Above 1200 Sq/FT Restored 1930's Auto Shop
BB767
Philo, IL
And now for the exciting conclusion...
Gus's Manual - Reunited At Last
With the case now constructed as seen below, outside view...
...it was prepared to fit the book block. To do so, a french groove was pressed into the case.
The book block was first set loosely into the case and the book was placed in this Rock City joint creaser. Front view...
...and here we have the rear view. Look closely and you can see the cover, close to the spine, being pressed between two bars, top and bottom, that have a protruding lip on them that is literally pressing that french groove in the cover. This press is pneumatically actuated using 40 psi but when concentrated on the small lip area, it results in a very high pounds per square inch pressure.
When done this is the result, a french groove which allows the cover to lay open without trying to close itself.
Now the cover is ready to have the title embossed on it. Chris H uses two machine for that. This one is KwikPrint single line embosser...
...that has a 1923 patent date cast into it. You can buy a machine new, today that is identical to this one. They haven't changed the design at all.
The other embosser is...
...this Kensol multi-line embosser. This is the one that was used for the manual.
The kind of type and size was selected trying to mimic the original cover as seen with service type being used. To the right is a small generic design that resembled pilot wings :angel: that was incorporated into the title which you'll soon see.
Here the words MECHANIC'S MANUAL is done, spelled backwards of course. Behind those words you can see a long brass device called a pallet that will hold the type.
Then smaller type was used for the rest of the title. All the type is a zinc alloy which is harder than traditional lead type and because it's lighter in weight, it heats up faster also.
A pallet holding some of the small type together.
All the type is now spelled out, spaced correctly and those pallets are then held by a devise called a chase.
The Kensol embossing machine was preheated and then the chase with all the type was inserted just long enough to warm the type. The black handle of the chase, on the right, provides insulation while handling the chase.
Different colors of foil can be used in embossing, seen here is gold foil. Because our cover is tan, black foil was selected.
The book cover was placed under the type...
...the foil placed on the cover (not seen here) and the type was lowered by hand close to the cover and then quickly pressed on and then off the cover...
...resulting in the black foil being transferred to the cover. You now have have an embossed cover! :thumbup: After that, the spine was embossed in much the same way.
If too much foil transfers during the embossing or it's a small complex design that can cause the foil to "bleed over" as seen on the right, yellowed circled leaf above...
...a smooth all is then used to burnish the foil. On the left a new smooth all and on the right a used one. It is made of cotton and copper strands.
Here after the smooth all burnished the leaf you can see how it removed excess foil so all the leaf detail can now be seen.
Lastly the case or cover needs to be glued to the book block. Wax paper covers and protects all the pages except the end paper and the little flap of the backing cloth which will serve as the hinge.
Here the flap and end paper are having PVA glue brushed on. When all the glue has been applied the book is then closed, glueing the end paper and hinge to the cover.
It is then placed in this hydraulic book press. To the right you can partially see, in black, an old hand operated book press.
The book is pressed with 1,500 -2,000 lbs (682 - 909 kg) of pressure. It is left there until the glue sets.
In making this book there were many small, subtle, little nuances' that I didn't show or talk about to shorten the overall post. This was just the high points and it was still a very lengthy 3 part post. There are no short cuts when hand binding a quality book, but you can cut corners! :D Here's the finished result.
So, after all that, here we see the manual in use in its natural environment perched on the flat fender...
... that Willys thoughtfully provided to hold the manual on. Gus is one happy camper now! ;) We even spelled Toledo on the cover correctly!!
It is with a deep sense of gratitude and thanks to Chris Hohn and his Lincoln Book Bindery for his willingness and patience to first of all take this project on and then let me thoroughly document the process. There were several calls and emails to ensure I got all the details as correct as possible. If there are any glaring errors I trust he'll let me know and I can edit them out.
I am on to the next project so watch this space for more Restored 1930's Auto Shop excitement! Thanks everyone.
