Tape OSB Seams?
Garage Dog
Minnesota
I will admit I have never tried taping OSB - and never will. Need it sealed? Try caulk. Need it to look nice - try some thin molding / trim...
Norcal
Want taped joints? Should have hung drywall, just my opinion......
johno
Southern Ont.
I don't think that would look very good even if it works, which i kind of doubt.
Vegaman_Dan
Pacific, WA
If I have OSB walls, I wouldn't want to seal them. Having the ability to remove the panel with screws to get behind it for wire/pipe access would be worth more to me than seeing seams.
usmc_noma
virginia
Agreed. If you want to hide the seam use molding, furring strips (i think that's the name), or caulk.
CNGsaves
KS and OK
EXTERIOR before Siding - -- yes, it's common practice to seal house better
(I've seen green wide tape used around here.)
INTERIOR (if using OSB vs sheetrock) - - then I'd say caulk as putting up sheets to help make airtight
Justanoldguy
Atiamuri. Central North Island. New Zealand
I just use a plastic jointer for most interior jobs.
38Chevy454
Cincinnati, OH
I used caulk, but not necessarily to hide the seams. To make it airtight. But it did minimize the seams to some extent.
