orange02ss
We decided to start on the roof, I talked to the manufacturer and asked if it would be ok to install the metal roof over the existing plywood. They said its fine as long as there is a moisture barrier between the two. After pulling all the old shingles off we found that most of the plywood on the front needed to be replaced.
My nephew and I tearing off the old shingles.
After tearing off the rotted plywood, I had to repair some of the rafters that were rotted. I also had to repair some of the 2X10 tie beams. After sitting abandoned in the hot humid weather and cold during winter the tie beams twisted and pulled away from the rafters. (I am not sure if I am using the right names, correct me if I am not). I had to pull the beams back into place and secure them. The left side of the building needed about 6-7 done on each side.
The new plywood going on.
