D.TRECE - Garage + House
nolimits76
Oklahoma
Re: D.TRECE - 62x36 - My first garage + house
Interesting. I've never seen structural embeds with the U-shape on them. Here we have studs with thickened heads. See picture below.
In regards to the "chicks"....is the plan to leave the flat plate so you can weld on it as needed or to place the U-shape down so you have built-in "hooks"? Guess I'm just not familiar with those. If the U-shape is exposed, I'd think you need the studs on the flat plat for anchoring into concrete. In my mind I'm thinking miniature embed as illustrated below, except with the U-shape on it. :dunno:
Yes the neighbor is pretty nuts, can't take the legal route because I don't have any evidence of him doing it.
Update:
Picked up some "structural" attach points that are going to be attached to beams.
made them at work for 10% of contractor price :D, also some galvanized "PTR" for pass through beams.
Also made at work for around 50% of contractor price, some "chicks", these will help hang stuff from the ceilings instead of using nails or screws.
L
LCG
GDL :: MX
Salt also chews up the cement itself so that it spalts.
There you go, one more reason to kick him in the balls.
Another interesting build here on GJ, always love checking in on all different builds here.
Keep up the good work.
How is the inspection process in Mexico?
Kinda the same as yours but I think it lacks of a proper electrical inspection.
The U shaped things are anchors for a metal staircase and a steel column but they are welded and tied into the "rebar beams" (for the lack of knowing the correct term).
The "chicks" are tied into the cross sections of the rebar and serve to be a weldable surface on the ceiling. Since the cement blocks used on the slab are hollow they are not very good at "retaining" anchors. Hope it works.
L
LCG
GDL :: MX
Walls for the first floor are going up
engear2005
Awesome man! definitely going to keep up with the progress on this. I am purchasing my land right now and want to build a modern style house on it. They aren't common here.
vectorw8015
USA
That is going to be beautiful. Nice build! More pictures!
tommyrs70
Great design..but will there be enough clearance for the car doors to open up in the driveway? Looks pretty tight!
L
LCG
GDL :: MX
Driveway is 17ft wide, not a lot but enough to open doors
I have been trying sketchup, can't really understand the lightning on the render plugin but here is something I have been working on.
Still a lot to add :lol:
L
LCG
GDL :: MX
Looks great!
Thank you, very much appreciated
Just walls and more walls. I know it looks VERY rough but still a lot of work to do.
Front view:
More front view to show the architectural (useless) wall progress
First floor room view from kitchen crossing the SMALL patio
Entrance from the inside and half bathroom
Living room
Kitech view from the patio
Another
*** for now!
Flatland Dave
SoDak
Great build, Great style. Anticipating the rest of the build.:drool:
Shop101
SoCal
Amazing! I can't wait to see the finished product. Do you know why the houses in Mexico leave the rebar sticking out above the roof? I always thought it was in case they wanted to add on.
OHSCrifle
Atlanta
Don't know if it is true or not.. But I heard rebar out the top means house is not finished.. Thus no property tax. Anyone know if this is the case?
I suspect this one won't have rebar sticking out the top when it's done.
Lookin good!
L
LCG
GDL :: MX
Great build! Thanks for sharing! Love the modern look
Thanks!
That would be the reason I would leave rebar out, but if you see it on a 3 floor house then I guess they wont add any more and they are just lazy or cheap :lol:
Lookin good!
I don't know the process in the US but here, as soon as you "close" the house meaning doors and windows, not even need to finish the inside you can call the inspectors and they will check and measure the property and start taxing you accordingly as a "liveable" place. Then they check you annually by satellite.
Small giggle story on that:
A cousin has a massive garden on his house, he organized a party on it with a couple of giant sunshades. Well that was the day the gov was checking his house on the sat. Story short he had to come and go to the gov office for 7 months trying to explain that they were not an addition and wanted it removed from his tax payment. :lol:
duggie
Sarnia, Ontario, Canada
another awesome modern house build ... I love them !!!
For your CAD - keep using Solidworks for your modelling (as you're very good at it) and go to this site for free CAD models to help you plan your garage space ...
http://grabcad.com/library?utm_campaign=workbench&utm_content=library_button&utm_medium=cta&utm_source=index
You should be able to search and find pretty much all you need. I would start with a model of a car (since you know how big they are) and/or build a 24"x96" "box" to represent a workbench. Doing both of these things will help you visualize the space more while your planning using the 3D model.
Manshoon
I am not an expert on Brick laying but it looks as if these guys are just slopping the mortar on thick. Are they using recycled bricks ?
L
LCG
GDL :: MX
I'm a grabCAD leecher :lol:
That is the normal thickness down here, maybe the camera lens is playing out with proportions. Wide Angle isn't very reliable at dimensioning. Recycled bricks in Mexico would be a first, they are so cheap that a recycled brick would be twice as much if not more :willy_nil
L
LCG
GDL :: MX
Very interesting way of laying bricks, so very different than over here in the Netherlands.
Good progress, I'm very curious on the end result, keep us posted please :thumbup:
How do you lay bricks?
Update:
I always say it. Looks Rough but eventually will look better :lol:
Garage view outside to inside, needs a good cleaning job
This is the Pumping well, already gathering water from all the rain that has been delaying us. Still looking for a reliable 220v solids pump for it.
