Weekend project was the change the struts on the car...and one of the bolts that mates the strut bracket to the lower control arm decided to snap! Don't know why they felt an little 12mm hex head bolt (M6-1.0) was a good idea for such a vital component.
Anyways, I was able to grind down and drill out the snapped bolt. Now my problem is I dont know what type of tap to use. I had a cheapie HF tap set on hand which did absolutely nothing. All the cutting threads just got mushed.
What would be a good set?
I currently have my eye on the Irwin/Hanson 'alignment' set:
http://www.amazon.com/dp/B002M78R68/?tag=atomicindus08-20
But it seems like most of you guys use the set that SO rebadges:
http://www.amazon.com/dp/B0000DD4KV/?tag=atomicindus08-20
Does the second one have any advantage over the first set? I like that the first set 'aligns' and has ratcheting adapters in the kit. And will either of them have a problem cutting into the control arm metal? I assume it is super hard metal...
