Kevin54
MEMBER EMERITUS
Re: anyone seen these socket trays?
Anodizing will come off the those pins if you use the sockets on a regular basis. Some chemicals will remove the anodize. People use Easy-Off oven cleaner to remove anodize fom aluminum trim before buffing. It does impregnate the aluminum somewhat, but it won't wear as good as a powdercoat job would, unless it was hard anodized. The holders he shows is just a conventional anodize so will wear easier. We anodize quite a bit of items where I worked and it will wear if it is something that is used regularly. Don't get me wrong, they'll last for quite a long while, but the pins will wear off by taking the sockets off and on.
From what I am reading, due to the anodizing actually being in the metal it would take something capable of etching the aluminum in order to remove the color. But please do some more research.
Great product. I'm glad I ordered them.
Such fast service!
