Red Leader
I like the flat wrenches for handles. If you can drill holes in the straight part and get some spaces to pull them out from the flat part of the drawer face, that would look awesome. The bent box end wrench idea is cool too, but if you use the box ends for the bolts to hold it on, you loose a little bit of the design of the wrench.
EDIT: wait, your making metal drawers, right? Scratch that. Either would be awesome
ps - thanks for the addition pictures of the press brake in action. I needed them
-RL
-RL
Did it just for you.
Dave those came out beautiful. I think they represent the idea perfectly when I picture the wrench handles.
I know right? Outlaw, this one is the exact same concept as your spring and cup idea except there is no cup. Essentially I would make the bolt hole bigger on the bottom plate. Big enough to accommodate a compression spring that slips over the bolt. The spring will sit between the bottom of the top plate and rest on the bench top (through the bottom plate enlarged hole). When I tighten the nut & bolt the spring will compress down into the 1/4" space afforded by the thickness of the bottom plate. When I loosen the nut and bolt the spring will decompress and lift the top plate as bolt tension reduces.
