dittle fart around
Great workbench you should start taking orders.
That is pretty cool as I just came in from working most of the day in the garage and saw that! I appreciate all of your kind words and hope that sharing what I have done helps someone as much as the GJ site has helped me. Hey thanks!!! The degree is a Bachelor of Business from NMSU and has a little to do with my current work. I’m civil service and work for DOD - basically in the QA field. The degree was a goal I set for myself when I retired so will be taking a look at future jobs that the degree can be useful in. I have to say that I used my 9/11 GI bill to pay for school and I’m forever grateful for that.Well, first of all, CONGRATULATIONS on getting your degree!
What was your major, and are you working in your field now, or hope to?
Breezed back through the thread to refresh what's been done; "You've come a long way"!
Being 'Army (ret.)', you're still living their enlistment hype "Be All You Can Be".
Very nice (modified) execution of Steevo's bench design; looks great! With the deeper drawers of those Craftsman boxes, let's see some pics of what lives beneath your tool bench. Speaking of which, what the specs on the top working surface; did you fab it or have it done? I believe I have the exact same Wilton vise; is that the Hammerite blue?
So, now that you've been graduated, are we going to see some major progress to the 'White' Scout?![]()
Thanks!!
Time for an update to the Scout Den! It has been a very busy past month for me as I finally finished my degree and graduate on Saturday so not a whole lot of time spent in the garage. That will change now!!
My family gave me some toolboxes for graduating so I wanted to put them in a frame similar to the ones Steevo designed and made. Here are some in progress shots.
You can see that I pretty much copied Steevo’s design right down to the feet inserts with just a change dimensionally to fit the boxes. I also added metal plate to the outside legs to hide the boxes. We have already put this to use and can say it is by far the best bench I have ever owned - really a great design and so glad Steevo shared it!
Still need to add doors to the toolroom shelves and do a little more trim work to call this area done.
Also added this MasterCool swamp cooler.
Jay
I’m hoping to get to those next week. I found out that the silver material I used on the main garage cabinet doors is no longer available which I wanted to use here also. Hope to find something similar to that.I too would like to see the cabs with the doors on them
Adam
Thanks! We had an old Power Wagon we called the Blue Beast!Great projects! Keep the pictures coming! Love the IH, had a blue 76 Scout all through college!! Was the Blue Beast!
I purchased the swamp cooler at Lowes. You can shop around and get these for a little over $400. It is rated for a 1500 sg ft home and so far has easily cooled our shop on the low fan speed setting.How does that swamp cooler perform? What kind of cost are we looking at?
Thanks! The site is addicting and there are so many great garage builds here! So many great ideas!!Awesome job so far !! I love your attention to detail. It really shows. Im sure the new space and lift will help out dramatically in working on projects. Cant wait to see more. I love this site too. I just wish I had more time to thumb through great threads like this. Keep up the work.
It is a waterless system from Zero Flush So far no odors and the chemicals that came with it do not have a distinct odor. Not flowery or anything to mask an odor. There is a concept movie here: http://www.zeroflush.com/how_it_works.phpDoes that urinal NOT flush? If it doesn't, what keeps the odor down?
Thanks Ed!!I love this shop! you did a great job.
Ed
Thanks! The rolled insulation was a bear to install in places I have to admit. The roof is the hardest just because you are up so high and each run is the full width of the garage. There are many warnings in the instructions not to walk on it!. They supply some double sided tape and it works surprisingly well to hold the insulation in place. Then the installation of the panels squeezes it tight to the beam and holds it in place. I was a little **** about keeping it aligned and making sure the seams where straight so probably added a few hours of extra time to the install!really cool shop man...love the bench, such a cool idea n looks simple to build bar the top....
how odes the insulation of the roof n walls work....it rolls out but must be a pain in the *** trying to pull it over the beams etc....how does it fix to the side walls???
Hey thanks! I love that picture in your signature! Such a cool garage!!!Very nice job on that worktop/cabinet.
