@jteck75
thanks for your post! Very helpful.
@Roverbo
I will start looking to ebay for a 1/2 " Snap on wrench with low shipping costs to Greece!
I think always try to find reasons to buy tools.
How much mm a 1/2 Snap on open end measure?
The laws of physics say that if you use a wrench that is softer than the bolt it's turning, eventually the wrench will wear out. I wonder what would happen if the wrench and the bolt were the exact same hardness...
Or ..............,
Monte could send you his whole 13mm wrench collection for you to test. I bet the small dimple wouldn't worry him![]()
A double nut where the arrow point? No space, plus that the thread has aCan you double.nut a couple of standard thin jam nuts under the head and tighten/loosen via those instead of the hardened.head?
Miskin, seeing that you have access to a hardness tester, could you possibly test an assortment of cheapy Chinese wrenches. Just for the hell of it, you know the whole set for a fiver type.
You can compensate for **** steel by tempering it less - i.e. a high hardness.
I find that you get the soft as butter ones or real brittle ones. But the hardness may vary all over the place due to lack of quality control
Or ..............,
BTW, does the thickness of the chrome plating effect the measured hardness?
Me too. I will find out.I'd be interested on how strong the 1b gedore wrenches are
I have some bolts in a similar situation. What happens is the curve of the wrench contacts the wall and added force pushes the wrench out so the contact area on the bolt is less.
Even the tninest wall box end you can find is too thick ? Could a square headed bolt be substituted ?
which 13mm wrench collection ??? you've mixed me up with someone else !Monte could send you his whole 13mm wrench collection for you to test. I bet the small dimple wouldn't worry him![]()
which 13mm wrench collection ??? you've mixed me up with someone else !![]()
Next rebranded Stahlwille from GARANT.
Pic tomorrow. I forget to shoot one, but the conclusion is the same with GEDORE. Worn but not streched, not useless.
Very interesting thread, thanks for posting. My 1/2" Snap On #OEX16B measures 12.89mm. Looking at the wrench that came with the machine it appears not much torque is required. Be nice if you could find a double open end like it with both ends 13mm. I have seen such wrenchs with one end standard 15 degree the other end between 60, and 90 degrees. I measured a few other brands I have and the Snap On is the smallest. The others Blackhawks, BW1162, BW1162H, And an old, and new Craftsman 44695 raised panel all US made, they were all between 12.95 and 13.03mm.
If your wrench is very soft in the inside, no thin hard layer of surface will prevent the wrench from deforming over time.
Think of a nice piece of spanakopita, the shell is hard, but you can still easily flex it because the soft spinach and cheese filling gives way for the shell to break apart.
But if you bake a loaf of bread that is thick, without yeast, the break doesn't want to flex and break inwards.
Dimitri
Ahh that explains why this 'Monte' fella is soo knowedgable on all things German.
I reckon that 'Monte' is more than one person and you are really a sales corporation promoting exports for the German tool industry![]()
here is his site:
http://www.herrapro.es/
These wrenches are used by many workers, who have no 'tool education'.
For example, the GEDORE i work with it the most of the time. It was okey. Then a co-worker destroyed it in one week.![]()
finding a good one and keeping it locked up is the best thing.
Teaching the other workers is OK, but some people never get it.
What surprises me the most are that the bolts are harder than the wrenches. I always thought it was the other way around.![]()
They ´re not common bolts. They ´re holding lathe tools with their 'heads' as you can see in the pics. That's why the head of the bolt is hardened.
I don't see what locks the fastener in place, which may explain the over-tightening.
If you will notice the pictures, there is no way a box end anything is ever going to work.
Have you considered contacting ARP fasteners, here in the USA, with the bolt specs and seeing if they can provide you with a reduced head size 12 point fastener that you could put a 12pt box end wrench on?
http://arp-bolts.com/
Wes
Gedore dealer refuse to replace the damaged No7. I dunno about Facom dealer.@ Miskin
I would try a Facom wrench if I were you, since you are into this kind of testing. They also have lifetime guarantee so you will get another one for free when you damage it![]()
Miskin
how about a shot of the gap between the bolt and the machine part? or a measurement of how much gap there is?
in any case if you cant get these to work, then why not just buy a small pipe wrench for the final torque, if the bolt is indeed harder than the pipe wrench jaws then they will bite and grab and won't mar the bolt either.
