zmotorsports
Re: what did you do in your garage today?
I too like the idea of having external contact/jumper points. I have used external connection points on our 1940 Chev coupe and our sandrail due to the battery being located in a hard to get to area. They work great and by getting that ugly battery out of the way really ad to the aesthetics.
Mike.
Battery box with the external jumper points is brilliant! Maybe I could use that on my shop truck as I'm always rescuing myself and others with it.....
Mike.
? Hold the valve pin open for 10psi only takes what a whole minute or so? I've had to replace the valve once and believe it was due to opening it with more than 40+ psi, didnt know about the 30 psi until I was looking for the part number and came across the 30 or less recommendation>
Installed a pair of fans that I re-purposed to use in my shop. Will post some before and after pics later. They should help keep the shop a little cooler.
