Familyof8kids
Yes you can but not all of them carry the epoxy. Some Menard's I believe can access the PPG epoxy but not 100% sure. They can order and then you would have fresh inventory.
You can get PPG at Pittsburgh Paints stores
Yeah I think Ill swing by the one a town over tomorrow. I was on my way to check out the Benjamin Moore options but they had closed.
I couldn't find any bad experiences from people with Benjamin Moore epoxies though. Not many comments at all but the few seemed positive.
I'm also still on the fence about just going without a primer. Nremember that the bond to the concrete is arguably the most important one. Am I going to trust the Epoxy-Coat product or (insert primer brand name here)? I'm still not sure!
I'll be using a primer too with my install this friday. Using this one below and also their Polyurea
http://www.garagecoatings.com/Epoxy...king-Penetrative-Epoxy-Primer-Sealer-15G.html
Familyof8kids- The Polyurea I bought has a really nice rolling technique guide which I'm sure would apply to yours also. Just thought it might be beneficial
http://www.garagecoatings.com/Product Literature/Install Guides PDF/5073 Rolling Techniques.pdf
I stand corrected and just looked at my old spreadsheet of notes and you are correct. BM epoxy was high on my list but local shop is not liked by our town so I moved on. I did note the paint by BM was horrible but did not include another note so not sure why I had that info down.
So, since purchasing my kit I've read that a primer is really, really recommended.
The only thing I could find locally would be the Benjamin Moore Super Spec HP (P35). This would be a compatible option?
Link
I am curious about what you think caused the fish-eye's however. Do you think it was the primer coat?
James
Question about product "thickness".
So obviously one coat is sufficient for coverage.
What I'm wondering is how far could you make it go if you planned on doing two coats.
For example I have two kits @ 500 per kit but ~630 feet to cover. Could I do a "primer" coat at 50% thickness and have lots left over to do the broadcast coat?
So stretch out 300ft coverage to 600? Can it be done?
Don't mean to hijack I can ask these questions in my own thread if you'd like, as long as you stop by!
Well now I am a little upset. Pictures will say it for me. Now got to get another tool to scrap them off. 100's of them in the yellow only.
I thought you sorted all the flakes out into different bags?
Let start off by saying WOW I am tired but impressed with Epoxy-Coat epoxy and FOR SURE PUT DOWN A PRIMER!!!!!
I'm interested in this statement. On what basis do you say for sure put down a primer if you haven't ever put down an epoxy without one?
Once you get your clear coat on you won't notice. Are you using aluminum oxide?
If you are going to apply a clear protective top coat you will need to do a good scraping to dislodge any loose chips. That would get rid of these chunks. I'm wondering if its the manufacturer of the chips not slicing properly.... I've never seen this.
