ID this vise, please?
jzt
Dallas, Tx
This is the only pic I have, will go to pick it up after work.
I will ask for more pictures, will post if I get them
Thanks
Catalyze
New Mexico
That vise is known as a Biggun'.....when you get more photos (and larger) we can tell what model it is.
Craig
J
jzt
Dallas, Tx
I did some CSI style "enhance, magnify" and guessed that it said "Ontario" on it.
I was correct. Will post pics shortly.
J
jzt
Dallas, Tx
One of the jaws needs to be replaced. Functions ok otherwise. There is lithium grease on some areas of it.
The seller said it was his great-grandfather's.
Edit: I paid $50.
J
jzt
Dallas, Tx
Yessir, it is pretty huge.
Similar to /same as Sawyer vises. Anybody have one of those?
It mounts via 1" threaded stud on the bottom.
What's it weigh, and how wide are the jaws?
That is basically the "original" swivel vise... does yours not have a hole in the flange for a drop pin to the bench to keep it in one position? I could nt see one...
J
jzt
Dallas, Tx
Weight is around 60lbs, 5 inch jaws. No hole for the pin.
Any guesses on age?
Early 1900s at a guess. post this up in the "vises of GJ" thread and you will probably get a lot more action on getting a date. Be sure to list it's specs, and all markings.
J
jzt
Dallas, Tx
Thread revival.
check out this thread starting at post 7. Bloo is the man when it comes to ID-ing these!
http://www.garagejournal.com/forum/showthread.php?t=80960
-Dane
I'll guess Sawyer (or Oswego).
He is indeed the man. Called it before the pics.
I have since picked up a rusty, but fully functioning Columbian 506M2.
Still want to repair/replace the missing jaw on the Ontario/Oswego.
5" long u shaped jaws. Previous owner started cutting the notch off already.
One of the fasteners has been drilled out, I am drilling out the other.
Not sure where to go at this point: continue cutting and install a flat jaw insert or find/make a u-shaped Oswego insert?
There is a 4" on Ebay for a reasonable $10, so finding a 5" may not be impossible.
