rodsatheart
- Joined
- Oct 2, 2012
- Messages
- 17
OK. Duh !!!!!!!!!!
Thickness of main cup is .380"=9.652mm.
By the way, there were more of the later versions of the Michelins made than the early versions because the strengt issue of the nitrile u-cup.Here's a big THANK YOU to ..... BOTH ..... Hiball and Edgar for all the educating you've been doing to us greenhorns when it comes to dismantling and fixing hydraulic jacks.
Stumbled on this thread and now have confidence to tear into nice long handle floor jack I've owned for 15 years but never used because it had leak down issues!!! Thanks again for helping us get these jacks back in service.
Also, in another new thread, there is shown a black 4 ton (early?) Craftman which is different from the one currently sold by Sears, as seen on their web site, ( the one that shares the same pump with the Michelin). I do not know if this different 4 ton jack uses the same size u-cup as the early Michelin although the size 24 x 40 x 10 is mentioned on that thread, but from the photo posted, I can see it is also a nitrile u-cup, like the one in your photo, but in the photos of this new thread the ribs between the lips and the step in the heel are shown. Maybe a 24 x 40 x 10 u-cup will fit this (early?)Craftman 4 ton without being a tight fit. The title of this new thread is "Craftman 4 ton floorjack rebuild".
That is my thread.The measurement of the cup that i listed is approximate. The actual measurements are 24.2mmx39.34mmx9mm. That is WITHOUT the backing washer. If helpful i can post some more photos of just the washers.
The other thread for clickablity ease.
http://www.garagejournal.com/forum/showthread.php?t=168840
Hiball
The only way to replace the nitrile OEM u-cup with the step is with a u-cup without the step because the ones with the step are not available in the aftermarket. You would need to get a repair kit from Shinn Fu, assuming that these are available.
Of course you have to shave or file away, the backup washer to make it a flat washer to be able to mount a modern stepless u-cup. If you don't it won't fit properly. That goes without saying. Thank you for your "friendly advice" but that info is very, very old news to me. It reflects on you if you think I am so stupid not to have known that.
If you have used the 24 x 40 on those jacks with no issue that means that you have only worked on the early versions of the Michelin jack. Even your photo says that you were not aware of the production change fron a nitrile cup to a stepless urethane cup, otherwise you would have also shown a photo of the late version u-cup.
These stepless seals in the quick lift have been around for more than six or seven years maybe even more. They are also found on the Omegas, made by Shinn Fu. That you have never encountered them is beyond my comprehension. Are you only fixing Weavers and Lincolns?
I was not stumped with the change of u-cup from nitrile to urethane because I realized right away that there was also a slight difference in size between them, something you will realize the day you finally get to fix one the later versions of Michelins. And what are you going to do then? Because you are only relying on the 24 x 40 u-cup and you did not know about the other size I mentioned in my post. You would be stumped!
I do not quote and paste here, I keep myself informed with the latest about hydraulics from the peolple that have knowledge about this issues, namely the manufacturers of u-cups and other types of seals. Perhaps you think they are a bunch of chumps?
That you make fun of my research means that you have never done any research about hydraulic seals. There is a lot of good info in these websites and you would have known about it if you had done even a little research on your own.
You are only relying in what you learned 20 years ago. So you are relying perhaps on outdated info? I see that you have over 7000 post on GJ. Perhaps you should use some of that computer time to keep up to date by doing some research about hydraulic seals.
Please, before challenging someone else knowledge, be certain that you know what you are talking about. The community here may think that you are a "guru" but without good, updated knowledge, you are just an "also ran". I can see through the smoke screen...others not.
For example, you did not know about tapping new valve balls to seat them properly. EVERYBODY IN THE BUSINES OF HYDRAULIC REPAIR KNOWS THAT. How come you don't know it.
I do not need to impress you or anyone else here. I only have interest in learning and knowing things that can help me do better job. Apparently, you don't.
The only one who always try to impress people here is you because you never miss an opportunity to mention that you have been doing this for 20 years. Just because you have been doing this for 20 years doesn' t make you an expert if you don't do any reseach or keep up to date with the changes that happens with hydraulic seals and equipment.
I do not claim to know everything there is to know about hydraulics, as you do, and that is why I do the research, not to impress anyone but to know what I am talking about. If I don't know something I would say it right away and not make up things or excuses, I have no problem with that. How about you, Hiball?
I do not negotiate with terrorist, Mr. "All high and mighty guru of jacks".
Should be the same seal that I posted in #279
Have a 25+ year old jack, made in Taiwan. 4400lb. Nice little jack. Was leaking badly, but worked OK. Would bleed down over time with a load on it.
The pump mechanism is very similar to this one:
www.youtube.com/watch?v=uSms24ZqG1Q&feature=related
I replaced the O-rings in the pump shaft bore: one that goes around the shaft and one that seals the bottom of the screw in fitting that the pump shaft goes in. It has one ball below the pump shaft, just like in the youtube video.
The first time I tried the jack it worked fine, lifting about 500 lb. When I tried it again the jack goes up on the pump stroke and then back down when I move the handle down for another pump stroke. The fluid level was a little low so I filled it. Pumped it with the filler plug out and release on and off to bleed air. Still got same result.
What could be wrong?
Lift Arm feedback that follows the Handle is normally a indication that Valve has a Ball that isnt seating properly. This can be caused by Debris that has made its way through the system, Components installed Wrong or Lastly a Damaged seat/Ball. On the Extreme side of things it could also be a Catastropic failure of the Main Ram seal, This scenario would probably also show some Leakage around the Tank Seal/Nut.
