46 Merc PU Engine overhaul
E
e-tek
Saskatoon, SK
i found one pic of the pumps but still can't find the spacers......find a truck pump and you don't need the adapters....used the merc pumps and you'll need the adapters.....
i had it bassackwards in my earlier post
Thanks again.
Here's another Question: What color where these stock? I was going to go Ford Blue, but am guessing it was a bland green or something!
green.bubbly
Lafayette, LA
Personally, I am interested in that Datsun. My first car was a '71 240Z. I can not tell you much about that Ford but I can tell you how to stop vapor lock on the 240's fuel lines with wood clothes pins.
E
e-tek
Saskatoon, SK
Ya - vapour lock! The Datsun is a 71 that was the parts car for Mrs E-tek's race car. (That's her in my Av working on the racer). It has a good suspension and engine, original interior and no rust on the shock towers. But it needs floors, which is where I am. It's last in line through, so it won't get much love for a while!
E
e-tek
Saskatoon, SK
Here's the "new" engine all prettied up. It'll get installed this weekend!! Yeeha!
Flatmotor
Arkansas
Looking good! but I believe you need a pair of 48-and up 1/2 ton pickup water pumps. Bill
E
e-tek
Saskatoon, SK
I am impressed. :thumbup: have to ask why did you paint it blue. I believe the usual color green for that motor ?
"As for original paint colors, the Ford and Mercury engines through 1940 were a dark green. Ford cars continued the color until 1942. Mercury engine had a dark blue color from 1941 thru 1948. Postwar Ford engines were dark blue thru 1948. Ford truck engines were generally the same as Ford cars during the years of this group. "
From VanPelt Flathead Sales website...
I also decided to swap ther waterpumps to get the right mounts. Not sure why my flathead guy said to build a bracket, when swapping them is SO easy! Oh well - gotta think for yourself sometimes!
****** was cleaned and opened today - all gears look reall good. I'll be installing it on Good Friday - GOOD indeed!!!
Dan in Pasadena
Pasadena, CA
Hi e-tek.
It DOES looks good. I am not criticizing at all because it looks clean, clean, clean but do you have any plans to jazz up the engine with, I don't know...chrome, maybe chrome acorn nuts on head studs, etc?
What other plans do you have for the truck? What do you generally use it for? My '46 Chevy is just a plaything. I still intend to get it totally reliable mechanically and somewhat detailed out - at least inside - for comfortable cruising here and there on weekends.
G1K
Buffalo, NY
The engine looks great. That sure is one nice truck you have, I bet it'll be real fun to cruise around in.
Ryan
HOTFR8
Castlemaine, Victoria. The Hot Rod Centre of Austr
:thumbup: Well I learnt something. I hope you did not take my post the wrong why as the Blue looks good. :thumbup:
So was it a GOOD day as you expected ??? Sorry I forget I am a day ahead of you :lol_hitti across the international date line.
E
e-tek
Saskatoon, SK
Hi e-tek.
No more plans for the engine...I love the truck in it's original "patina" colors, but I have taken a few measures to abate the rust, like POR15 on the undersides and cab floor....
I mostly use it for a yard truck, for cruising and take it to the occasional show. It'll be fun to pull the hood open now and have it all purdy!
Actually - we both learned something. Although "Blue" is correct, I found the ACTUAL CORRECT color is a much darker blue than the newer FORD blue I used....oh well...
It was so-so....it didn't quite get finsihed that day, due to needing a few small items....but now she is back on the road, plated and runnning smooth again!
Thanks to all for looking!!!:thumbup:
jayrush13
Lebanon Oregon
Boy that L24 brings back memories. Thoses SU's bring back nightmares ;-) A motor so simple even I could build one. My first car was a '72. I had no idea what I was doing...cam and headers killed any hope for low end torque, but I could brag I had a big cam ;-) Loved that car. Maybe I'll get another one day...v8 swap...hmmmm.
Just for your information you can crack your block by mounting it to an engine stand the normal way it should be mounted to one of the exhaust flanges
swharris
So. Cal.
Nice. Mine was a '72. Puke green with the orangie looking interior. My dad always talked about getting one for himself but never did. Then when I was looking a VW squarebacks he was out looking for Z's behind my back. He found this one with a blown head gasket. I was like...um but Dad I really want a VW. He was paying so guess what I got? Hey it was cool. I learned to do a lot on that car. My sister's boyfriend was a mechanic and helped me learn a bunch including rebuilding the motor and installing headers. I still dislike those SU carbs :mad:
I have to admit I really messed up the looks. 80's tri color stripes with centerline wheels and an airdam. I blacked out the interior with vinyl paint and splurged on nice recaro seats. Wish I had it back. I think someday I'll get another one...maybe drop a 350 in it :)
My neighbor has two originals sitting in his back yard. I keep bugging him..haha.
