Solving the USB charging dilema
klaw
to many usb devices that need charging so I installed this
theoldwizard1
SE MI
Interesting.
Need link to the product !!
Does it do the high current (1.0A; standard USB is 0.5A) charge on Apple products ?
K
klaw
I have used the multiport devices but wanted to have a cleaner installation
I have a spot in kitchen where everyone charges phones and it is handy to have a built in 4 outlet usb charger
It can charge (up to 2.1 amp) all of the apple products including the ipad
the link is
http://currentwerks.com/
they also make some that retain the 110 v outlets
Cardboard Man
I've seen those before, and that is a slick product. I wonder though, since they obviously have a built-in transformer, are they consuming power even when not charging something?
K
klaw
they say No
From their web site
Specs
Specs
Operating Temperature: 0-35 degrees°
Input: 90-132VAC 50/60Hz 0.7A
Output: 22 Watts 5VDC 4.4A (2.1A maximum per port)
Tested to UL standards by Met Labs
Features
Delivers 22Watts of output power.
Can charge 4 USB devices simultaneously.
Draw NO standby Vampire Power
Exceeds 5 Star Energy Standards.
Fits all standard single gang electrical boxesOperating Temperature: 0-35 degrees°
Features
RCStocker
Indiana, California, Australia
Yes power is going all the time but it will not cost you anything. Un-pluging things is a waste of time and a big joke. You will not save a dollar a year and it is not worth worring about. You would never know the difference on your power bill. The inviromentalist waco's started all that garbage about un-pluging. I never turn off my computer and for the past 60 years I have always left things pluged in.
The only time I worry about power is when there is a power outate or huge storm. If the power goes out I flip the 200 am breaker off so I don't get a power surge when the power kicks back in. I have had things blow with the surge. I forget what it was now but it can and will happen. I have a lightning rod on all my homes. Even in places that get little rain. I had the barn catch on fire from lightning and they had a lightning rod on each end.
I personaly don't have time to worry about what has power and what doesn't. I have a life. :shocking:
K
klaw
the only thing you have to watch for is ipad nee more current to charge unless in sleep mode
Catalog Number TR7740
Wiring Method Side Wire
USB Rating 700mA 5V/DC
Receptacle Rating 15A 125V NEMA 5-15R
Product Colors Colors may vary per product. For ordering, include Cat No. followed by the color code: A (Almond), BK (Black), LA (Light Almond), V (Ivory), W (White).
BFBOB
OK. Let's consider pilot lights. LED's typically pull 20 mA at 2 volts. That's .04 watts. Multiply by 8760 hours in a year = 350 watt-hours per year. Say you've got ten of 'em. That's 3.5 kWh per year. Electricity costs vary, but call it a dime per kWh. You're WASTING 35 cents worth of electricity every YEAR.
Is it worth the hassle of unplugging rather than just turning off? You decide.
The USB chargers that claim to have no parasitic load could easily have a mechanical switch turned on by plugging in the USB cord. Lots of audio jacks have switching functions.
K
klaw
I just ordered 2 of these:
http://www.amazon.com/dp/B008O11IEY/?tag=atomicindus08-20
It looks to have higher power output than the Copper version.
Steve
Leviton’s USB charger/tamper-resistant receptacle uses advanced technology to deliver the most efficient charging for every device. The USB ports are controlled by a smart chip that recognizes the charging needs of each unique device and optimizes current to reduce charging time. This allows users to spend less time waiting for devices to charge and more time enjoying them. The Type A, 2.0/3.0 USB ports feature a combined power of 2.1 amps. The USB receptacle also features a high-power port, ideal for charging tablets and other high-draw portable devices. With these value-added features, users can be sure they are making the smart choice for charging their electronic devices.
I am a little confused says a combined output of 2.1 amps but also says it has a high powered port?
skamp
Cypress, TX
I was not sure of that either. The user guide has some extra info on this:
IMPORTANT NOTE ABOUT THIS USB CHARGER/TAMPER RESISTANT OUTLET:
The 2.1 Amp USB outlets on this USB Charger/Tamper Resistant Outlet are
optimized for use with certain types of devices such as iPad®. As a result, the USB outlets may not charge all models of all brands of your mobile devices. If any of your devices will not charge using the USB outlets, use the 15A-125V outlet and the AC adapter of your device for charging.
The two USB outlets are designed to charge two devices simultaneously. However, if you plug in two devices to charge simultaneously and their combined power requirements exceed the power capacity of the USB outlets, they will shut down to protect your devices. In that case, try charging each device by itself.
So looks like 2.1A total. This should charge an iPad even if it is on provided nothing else is plugged in.
Steve
cide1
We have been in our house for about 3 years, and the power bill has kept creeping higher and higher. I thought I had most of our light bulbs switched over to CFLs, and I tried to unplug things that weren't being used for extended periods of time. The sensor for our 3 outdoor lights was broken, which left them on all the time.
I got tired of paying money to the power company, so about 45 days ago, I replaced the remaining 25 bulbs or so with CFLs, and fixed the light sensor. I put power strips with true on / off switches on our home theater setup, bedroom TV setup, and drill charger / TV / radio / computer in the garage (and actually use these to turn the things off). I also have been a little careful with the A/C (but not a lot). My power usage went from 1850 kWh in July of 2011 to 1250 kWh in July of 2012 which was the hottest month on record, so my power bill dropped over $50 for the month of July.
Simply a status LED wont cost much, but most of these standby things get warm, and warmth indicates more than a tiny draw.
shoturtle
Frankfurt AM
It does look cleaner, but I have 2 ipads, 2 iphones, and 2 blackberry. So All the 4 port ones I look at was not an option. Went with a 7 port hub to charge everything instead.
