
A
AgDieseler
A few milestones:
- Doors are dead bolted and secured
- Storage unit has been emptied, and all my gear is back
- We passed final inspection, and took down the construction sign
- I started my first truck project in several years
I'm going to take a break before starting work on the interior.
Quite frankly, I thought I knew exactly what I wanted to do on the interior before stumbling across this site. Now, I have several different ideas for organization that were either gleaned directly from or inspired by what I've seen here. Combine that with 8 near-solid months of building and I'm just plain burned-out on garage building for the time being. I'm going to catch my breath until at least May or June.
It's time to spend some time on the truck and get back out on the trail.
David
redlinetoys
Great build pics. Love the extra height and the outside wood, and especially those folding doors. I need something like that if I am going to have a lift in my garage. Super idea.
A
AgDieseler
It's been too long since I updated this thread. A few things have happened in the intervening three years:
  • ran lighting and electrical
  • insulated and walled the interior
  • completed a few projects on the suburban
  • built a workbench
  • traded the Cadillac for a Volt
  • repainted the exterior and doors
  • sold the 55 truck
  • completed a series of projects on the house
  • acquired a 70 Charger
Since this last photo, I've gone through each shelf, box and dirty corner where parts and gear may hide. It's time to shift the shop mentality from one that is under construction to one that hosts the making of things, cars and good times.
David
A
AgDieseler
Had a good evening working on the charger. Caught the right light for a quick photo.
David
HSpencer
South Central US
Just a totally great looking garage in every respect. I am sure you are justly proud of it.
Love the style and the interior finish. The lighting is outstanding as well.
Super Job
Best Regards
Herb Spencer
Bib Overalls
Jonesboro, Arkansas
Good to see you posting again. Looks like you have some neat projects. Why don't you keep this thread open by posting updates on your projects. I'd like to know why you were bending DOM for your 55 1st Series (Chevy?). If you have the pickup that was sold in early 55, the one with the updated chassis and bed with the 54 one piece windshield and clip, your a lucky guy.
NBHD
Chippewa Valley, WI
That looks great, and I realllly like the two-tone wood plank walls. Was that planned, or did you have a small amount of reclaimed wood to use up?
Ripcurl
Ottawa, Ontario
Very nice garage and original! The extent of my creativity ends at paint walls white. Also love those doors that wrap around the side of the garage. Like said before, keep this thread alive with updates, even the smallest thing is worth updating.
A
AgDieseler
It was a lovely '55 first series 6400 (2 ton) flatbed with loads of character. I had prepped the garage to start the project when a friend of mine found a clean, solid, and titled '70 Charger that needed a new owner. I already have the suburban as a running project, and can only take on one non-engined vehicle at a time, so I sold the '55 to fund the charger. It found a good home with someone that needed a solid cab for their '54 3800 restoration.
The walls are a combination of new shiplap, old 105 siding installed face down, and a few east Texas blue pine edge bevel boards. I'm happy with the way it came out, especially since it evolved from a place of frugality. I spent a few months collecting the siding and shiplap from various Craigslisters. As soon as it was clear that I would have different colored boards on the wall, it did become something of an art project.
Recent project:
I needed a workbench. What I had was extra steel tubing, pine trim and lumber. Here's what I came up with:
I'm a tall guy, so working height is 40" - right at my belt buckle. The 2x4 top is glued and screwed and planed about 1/4" so it looks like a butcher block, while the trim board floor rests on a steel ladder frame and easily lifts out. The combined surfaces soaked up nearly 3 quarts of Teak oil. It's heavy, but rolls easily.
Turns out it's also the perfect bar height, so it's handy for hosting friends in the shop.
David
Weizenbier
Selinsgrove, PA
I like those doors, pretty near.
Are those pervious pavers in your driveway to the garage? If so how are they holding up? I thought about using them for a parking area
A
AgDieseler
Yes, those are "turfstone" or "grasscrete" pavers from Featherlite Products (Acme Brick affiliate). They're 15.5"x23.5"x3.5" and weight about 70lbs a piece. My back was a bit stiff after laying the driveway.
We like them very much and they've held up extremely well after 5 years of consistent driveway use. Our base is a compacted decomposed granite, and movement has been minor. We chose them primarily for improved runoff control, and during a rain the granite is able to absorb a great deal of water that would otherwise be headed to the storm sewer.
David
A
AgDieseler
The Willomet shuffle, (noun):
the act of moving or rearranging multiple project vehicles so the current project is close enough to the required tool or electrical outlet.
See also: extension cords and their uses
David
