Open End Stress Test Results
bpankratz
Hey, I am just curious, the Carlyle brand wrenches sold at NAPA (I know Taiwan...) anyways if you would be willing to ship me the wrench after, I would pay for it so you could test it, they have a design with teeth like the FD+.
Steve_P
thanks for posting this.
Doesn't the new Williams USA wrench have an open end design like the Matco?
Skin
Boston
Its slightly different but the same idea, the cut-outs are very pronounced like the grooved section on the FD+, and there are 4 so it functions in either direction.
Skin, what were you using to get the extra leverage?
Nothing. Each wrenchs length was its own leverage.
marlinspike
Virginia
I wish Hazet or Stahlwille would use those grooves. As it is, I have applications where I can't get two Hazets in place (e.g. breaking loose certain fuel lines on a K-Jetronic system) without a lot of difficulty and instead use one Hazet and one Stahlwille. That Matco would be a non-starter, but those little lines seem to work wonders without marring the fastener.
That said, I guess it's all academic since I've never rounded anything since buying a set of Hazets. Still though, can't help but be a little jealous lol.
superautobacs
Vancouver, BC
Thanks for taking the time and putting the effort into this demonstration.
A few things that popped into my mind...
Because there's variances in dimensional tolerances on fasteners (in this instance it's the distance across flats), can you use fasteners that are as close to being equal and of the same supplier?
The smaller the measurement across flats on the fastener, the more prone the wrench is going to round over the edge. If you can narrow the variances as much as possible between the fasteners we can really pin-point what the wrenches are capable of doing (the level of marring at the corners).
You mentioned that the wrenches that did roll over the corner were stretched beyond yield and the spread was measurable at the ends of the open-end. I just want to clarify that it was only at the ends, where spread is inevitably going to happen, correct? When using the open-end it's critical that the operator places the fastener head right against the base of the open-end. The farther out the fastener is from the base of the open-end the more likely it is to round over the corners under torque, as there's less material.
It would be interesting to know how the others would stack up to the experiment:
Stahlwille:
Carlyle (Napa):
Wright Wrightgrip, Armstrong/Gearwrench, Williams SuperCombo:
Stanley:
images
Proto ASD:
marlinspike
Virginia
I have a set of those Stahlwille Type 15 wrenches (the Stahlwille in the picture). I like their size, but that Softgrip head is no good for bolts that susceptible to rounding. They're were discontinued a few years ago. That said, I've only had issues with it rounding soft fittings (brass and such). I'd be happy to mail one to OP if he'll mail it back after testing.
lwlobo
Colorado Springs, CO
The wrenches are metal and if you round a bolt it will spread permanently. The question is by how much.
Just because the wrenches are metal and deform during the process doesn't mean they will spread permanently. They may, but its possible, even likely, that high quality wrenches are designed to keep deformation from rounding a bolt head within the elastic zone of the steel, meaning no plastic or permanent deformation.
Cheaper wrenches, not as likely.
There is not doubt that FD+ type features will generate more torque before slipping, thanks for the tests and good pictures showing it.
marlinspike
Virginia
If I remember the marketing right, the Stahlwille Type 15 were designed to take advantage of this as part of the convex jaws thing, which is why I think they cause problems with fittings made from soft metals.
Skin
Boston
Okay, lets agree to disagree then. They're hardened metal objects, they're being flexed, they will all spread permanently, the question is simply how much and how often is it being spread.
I could get all **** about it but, why? Actually trying to fix things you don't have the luxury to hand pick what fasteners are used, and especially on corroded junk a lot of times the wrench doesn't even fit properly anymore without being pushed or hammered on. If I can get a group of corroded fasteners together I might go there because I think that test has merit but as far as hand picking nuts and bolts that are as perfect to their labeled size as possible, i'll pass.
correct
Good crimany seriously? Pulling on those thin beam Snap-on wrenches must've hurt. I hope you had a glove on or a towel wrapped around it. :shocking:
you can see a blue shop towel in the first string of pics. I actually don't find Snap-On wrenches nearly as bad as people make them out to be.
Katok
Awesome thread. It's not entirely controlled scientific test but this test does makes sense in real world application. Thank you.
N.I.
Northern Ireland
Sorry, but you are completely wrong!
Please keep an open mind, and learn from others trying to correct you. The joy of forums is that they are a wealth of knowledge.
Time to brush up on your basic Physics.
All metals are like an elastic spring (untill the yield point).
The strain ( i.e. extension) is directly proportional to to stress (i.e load).
Strain = Stress/ Young's Modulus.
The very basic principle all Engineering Design is based on.
A stronger/ harder material will have a higher Young's Modulus value.
This basically means that it will flex less for a given load, but a spring it remains.
N.I.
Northern Ireland
Engineering at its finest:-
Not the best quality, but it shows the deflection that has been designed into an aircraft wing, to keep weight to a minimum.
It is difficult to get a picture of the scale, but it is 26 feet at the tip.
Another video showing deflection when landing at the stage the 'load' is removed from the wings:
Steve_P
you are somewhat correct in that the OP is wrong on this statement:
and you are correct when you said this:
But, once you said this
it's not necessarily true. Yes, steel has a higher E (young's modulus) than AL (by a factor of ~3). But steel, whether it's 1020, or 4140 at RC 40, has essentially the same E value.
Look it up on matweb.com before you argue and you'll see it's 29,000-30,000ksi for steel whether it's 1020 as-rolled or 4140 at RC 40, or whatever). Yes, the yield strength greatly varies, but both materials have the same E value and therefore WILL deform the same amount below the yield of the 1020. Of course the 1020 will reach yield sooner and permanently deform.
N.I.
Northern Ireland
Actually thanks for pointing that out. You made me spend the last hour looking into this more and comparing all the various grades and alloys of steel.:thumbup:
With such a pronounced difference between the modulus of iron and many of its alloying elements, along with forging and tempering processes, etc, I did assume these would all have a more notable effect on the modulus.
Forums and a wealth of knowledge ;).
vintagefan
I own Wright's WrightGrip, and SO FD+. I find them to be equal to each other.
The Wright's teeth are very sharp and well cut, but smaller than the SO, so they don't mar as bad but still grip very well.
I find the Wrights to be slightly more comfortable and maybe even a bit stronger than the SO (they are beefier), but also harder to get into tight spaces, and are a bit on the short side. That's why I own both.
kxxr
Big Sky Country
Great thread! I was reminded of another that appeared here some time ago. Here's a link to it (I think this link is to the second of at least 2 threads on the topic, find them all by searching for threads by user DavidB):
http://www.garagejournal.com/forum/showthread.php?t=59707
Anyway, for those of you interested, you may find this thread informative as well.
I'd like to see how the Metrinch design would fare under Skin's methodology.
lwlobo
Exactly right, Steve. I remember wrestling with this idea back when I was studying engineering materials, and I had to adjust my intuition to reality. Fact is, hardening doesn't make something stiffer.
BTW, I've found it's not uncommon for engineers to misunderstand this.