I was not able to get the cap nut off the cylinder. So I am going to flush out the jack. Would brake cleaner be OK or should I use something else?
Pete
You would be better served by removing that tank nut, this way you can evaluate the system looking for problem areas at could be allowing seal parts to be ingested I to the system. I think it's uphill business trying to flush the system without opening up all ports. What have you tried so far to remove the tank nut? Have you tried adding leverage?
I tried a big pipe wrench with a cheater pipe.
First, you have to make certain the pump body is SECURELY attached to something that is not going to move when you apply massive amounts of torque !
That was a problem using my home vice. But the work vice is much better. Or, I may reinstall the pump back in the jack frame, and secure the frame.
Pete
Hi HiBall,
Your post got me motivated to rebuild my Craftsman 3.5 ton professional jack. I used the seal kit from an Omega MagicLift 25030 (http://www.shinnfuamerica.com/ProductDetails/Omega_Lift_Equipment/Magic_Lift_Service_Jacks/25030/360) because the power unit cross referenced to be the same and was able to replace the cracked u-cup and most of the o-rings to bring the jack back to life.
However, there is one small annoyance after the rebuild. When I lower the jack with no load on it, the arm comes down in steps as if its sticking rather than smoothly like it originally did. I tested the jack by lifting a corner of my car and it lifts and holds. So I have been reviewing my rebuild in my mind particularly on the release valve but I couldn't figure out why.
One thing I may have done incorrectly is I placed the tiny ball under the release needle valve (as shown in the owner's manual diagram) in the bottom passage (there is one on top that leads to the release valve and one at the bottom that I don't know where it leads to) that leads away from the hole where the quick lift tube is seated because I thought that's where it came out when I disassembled it. Even with that, I couldn't imagine how that would cause the ram not to retract smoothly.
Any thoughts? Or is the new u-cup simply tighter causing the ram to stick a little?
Thanks
Eddy
Hi Hiball,
The release valve has a conical tip which one reason I couldn't figure what the tiny ball i found both in the unit and in the diagram was for. Maybe the ball I put back in there is not really needed and its obstructing the release of oil.
I didn't mic the u-cup but visually it looked the same shape and size and the fit was good on the rod and just snug back into the cylinder.
I did make sure I bled the air after filling the oil reservoir by pumping it with the release open and the oil covering the inner cylinder after bleeding. But I have only cycled the jack under load maybe 2-3 times. Perhaps I need to use it a few times to break it in?
Thanks again.
Eddy
Hi HiBall,
The release is definitely a cone/needle valve. The extra ball however was never placed into the release valve cavity so I am positive the valve seat wasn't damaged by the ball.
It's a bit difficult to describe and I didn't take a picture but I actually found the ball in the cavity where the most inner tube sits.(the tube that goes inside the ram that provides the quick lift function) In that cavity, there are 2 galleys, one goes up to the release needle valve and one goes down. I saw the ball fall out of the bottom galley (though I am not 100% sure as it could've fallen out of the top galley into the bottom galley and back out into the center of the cavity) so that's where I put it back.
At this point, the jack is lifting and coming back down so it's just slightly annoying that it's studdering when it's coming down.
Thanks.
Eddy
but, I Know of none of those jacks that utilizes a ball "Inside" the Main cylinder or the quick lift stem, hopefully it won't make it's way into one of the passages.. Good Luck..Hey hiball--- my jack is almost exactly like the one in the original thread....how does one put the pieces back together and bleed it??? My jack only moves the same distance as the handle....then back down when I raise the handle... Seems like such a simple fix but I am stumped----
I have an AMT jack made in Taiwan that I am trying to fix . Is this brand one you are familiar with Hiball? The u cup is shot. It is a 3 ton floor Jack. Id .85in od 1.4 in .33height are the dimensions of the piston and cylinder. I paid 20 dollars for it and 4 jackstands and a bottle jack . Can take pictures if you care to see them . Seems worth fixing . Thanks in advance
Hiball--- i can not thank you enough--took her apart--cleaned everything---the two balls in one of the chambers were stuck---anywho---works like a champ now-- she's not the best jack in the world, but get's the job done---thanks again--- no way i could have done it without this feed!!! THANKS!!!!!!!!!Lift arm feedback that mimics the handle is a indication of a valve issue, double check the working valve assembly order.
I'm out of town, ill contact you via Pm when I get home..
Hey Hiball, I found this post when my jack quit. Great post! My jack is a little different because it has a speedy lift function. It is beefier than the newer China jacks and I would like to save it. Like you, I don't like throwing anything away.
Here's what I know:
It is a Penske Speedy Lift 3 Ton, about 10 years old, made by MVP. I took it apart and replaced the pump and valve seals, put it back together and it did nothing, NADA. I checked my photo and checked to see if I had it all back correctly, then I found a checkball on the floor that must have fell off magnet when dissassembling. I have no idea where this ball goes and quite certain that's the problem. Mine has an extra control valve not shown in your post. I'm including photos, one of my dissassembly and another of the power unit.
If you have a diagram for this type jack, it would help me get that "extra" ball back where it belongs. Thanks for considering my dilema.
Anyone know what brand of jack this is? Appears to be a walker/lincoln design but the rear wheels are welded and look different than what I've seen? Very old one?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=290811582907&ssPageName=ADME:B:SS:US:1123
