alan camby
I have a Ingersoll Rand 80 gal SS5 air compressor. I was just making this thread to document the modifications to my unit. I don't really have any questions to start out with but feel free to comment and question my compressor modifications.
The other reason I started this thread is because I am starting to go off topic on the after cooler thread http://garagejournal.com/forum/showthread.php?t=50946&page=8 and did not want to hijack that thread.
The pump (SS5) is a single stage in line 2 cylinder pump that turns at approximately 1000 rpm. The compressor label shows a CFM of 18.1 at 90psi.
The drive motor is a single phase Emerson 5hp pulling 22.5 amps at 230volt.
Anyhow I am working on cooling the air in order to get the moisture to fall out before the water can make it to the air lines.
Here is where i am at in the after cooler thread.
below is what i wrote about the cooler in the aftercooler thread.
"Here is the temperatures I came up with this time.
The temp in my garage was 90 degrees F.
Started the test with a full tank of air.
Unhooked the sand feed line in the blast cabinet and put a bucket on the foot air valve, just like i did the last time. pressure stayed around 90-95 the entire test and the compressor ran 100% of the time. All temps are in Fahrenheit. All temps are the highest recorded for the area tested. Temps are surface temps.
One minute of running
198.9 degrees at the inlet of the cooler
98.8 degrees at the outlet of the cooler
96 degrees at the inlet of the tank check valve
six minutes
285 degrees at the inlet of the cooler
111.2 degrees at the outlet of cooler
103 degrees at tank check valve
Also checked the compressor pump head temp. at 331 degrees
ten minutes
305 degrees inlet of cooler
111.9 outlet of cooler
107 degrees at tank check valve.
356 degrees head temp.
outlet of the water trap just felt warm to the touch. Could easily hold onto it for as long as i wanted. Cooler then the temperature of the water i wash my hands with. I would never intentionally touch that pump outlet pipe"
My next project is to cool the pump on the compressor in order to get a lower outlet temperature and increase pump life.
I am doing some testing to prove that this is reducing my temperatures.
Here is the how i rigged up a muffin fan (equipment cooling fan) to cool the head.
Note: this is a temporary mount for testing.
here you can see the stock belt drive flywheel fan and how none of the air is directed to the top of the pump. I think this is a design flaw, and should have had a shroud to direct more air to the head.
Now i don't have time to write this entire thread today. I plan to add part #'s for the items i used and where i got them, a bunch of pictures, and all my other modifications. this will take weeks if not months for me to slowly complete
Thanks for looking
six minutes
ten minutes
Thanks for looking