Thomas
BTW, please note no animals were harmed in the binding of this manual. The animals used in the glue were already dead! :eek:
markviii
east central IL
And Toledo connects back to me! I was born there. My grandmother worked in that Willys plant in Toledo and probably had a hand in sewing up the upholstery in Gus's interior, just as she did with the six Willys Jeepsters Jackie Kennedy ordered while the Kennedys were in the White House.
Everything comes full cicle back here to the COTU.
Chris
onething
TEXAS
Kudos for helping use all of the dead already animal :thumbup:
And again, thanks for the edumacational information.
Omphaloskeptic
Ultima Ratio, Wa.
Thomas, fantastic documentation of the book binder's art. Gus is lucky to have such a gilded tome to enhance his pedigree. Now be careful that no grease, oil, fuel, brake fluid, or even bird droppings come near that manual!:scared:
Perhaps now is a good time to use some of your fine walnut stock in building a proper wood case to protect and preserve the finished manual? Overkill? Maybe, but I think it deserves the 'Thomas Touch'.:thumbup:
realvc
Lake Norrell, AR
Oh man, now we have to remember that your mother-in-law worked at the Willys plant in Toledo and sewed the upholstery on Gus and Jackie Kennedy's Jeepsters?
Would it be OK to just audit this thread and not go for a grade on the exam?
Very interesting and I still check in every day.
Thanks one more time.
Vince
BB767
Philo, IL
Thomas,
Nice job on the manual rebinding. Here are a couple of pictures (before and after) from my Craig’s list find last Monday. I bought this 60’s version of Sun’s 1020 scope for $70, not working. I brought it home and cleaned it up. Went through each system electronically and found a number of corroded failed terminals, a frozen motor, frozen breakers and a dirty old machine that just needed a little tlc. I am happy to report that the unit is now in 100% working order and ready to be hooked up to a vintage hot rod. Your machine made this discovery very exciting for me. Now I just need to find a Sun distributor machine to sit along its side.
What a nice Sun Engine Analyzer. Terrific job cleaning it up and bringing the paint back beggers. Sun always did use high quality paint. It looks like the same vintage as my distributor machine, late 1950's - early '60's. Do you have the lower cabinet unit? If not send me a PM about one I've got that I'd like to see you have if it's the right measurement. I can perhaps bring it along to one of my Michigan drag races and you can pick it up track side. Just a thought anyway. :dunno:
Thanks for sharing it here with everyone and showing what's possible. The spirit of saving the dead and near dead continues! :thumbup:
Thomas
BB767
Philo, IL
Thomas,
May I suggest adding:
DEDICATED TO
VIRGIL JOHNSON
AND
JOHNSON'S WELDING
AND REPAIR
PHILO, ILL
U.S.A.
CENTER OF THE UNIVERSE
That addition was a great suggestion, unfortunately I had already completed the manual about a month previously. I need you guys to come hand around the shop more often so I can get these good ideas in a more timely way! The soda fizz in the Pepsi machine is always cold and the tunes are always playing, so come on over. :) Thanks Bill. ;)
Thomas
BB767
Philo, IL
Wow. I've always wondered about book bindings. Who knew I would find the answers buried deep in a thread about a 1930's auto shop? The education I receive from reading this is part of what keeps me interested.
It's like an novel unfolding right before your eyes without realizing it at all. I hope to hang around until the ending!
Great story as always Thomas!
--Jeff
There may be no "ending", just another installment! That is until Chris "lowers the boom" with the dreaded Test!
Jeff I hope you hang around too! As for the ending, Sweet Old Bill my have it right. There are ATP's (A Temporary Pause) while I'm off doing my day (night :wtf:) job but I've still got quite a bit of material in the pipeline to share here. Just remember to take notes as you go along, you'll thank me later, after the test. :D
Thomas
Vernmotor
Mt.vernon oh
I sit here wondering what else am I going to learn from this thread. I never even thought about book binding before. Not sure I have ever look at one and wonder about it. Now when I pick up a book I will look and think and about every time :) Thanks Teacher tom..