Not mine, but what it would have looked like originally.
E
e-tek
Saskatoon, SK
Funny how the uglier they where then, the cooler they are now (I meant the 240Z...;))
As for the old block - same plans as you HOTFR8! Gearheads....sheesh!
E
e-tek
Saskatoon, SK
Finally got started rebuilding the block I got to replace the original. It's circa 46 (distributor on front) and looks OK....so far. Once I strip the valve-train out I can have it magnafluxed to be sure. Removing the valves is the toughest part of rebuilding these engines, consisting of prying on the valvesprings with a long forked bar and then pulling out horse-shoe retainer clips with a tool (I made) that bends around the block top and hooks into them.
Out with old:
Getting started on the "new":
realvc
Lake Norrell, AR
Great thread. I have spent way to much time reading it.
You have one of the coolest trucks ever.
I had a 46 Stude back in the 70s and 80s that was a blast to drive.
It had a flat head six in it that I replaced the same way you did your replacement engine.
The old dude at the wrecking yard did not like it that we brought a battery and gas and started it up before we bought it. When he pulled it, he hooked his wrecker to the engine and started cutting everything loose with a torch until it came out.
Old trucks with flatheads are still cool.
E
e-tek
Saskatoon, SK
Hey E-tek, any pics of that shiny engine sitting in the Patina'd truck? Great build. Should have commented sooner, as this is my 10-12 time to look through this thread.
Here's some pics of it getting buttoned up - things where tight in the shop that day!:willy_nil
Flathead Youngin'
Southern Ohio
i must have missed something....is the blue engine the one you are putting in?
the cruddy one with the valve tools in the pics is the one that came out?
....so my crab dist. doesn't apply to the late model engine that went in...sorry
E
e-tek
Saskatoon, SK
Ya - I scratched my head when I read that, but figured I think on it.... ;)
The blue engine is a 53 I got out of a guys 53 truck just to keep mine moving while I hunted for a hard-to-find pre-49 block. One thing I try to avoid is vehicles that don't run. It's just a personality quirk....Around these parts the natives have yards full of non-runners.
The 53 engine has been great. I put it in early last summer and worked it hard all summer. It's my yard truck and I do lots of hauling with our big yard and a few rental homes. I likely won't even put the early engine back in right away - I just want to have it done.
Flathead Youngin'
Southern Ohio
oh, ok.....i'm slow you have to draw me a pic.....we'll you did:headscrat :bounce:
yeah, on that pre49 block (59ab??) use a crab distributor, you'll like it much better than that bail type......
all you need, and you may know this, is a different dist. cap, rotor button and some of the clips to replace the bail.....cheap quick and easy....
E
e-tek
Saskatoon, SK
When I sprayed the ('53) replacement engine (above), I used a No-Name High-Temp engine paint. Unfortunately, I found - after only one summer - that there is already some wrinkling and seperation showing. I can't see it lasting much longer, which is not only a shame, but it pisses me off something royal!! No one wants to put a bunch of work into an engine (or anything) and have it look like **** a few months later!
So I did some research and ordered Eastwood's Specialty Engine Paint in old-Ford Blue (Seafoam). It's an activated (2-part) paint which should hold up MUCH better than any single-stage product, high-temp or not.
sellersrodshop
Nashville, TN
the por-15 engine paint really holds up well too. i painted the block in my 40 ford coupe when i had it apart (2002) & when i sold it in 07 it still looked like new.
E
e-tek
Saskatoon, SK
OK Flatty pro's....can you confirm this is a Holley carb? I need to order a rebuild kit and want to be sure...
oilslick
Central illinois
Sort of related to your build , just wanted to tell you about the time my friend bought a 32 ford with a 49 merc flattie, The guy told him it was magnafluxed and had the receipt to prove it, friend bought it I was given the job of getting necessary odds and ends to fire it, got it running good and decided to add coolant , it went right into the oil pan!! I pulled heads and the block was cracked everywhere I looked, lesson learned to ask what the results were on the magnaflux!!!!!!!!!!! We searched the whole state of illinois for a year for a good block and ended up finding one only a few miles from home!!!!! I built it and it is so cool, dual carbs cammed up and headers.
E
e-tek
Saskatoon, SK
They are COOL engines - but as you found, when they crack, they C-R-A-C-K!!!:shocking:
E
e-tek
Saskatoon, SK
Just re-read this thread. Memories of loosing my original 46 engine, but grateful for the replacement. I still hang with Morris, who sold me the flathead from his 53 Ford.
It was also a good time at the forum. Good people, no BS.