Garage bathroom ended up too narrow to my liking but nothing I can do at this point.
Garage view from inside to outside
Current house view
bars and more bars
Wood for an internal board concrete wall
Getting there
OHSCrifle
Atlanta
I love seeing how things are done in different parts of the world.
I'm puzzled by the photos. How are the floor slabs constructed, in between reinforced concrete beams? Are those bricks in-filling a grid of concrete joists?
Progress is looking good.
Jack Olsen
Los Angeles
Don't hold back for pictures or work being not garage-related. I think it's safe to say that this kind of outside-the-norm construction is very interesting to a lot of us.
It's going to be a beautiful building!
L
LCG
GDL :: MX
Yes, bricks are hollow for a "lightweight" floor, on top of that goes a thin layer 2" to 3" of lighter concrete.
Thank you!
L
LCG
GDL :: MX
More pictures:
Progress of the architectural wallhole? :dunno: .. This huge wall will be supported by the top beam making a huge deadweight lever to support a lot of the roof slab, pretty cool math calculation on that.
This floor is taking a lot more time than expected, we made a space arrangement change and had to add a more beams to support the new walls, made a mess of the rebar.
Hard to see if you are not looking for it but there is one of the metal column anchors under all the rebar
Board concrete wall from the top
Pic of a "chick" in place
Clear sky after 2 weeks of heavy rain
Random WTF framing picture
Hollow Blocks should be done by now and it should be poured anytime now.
Thanks for watching
Nick DL
Souderton, Pa.
Great build, looking forward to seeing how the rest comes along. Good luck with everything!
Jwestercamp
Just curious but where do u live guessing not us
floridaguy
In the garage
Hola,
Just found the thread. WOW- Nice build:thumbup:. The detail is real nice I like everything. The neighborhood tends be similar modern style houses, is this a requirement to build in this area or just the look of modern GDL. Also it appears that most surrounding houses do not have garages. Keep posting the progress.
Saludos,
L
LCG
GDL :: MX
Thank you
Hecho en Mexico.
(see previous/earlier posts)
-W
cheers
Hola,
Saludos,
Requirement inside the neighborhood by the HOA, still there are some questionable architectural ideas going on.
By rule you must have parking space for 4 cars, as owner you can interpret it any way you like.
And Thanks!
L
LCG
GDL :: MX
Update:
Slab poured and walls are going up
The pool is ready!
The ultra nice looking framing of the second floor
I told the carpenter that I did NOT want any holes on the board concrete and he told me it was very hard to keep the concrete straight without them, we will see how that went.
Quick work on the brick laying
House view:
I'm having a hard time deciding on the floor surface of the garage.
Polished concrete vs Porcelain, cost is around the same depending on the quality of the porcelain but I just can't take a proper decision.
HOWSER
KC
With the design of the home I'd lean towards polished concrete.
ConCretin
Central Maine
Personally, Id opt for porcelain in a garage. Polished concrete could be quite slippery and your relying on a sealer to prevent stains. Might seem strange coming from me, but I'm not a huge fan of decorative concrete. It has it's place but it's too often trying to be something it's not.
The house is looking great. I'm fascinated by the methods. The formwork looks a bit 'rough' compared to what we'd do but it obviously works. There's obviously no lack of skill based on the rebar, which looks to be very well done. Looking forward to seeing this all come together. You're catching up fast.
L
LCG
GDL :: MX
The only thing that worries me about ceramic/porcelain is it cracking or breaking. I would have to buy a small extra batch to keep up with time... too OCD to see a cracked or different color/texture tile.
I would have to be extra careful while doing work on the garage say floor jacks etc..
BeachBoy
according to readers here, it doesn't crack, even when you drop a tool, roll your jack, etc.
Some users have posted reports after a while and abuse... still without cracking one piece
Jack Olsen
Los Angeles
Ceramic vs. 4-lb Sledge Hammer:
Click on the image for the video.
Five years on, I've still never replaced a piece. My lift is covered with the same tiles, and the body of the car simply rests on them.
RogueFab
Oregon
WOW. Awesome to see such a unique build. We use so much wood here in the northwest, becuase we are surrounded by it. I'm guessing it is less expensive to build with concrete and brick there? Every time I visit MX, Gua., Hon., Belize, I see it all done this way.
Nice work. Thanks for all teh pics and thank for having a nice camera :beer:
L
LCG
GDL :: MX
Its because of being third world countries, you know.. With a stick house a robber would just sawzall in hahaha..
I think is just because we are used to it, it would be way hard to find someone that knows how to build a wood house, we don't have the know how and the availability of materials that are used like insulation, "tyvek", heaters and all the related wood house stuff.
This is the last picture I took last week, This will be the rear bedroom outer wall.
they have not removed the framing for the kitchen board concrete but I took a peek view of a corner and I was not happy with it, may end up covering it.
And on other amusing news. My lovely neighbor sued the HOA and the City for my construction license, he says I will have to demolish my house. Go Figure...
OHSCrifle
Atlanta
Is this the guy with the salt? Are you blocking his view or something? What's his problem?
L
LCG
GDL :: MX
Yes same guy, and honestly I don't know what the REAL problem is.
He has made a lot of excuses, only one is real, when I offered to fix it he made an excuse of it.
I guess his REAL problem is just the fact that he lived there 5 years with no houses built around his. Who knows... God bless him.