BB767
Philo, IL
I hope this isn't a dissappointment Thomas, I wouldn't have wanted to get your hopes up for something interesting :lol_hitti
For my Easter break with the family we took the caravan to a place in Hampshire, southern England, called The New Forest. The place is full of wild horses and beautiful woodland to walk in, but it has a gem in the form of a village called Beaulieu. (pronounced b-you-lee).
A very pretty village by the river that is home to a rather special place that goes by the name of Beaulieu Motor Museum.
The museum holds some cars that are very close to my heart, such as one of the Campbell's Bluebird land speed record cars:
But, what I think Thomas would be interested in is this:
Based on a garage from Wedmore in Somerset, its got a couple of things in common with Thomas and Virgil's garage in being from the 1930's!
The building is only a reproduction and but with the way its filled it has atmosphere. It reminded me very much of your shop Thomas and the way nothing was thrown away:
Gus' english cousin:
Hope you like it Thomas! If you want to have a browse of my other pictures from there take a look at my photobucket here: http://s439.photobucket.com/albums/qq112/landroversforever/Beaulieu Motor Museum/
Very, very nice and you were correct on all counts, I found all of it incredibly interesting and good quality photographs too! Next to Donald Campbell's gorgeous Bluebird are glimpses of Sir Henry Segrave's Golden Arrow, one of the pioneers of streamlining in action. I've had a great fondness for all those old land speed cars. I started reading about all of them in grade school and they still fascinate me!
The T & N MotorWorks wouldn't look out of place sitting right next to Mr. Johnson's shop would it? What an amazing place and the museum all seems so well done. If I might be so bold, would you post contact information for Beaulieu? That is a place Chris and I need to visit, no doubt!
Thank you so much for thinking of me and sharing this and your link to your album for all of us here. These are the things I think that make this thread so special. :thumbup:
Thomas
BB767
Philo, IL
Wow.
I have finally read through this entire thread. It has taken several days!!
Thomas & Chris, you have something very special, and the shops and vehicles are amazing as well.
I look forward to what you post in the future!
Welcome to the thread UN4GTBL. I hope you didn't loose much sleep while wading through all this! :) There is more on the way, trust me. Thank you for your interest and kind words. Much appreciated.
Thomas
BB767
Philo, IL
Ah haa, so there is a chance something will get powder coated then? I wouldn't want to be disappointed.
I'm also waiting to see how you weave in the SM shirt.
R1chy
R1chy, Hohn Motorsport Spec Miata Racing is owned by Chris H's nephew and he wore the shirt in my honor when we re-bound the Jeep manual. A bit of a stretch I admit but there it is.
BTW, I suggested to Chris H that a couple of his machines would look mighty spiffy powder coated but he didn't bite. At least I tried! ;)
Thomas
BB767
Philo, IL
Nicely done.:thumbup: Again worth the wait.
Thomas,
Well done, you never cease to amaze me with your projects!
Shaun
Wow! That is awesome.
well done BB767!!
Your dedication to details it's amazing...!:drool:
Beautiful. I love that stuff.
That's awesome! Thanks for the pics on the bookbinding!
Unbelievably cool! Thanks for doing the detailed photo-documentation.
Vince
Boy, thanks everyone for the support on this project. As I mentioned earlier I was really concerned about how those posts would be received. I personally found the bindery process fascinating and thought you would too! That's just another chapter, so to speak, in the continuing saga of the Restored 1930's Auto Shop.
Up next...
...a post about a cabinet. It's not quite what you might think. Also, just so you'll not get your hopes up, there's no powder coating involved. ;)
Thomas
MisteR Tee
England
Also in the Beaulieu Museum, until recently that is, was the very first slingshot dragster built by Sydney Allard in the very early 60s. Now, in conjunction with Beaulieu, the Allard Chrysler Action Group (ACAG for those acronym fanatics out there) is restoring this historic vehicle to a "cackle-ready" state. This photo was taken by me at the equally historic Brighton Speed Trials in 1963.
Here is the stripped bare chassis with the fresh Chrysler motor & front-mounted blower built by Aarons Booth, having been delivered last week by myself & a friend to the workshop of Sydney Allard's grandson, Lloyd, for him to fabricate a pair of new stainless steel intake pipes.
