bobcatdan
John Deere engines are full of them, main reason I bought all of mine.
Pls read the OP, I AM asking about sockets.
12 point will work with square plugs.
For box wrenches, yes. I'm talking about sockets on a ratchet.
Some have already mentioned VW/Audi axle fasteners but also crankshaft bolts such as the 1.8T.
Hold on a second......let me get my calculator out.
Triple square you say?
Let's see......a square has 4 points......
A triple square would have 3 squares......
That's 3 squares with 4 points......
3 X 4 = 12
Thats quite a smarty pants answer, but my question was not how many points does a
triple square have. Obviously it has 12 points, and so does a bi hex have 12 points.
My questions was the angle of each point on a triple square is 90 degress and the angle
of each point on a bi hex is 60 degrees.
I thought all 12 point sockets were made with a bi hex design (i.e. 60 degree angles)
and from the look of that picture the bolts are made with a triple square design
(i.e. 90 degree angles) So really one should use triple square 12 point sockets on them
rather than bi hex 12 point sockets on them.
Look at it again. It's double hex.
If you are reffering to the picture in post No.56... I have looked at it again and again
and I respectfully say you are wrong... that is not a double hex it is most definitely
a triple square.
I was changing the assist springs on my garage door, these grab bolts are square head. good luck turning that thing with a 6-point socket.
It would be a lot clearer if the picture was larger, and from a directly overhead angle.
On one side, the angles look like mostly 120, on the other side closer to 90. I'm beginning to think the image quality is not sufficient to make a 100% definite determination.
Why are (almost?) all impact sockets 6-point then?The "The fastener has 6 sides so I will use a 6 point" argument is no longer valid.
12 point spline sets are advertised as handling them. Is that a good idea, or is it a case of
"works for both, but best for neither"?
12 pt sockets do not fit square fasteners.
