I think someone scabbed that gear rack onto the top ring. Look closer at the lower ring; doesn't the gear rack float in a groove in the lower ring? it should do the same on the upper ring. This is so you can loosen just the table clamp (another scabbed up job on yours...) and swing the table around. Somewhat difficult to do with all the rust, gunge, and paint left by the PO on the column in that area.
If the gear rack is missing the small step needed to engage the upper ring, just re-grind a new one.
The table itself is in sort of tough shape, but it IS the larger industrial table. I'd love to get one that size with the lift for mine.
The arc is not as bad if you put a drill press vise over it, it just hurts to look at now