Here are the finished pipes, a fitting contribution by Lloyd towards the restoration of this iconic dragster. Apologies for the poor quality of the pic, taken with my phone.
& sorry for hijacking this....thread? It's more of an historical treatise on all things mechanical, construction, landscaping, woodworking & now book binding!! Keep it up Thomas.
IMCA38
Bennet, NE
Anvil update:
For those who may be curious, I saw the auctioneer yesterday, so inquired about the three anvils on the auction I posted recently.
He didn't recall specifics, but said they all sold in the $425-475 range.
landroversforever
Thomas
Thomas,
Two places so far away from each other and yet so similar!!
Their website is: http://www.beaulieu.co.uk/
As well as the museum there is a lovely old house and the village of Beaulieu is lovely too. Please let me know if/when you come over... it would be a great place to meet up!
Ross
KAP1978
Wolverine, Michigan
Chris
I was also born there and retired from the Toledo Police Department. I went past that plant for many years. The plant was torn down in 2006 and a smoke stack with the word "OVERLAND" was left there in honor. The Jeep is still built in Toledo.
BB767
Philo, IL
MisteR Tee another fine addition to this thread. I am familiar with that car and its timeless lines. Beautiful isn't it? My first glimpse of a dragster equipped with a front mounted blower was Dean Moon's Mooneyes Dragster. I am smitten by those wonderful intake pipes. Here's a link to see it in action in 1963 in the UK no less, for those interested.
Thank you sir for the above information and pictures. Did I read correctly you actually got to touch the engine and are involved, somewhat with the car's restoration? This after seeing it in action in 1963 no less. Lucky guy! :thumbup:
Thomas
BB767
Philo, IL
Anvil update:
Thanks IMCA38 for that update. For as simple as they are, anvils are just not cheap are they? :dunno:
Thomas
MisteR Tee
England
Thomas
Yes, Thomas, in fact I have been involved with the Allards in more ways than this as I served on the committee of the BDR&HRA (British Drag Racing & Hot Rod Association) in the 70s when Alan Allard was chairman. Not only this but the vice-chairman of the Allard Owners club, Mike Knapman is a near neighbour of mine & is to be seen reguarly driving around in one of his Allards!!
I'd already donated to the cause of this restoration, this epic trip was in response to an appeal for volunteers to do the neccessary transporting. In fact there was a deadline to this trip as a work day had been scheduled for the 22nd April to start the reassembly. I can now report that this was very successful & the car now sits on it's wheels & it's looking good for a test fire up at Dragstalgia in July!
Nuts
Baker City, Or
Wow I miss a month and what happens? Book binding!!!!
Terrific.
A nephew who worked his way thru college doing book restorations at University libraries repaired/rebound a few of my fathers car books and manuals.
Nice to see the process in photo's.
Doug
BB767
Philo, IL
Terrific.
Doug
Gone for a whole month Doug........what were you thinking?!:D
Welcome back.
Thomas
jeffmoss26
Cleveland, Ohio
I just read back a few pages and was fascinated with the book binding. My mom has been a librarian for 20+ years, yet I never saw how books were repaired/bound, or thought to ask.
Speaking of Toledo, I went to UT and graduated last May.
Nuts
Baker City, Or
Welcome back.
Thomas
Thomas selling old car rust is strenuous, and besides it's spring.
The Portland swap meet was very busy.
They were have to use tandem trailers to haul everything this year.
Doug
Nuts
Baker City, Or
Naw that's the Open Hiway Big Rig version with Pup Trailer.
This is the Off Road Flyer known as Big Foot.
Doug
Motown 454
I love this thread, no matter when I check in it still amazes me. The manual came out great!
Wingnut65
Tampa Bay, FL
I can confirm that you can learn something new every day. That binding process was unexpected, but totally welcomed. Besides using vintage machines, it showed a side of manufacturing that we live with every day, but never really thought about. I will appreciate a good hard bound book even more thanks to you, Thomas, and Chris H. Please thank him for all of us.
I know Gus is proud of the work you have done and he sits a little higher now. :thumbup:
