13 mm wrench test
geo9
Greece
Miskin, I understand what you mean, I proposed the particular brand for purely scientific testing reasons :) (and because I am curious too!). In any case, so far I have had nothing but good luck from my Facom dealer.
Miskin
Athens, Greece
A gift from GJ member cosmik binturong. :beer:
Bost 13mm wrench ready for testing! :thumbup:
View media item 31089
View media item 31090
View media item 31091
We use this to measure the chrome thickness coating on spare parts. I think is usefull to know if the wrenches have chrome coating and how much.
View media item 31086
View media item 31087
View media item 31088
For start i measure the chrome coating on Proxxon and Stahlwille
Proxxon: 0.159 mm
Stahlwille: no chrome coating indicated at permascope
That means no chrome chipping for Stahlwille! :lol_hitti
It doesn't mean that Stahlwille have no chrome in its steel. The permascope measure the coating. For example i think with the same tester you can measure the thickness of paint on iron or steel.
Miskin
Athens, Greece
interesting results.... Did you measure other wrenches too ?
Not yet, but i'm about to measure all the wrenches i have, even some i wouldn't put to test, like 600N. I think now i will start to appreciate Stahlwille more than other brands. I very curious about Gedore and Hazet.
ishiboo
Oshkosh, WI
I am the last person here to pitch Snap-on, but I'm going to here. I own a total of one Snap-on tool - a 1/4x5/16 flare nut wrench, which as nice as it was, was cheaper brand new on eBay than the Craftsman.
First, as mentioned... the thin wrenches are not helping to distribute the force.
Second, the hardness is definitely an issue which is why tools which would otherwise hold up fine are getting their asses kicked. I think this may be a legitimate boon for not only the high quality steel Snap-on uses (not that the Euro variants do not) and being thicker, but also the flank drive plus setup which I think will have an advantage in these situations. There are lots of competitors in the US, I am surprised though that not a wrench you picked up has anything other than a "flat" profile to it.
Suggestions about making the bolt weaker are rather frightening. Not only is there the real danger of a piece of tooling coming flying off (bad), but the bigger risk is now instead of rounding off the wrench, you round off the bolt... and it does NOT look like that would leave you many options for easy removal. Worst case scenario now - you have to replace the wrench once and a while. :)
Miskin
Athens, Greece
As i mentioned few post back, is very difficult to find US made tools in Greece. The only US wrench we use is this Williams Vulcan
View media item 25596
About flank drive plus, is something i want to try out in the future. Now i stick to the common wrenches for a full inspection :pimpflash
ishiboo
Oshkosh, WI
Absolutely I understand... I am just suggesting it may be worth the hassle of getting one to try :) If you need it, there are many people here who would buy one (including myself) and ship it to you at cost.
Looks like the wrench is US $32 new... that is why I don't own Snap-on, not because they're not the best, but because I can buy a whole SET of decent wrenches for $32 :p
Miskin
Athens, Greece
$32 (24,20 €) to mess up the wrench is too much. I will buy a Snap-on to measure the hardness and chrome coating, but first i want to search Greek shops to find a forgotten set of Snap-on if i'm lucky. ;)
Monte
Germany
maybe you can get ahold of a Stahlwille "soft grip" wrench..? maybe the jaw design will work better ?
Miskin
Athens, Greece
:dunno:
Who knows? Maybe. Mmmm from the pic looks a bit slippery. I mean less contact surface with the screw's head, less torque. Is this wrench actually works?
ishiboo
Oshkosh, WI
:dunno:
How about a GearWrench surface drive? $4.00 shipped in the US... not sure the most economical way to get it to Greece though.
I'm curious how the surface drive performs, though I don't think the GW steel is anywhere near where Snap-on is.
The purpose of most of these drives is to relocate the stresses from the edges of the fastener to the flat "faces"... so I think the benefit with that hard bolt is that it would move the forces from the sharp ends.
Miskin
Athens, Greece
Ooohh I think i can answer your question... :pimpflash
View media item 27921
View media item 27924
... but it's locked and only my supervisor use it. In the future i will 'scan' some wrenches, but it will take time...
Monte
Germany
...or try a Heyco "Maxline" wrench which is made of higher grade spring steel or a Wera Joker with it´s special jaw design which might work better ? .....the wrench is made out of chrom-molybdenum.
Miskin
Athens, Greece
Unfortunately i sold the Wera Joker set i had :D
Kracin
Omaha, NE
quick, someone send this thread to a snap-on rep and some other high end tool companies and see how many of them will toss a 13mm his way to test out where all others have failed!
Miskin
Athens, Greece
Βe patience, i will find a Snap-on wrench here in Greece or in another part of the Old World with acceptable shipping. In the end I will go to the gate of U.S. base in Crete to ask a wrench from the guard. Even better I can go to the American Embassy located a 10 minute walk from my house and tell them: "Why Snap-On has no representative in Greece? Shame!" :lol_hitti:lol_hitti
bahcoswed
Sweden
I can send you an old bahco pu stockholm and a new bahco belzer 1952m if you want?! Old bahco is very strong, stronger than all you have test in this thread!
ishiboo
Oshkosh, WI
Just keep in mind in most of these brands, there are regular and then the flank drive/surface drive/other random trademark for the special "jaws". I think specifically a wrench designed to grip on the faces of the bolt will be beneficial, but it must also be a good grade steel.
Keep an eye out for the Snap-on flank drive plus... there must be a 13mm left in Greece :)
Miskin
Athens, Greece
Some new interesting data
Brand HRC Chrome coating (mm)
Matador 190--------------------41--------------------0.085
Garant---------------------------41---------------------~0
Stahlwille-----------------------47----------------------~0
Matador 190 old series---------38--------------------0.15
HR (India) Lidl------------------34--------------------0.10
Bost-----------------------------49 :wtf: -----------0.08
Dowidat No6 12-13-------------38--------------------0.10
Gedore No6 14-17--------------52 :D --------------0.10
Unior----------------------------47.5-------------------0.15
IUS------------------------------47 :wtf: --------------0.05
Izeltas---------------------------44----------------------~0
Cobalt Ratcheting Wrench------45----------------------~0 :confused:
Hazet 600N :scared: beam---------35--------------------0.17 :rocketwho
----------------open end-------- 31---------------------~0
View media item 31167
View media item 31166
View media item 31168
View media item 31169
View media item 31170
I didn't expect the measures of 600N. Very soft. I triple check it. The average
was the values i gave (this is true for all values).
Also surprised by Bost. I must notice the chrome peeling in this wrench. And i didn't even use it.
Gedore No 6. :rocker:
From the start of this thread i said that i must work with this wrench. The values points the correctness of that state.
cosmik binturong
.fr
@georgy
No, not yet. Facom.... too shiny to destroyed :lol_hitti
But i would like to measure its hardness, especially compared with an old Facom made in France.
Miskin, got an almost new Facom 440 from same friend for you if you still do want to test it for hardness + some real world hard bolt testin'! :D
Monte, if i remember correctly, you do already have one of those in your collection so you won't mind, eh? :spit:
Miskin
Athens, Greece
Cosmik binturong find out where Monte lives, steal all his 13 mm wrenches and mail them to me!! :D :bowdown::bowdown:
Miskin... did you check the Hazet again? I'm curious why the HRC is low.
Not yet, i plan to check a 600N 14mm and a 450 10x11.
cosmik binturong
.fr
i would never steal Monte's 13mm wrenches: too many of them and i'll break my back doing so! :D
but i'll mail you some nice ones from time to time if you want... :spit:
pssst! Monte, you should do a "my growing collection of 13mm combo wrenches from around the world" thread just so we can see them all!(beware of that guy lurking all day in your alley with an Okuma t-shirt, a big bag and a lust for 13mm wrenches! :D)
Monte
Germany
yup :) thanks for asking :D you`re allowed to send it to Miskin :D ;););)
i live in a castle far away and it´s dangerous to enter it
here i live :
:lol:
lol yeah i´ll watch out :D
good idea.... i will start a new thread but i´ll take some new pics before....stay tuned :)
Gotmayhem
CT
When a SO wrench finally makes it into Miskin's hands the results are going to cause a GJ meltdown regardless of whether it's the best or not.
Seriously, Miskin, if you give up all hope in your pawn shop/second hand search in Greece let us know.
Miskin
Athens, Greece
I check a couple of Hazet again. A 600N 14 and a 450N 10x11. Similar results with 600N 13 i checked a few posts before
Hazet 600N 14--------------36.5 HRC---------------~0 chrome coating on the open end (you can distinguish the sign from hardness meter on the open end)
The chrome coating on the beam is 0,1 mm.
Someone with experience with hardness tests, realize how 'big' is the sign on 14mm. The bigger the sign, the softer steel.
Hazet 450N 10x11----------39,5 HRC---------------0,08 mm chrome coating. The sign from the hardness meter is on the right side (open end 11)
View media item 31283
I didn't expect that. Is there something i don't understand? Why Hazet uses so soft material? I'm not a metallurgist, so my opinion doesn't count.
marcone
Romania
Glad to see IUS scored high in the hardness test! Think I'll give them a try out of national pride :)