Is the top rear rail removable? It looks like it's bolted on. Is it removable to allow easy insertion and removal of the toolboxes?
Yes exactly! I had to do that in order to get the tool boxes in. I also flipped the front top angle and welded those in individually as compared to Steevo’s design. I did this to keep the overhang of the work top at an inch. Shows the versatility of his design as it can be scaled to fit other types of boxes and garages. I had to make mine smaller!Is the top rear rail removable? It looks like it's bolted on. Is it removable to allow easy insertion and removal of the toolboxes?
Thanks!Cool Scout II ---- I used to own a '64 Scout 80
They work very well here but, just like Louisiana, when we do have rain they are not as efficient. We are experiencing that now but no way can I complain about getting some rain!!I'm envious! Those "swamp coolers" don't work in the swamps of Southeast Louisiana where the humidity approaches 100%.
Bob
The top is just mild steel that I got at a local supplier and the feet I got at this site: http://www.jwwinco.com/ The plastic insert is part # 10TPTD and the feet are part # 10T3WP1. By the way, in case you missed it, this is the thread a lot of the ideas for my bench came from: HF Toolboxes Workbench - Phase 3Where did you get the stainless for the top? Also where did you find the feet?
Our latest Scout we picked up - 1980. Will fix up and sell to fund other projects!OT: Is daughter single? I redid a 74 scout II, sold it to help buy a house I am hoping to close on in 3 hrs.
I ask about the daughter because she seems like she would be more reasonable to deal with when I get another scout project to work on than my current warden.
Thanks! We just spent a week recently in Lillian, AL/Pensacola area. Lots of green vegetation!!90+...
Thunderstorms everyday...
Welcome to the Gulf Coast...
(Retired USAF...I hate sleeping on the ground!!!)
Really like your build...
Ya dun gud, Bubba...
Thanks!!it is looking like a well planned structure .. no doubt ..will definitely turn into a productive garage .. cheers
Hey thanks!! We are doing as much prep as we can to save some money for sure plus learn a little along the way!!are you doing any of your own paint or powder coating, or just the prep to save some cash?
Either way, the white looks amazing.
Thanks! Yes the 70's!!Great to be able to put those babies to use with the boat. Looks great! If you had an older boat, and no Town car and Explorer in the back ground you could easily pass it as a retro image.
Thanks Scott! We are lucky to find a few “almost” rust free Scouts here and are always looking!Really enjoying your thread. Your '65 is coming along nicely. I'm really impressed with how clean the '80 Scout is. We don't find them nearly as nice here in the upper mid-west. The rust-monster really took its toll on them.
Scott
Thanks Adam!!BRAVO
very nicely done
Adam
Besides the lift I think the floor coating from Supercoat was a very good investment when you look at the cost. We do not baby it as it is a working garage and there are some scrapes and dings in it from dropping tools or dragging a stuck wheel on a hoist across it. I have even welded on vehicles on the lift! But the thing I like the most is cleanup. Oil and chemicals cleanup easily and where there are dings you can touch those up. Here is a pic from tonight:how is your floor epoxy holding up?
Hey thanks and welcome to GJ!!!Great looking garage. I love the work bench and you have some very nice scout's. I will be following along to see what else you do with your garage.
Thanks! I would like to see that!! They do tend to multiply!!Wow the Scout looks great. There a guy in Portland Oregon that always seems to be closed, his lot is full of International trucks, Travelalls and Scouts
Thanks!Nice!! wish all engine bays had that kind of room to work in..![]()
If you are talking about the heater I got it through Amazon. The Scout is a long story but you can read about that here: http://www.binderplanet.com/forums/showthread.php?t=107381 Thanks!!Very good. Where did you get ?
Thanks! I’m lucky she still enjoys hanging out with me!Outstanding. I like the late model Scout almost as much as your great garage. Great that your daughter is so actively involved in things too!
