Stem wall application!
stang1
I have approx. 66 linear ft. x 14'high stem wall in my garage. I've watched the disk on epoxy coat application,but I would like advice as to include stem wall in 10 x 12 section? or do stem wall completely first and then do floor in 10x 12 sections. Concerned about the stem wall slowing my working time down. Temp 80/ humidity 70. Thx.
LegacyIndustrial
deerfield, IL
I have approx. 66 linear ft. x 14'high stem wall in my garage. I've watch the disk on epoxy coat application,but I would like advice as to include stem wall in 10 x 12 section? or do stem wall completely first and then do floor in 10x 12 sections. Concerned about the stem wall slowing my working time down. Temp 80/ humidity 70. Thx.
Be more concerned with the slump. You need to add fumed silica to the coating or she will be a dripping on down the wall.
If you can't find the fumed silica or if Christine doesn't have a vertical version, we have a coating that is designed for vertical surfaces, you need to call us, it's not on the web-site.
Good luck.
stang1
After mixing part A and B normally it's to be poured on the floor and squeegied and then back rolled. What's the best way to apply to the vertical surface. brush? or roll? Where to pour after mixing?
LegacyIndustrial
deerfield, IL
Stang, I am quite certain the material will drip down the wall without an additive. Ask Christine if she can supply you with fumed silica.
Epoxy is not paint and will not adhere to vertical surfaces well without a thickener.
You can buy fumed silica on ebay.
http://cgi.ebay.com/5-Pounds-Aerosi...828?pt=LH_DefaultDomain_0&hash=item255fe06e84
rugerlady
Call me at the office, I first need to check if you have enough product to do the stem wall. I will usually recommend doing the stem wall first.
bRIZZAd
I've seen multiple comments from searching that some people recommend painting instead, as it will end up being much cheaper. Your stems walls may not see much traffic, but then again since they are high like mine, they may see some abuse whether due to tools, shovels, etc, etc.
Brian1413
Stang1, Was wondering if you could share how your application on the stem wall went? I have a 20" stem wall I am planing on doing with epoxy-coat and I am a little nervous about the process. Some people say I need fumed silica, Epoxy-Coat said to just mix up small batches and put it on thin with a brush. I am concerned about the working time and not only need to get it on the stem wall but have to have time to throw some flakes at it. I was planning on painting a 20 inch x 10 foot section at a time. Any suggestions?
FFPL
Massachusetts
You need to use a thickener but it really is worth doing it with the epoxy. Here's mine and my neighbors that I did a number of years ago with Wolverine. Still looks great but has change quite alot from these pics.
http://www.garagejournal.com/forum/showthread.php?t=13347
http://www.garagejournal.com/forum/showthread.php?t=20542
My neighbors walls were a bit of a choir as I bevelled all the edges as well. Never again....
