What I've been testing (QUICKJACK by Ranger Products)!
ovilla
Plainfield, IL
Introducing the QuickJack by Ranger Products!
I know many of you may have heard rumors that this way coming. Guess what? It’s finally here. For those of you not too familiar with Ranger Products go ahead and check them out and just know that their parent company (BendPak) has been in the lift business for a very long time now (45+ years).
Anyway, let me start by pointing out that my pics will show the lift with an earlier prototype name (just ignore that). Yes, I’ve had this lift in my possession for quite a while now, taking it to autocrosses, car shows, cruise nights, friend’s houses – ALL in the name of research. I was asked if I wanted to be a tester and of course I said “YES!!!”. Anyway, I’m taking the job seriously, doing various tests and offering up what I like and don’t like about the lift, and also collecting as much feedback as I can from others, which has been great. Everyone that sees this lift has been quite excited about it and rightly so. There’s just something so cool about being able to show up at the track (or a friend’s house) with tools AND a lift, especially one that will safely get you up in the air faster than it will take you to drag the jack over to your car.
Okay, let’s get started (in no particular order)!
How “portable” is this lift?
Extremely portable! Each ramp is very light and manageable, weighting only about 45 pounds per ramp and coming with short hydraulic lines with quick disconnects on each end. The weight of the power unit, which comes with a handle, and attached hydraulic lines is another 14 pounds. The ramps lay ridiculously flat (only about 3” tall when fully collapsed) and are only 5’ in total length (when collapsed). In the fully upright position the ramps are 46” long. The overall width of the ramps is 10.5” wide. You shouldn’t have any issue sliding these ramps under the lowest race car, Porsche, Honda, Vette, etc. or lowered hot rod.
Lifting Height/Capacity
Up to 20+” of height and a 3,500 pound lifting capacity. This is mostly dependent on how you use/configure any of the 8 rubber blocks that come with the QuickJack, which also come in two different heights (3” and 1.5”). By the way, you might find that 20+” of height is actually too much – that was some of the feedback that I collected. Luckily, that’s been addressed (see next section below).
Mechanical lock(s)
My prototype unit only has ONE lock but don’t worry, the final version will have two. When the hydraulic cylinder is fully extended, you will be able to position the locking lever into place (and then lower the lift), at which point the top of the ramp will be at its full height extension of roughly 20+”, and will no longer be dependent on hydraulic pressure to keep it in place. Yes, you can also lift your car temporarily to whatever height you might need, but think safety first (and at least slide your wheel under the car). The addition of the 2nd locking point should give you plenty of locking options to work with.
Power Unit
You have two choices! There’s a 110 and a 12V motor available. Both of these units are really small and only take up around two quarts of ATF or hydraulic fluid. Both units come with a 20’ remote cord that gives you plenty of cord to walk around your car and engage/disengage the locks. You’ll find that you petty much walk around holding the remote in your hand all the time (at least that’s why I’ve been doing). Anyway, the 110 motor drew between 9-11 Amps on my amp meter so you can easily run this on a 15amp circuit without blowing a fuse. You can also plug it into a big 1200 watt power inverter or run it off a small portable generator. The 12V unit will obviously run off your car battery and is not much slower than the 110 motor. So how fast does it lift a car? After you position the ramps into place, it will take roughly 10 seconds (with the 12V unit) to get your car fully up in the air. The 110 unit is just slightly faster, shaving just a second or two off that time. I recommend thinking carefully about how you intend to use your QuickJack. If you’re always going to be lifting something that has a good working battery, then 12V is the way to go. Then again, if you’re going to use it primarily in the shop for project cars and already have a decent power inverter or small generator to use as needed, then a 110 would be perfect.
Hydraulic lines
The QuickJack comes with quick disconnects (think MaxJax!) in standard 15’ lengths, which should meet all of your needs. If you need something longer, I’m sure Ranger Products can accommodate your request. Anyway, the lines are really easy to connect/disconnect (no different than hooking up air tools). I actually found that they disconnect even easier than air lines and there’s no spill when you disconnect the lines. Now, when you go to connect them, and happen to pause a bit (or simply have an issue connecting them like one of the gals at the track did), then and only then, will you possibly spill a little fluid. No biggie, just add some more ATF or Hydraulic fluid (or both – depending on what you can source locally at the time).
Remote Control
This is a nice industrial remote that fits comfortably in your hand and comes with a 20’ power cord. There’s plenty of cord to keep the remote in your hand as you walk around to engage/disengage the locking levers. The remote itself just has two buttons - UP and DOWN.
Grey air cylinders/canisters (what are those for???)
Next to each hydraulic cylinder/ram you will see a small air cylinder/canister with a Schrader valve on one end of it. This is why these are needed. The weight of your car will obviously allow the ramps to descend/collapse but what happens when the car is now resting on its wheels and you still need to fully collapse your ramps (a few more inches) so you can slide them out from underneath the car? Well, by initially filling these air cylinders with 50 PSI (Max) of air and then just using your lift going forward, you’ll always have enough air to force the hydraulic cylinder to fully compress itself - without needing the weight of a car now. Don’t worry about having to continually check the air pressure of these cylinders either. As part of the normal operation of the lift, the air cylinder is automatically being filled with air, during each use. I checked mine at the beginning and they’ve been holding air just fine.
How will you know if you’re under the 50 PSI capacity? Don’t worry, your QuickJack will let you know if you’re low on air. Yes, I tested for this scenario too by purposely bleeding my air cylinders all the way down to 5 PSI. Well, here’s what happens. The weight of your car will collapse the ramps down enough until your car is resting on its wheels. Then your ramps will come down a little more (maybe an inch or so but not much more). At this point you have two options, either fill the cylinders right now with 50 PSI (Max) or slide the ramp out from under the car (it will clear) and stand on the ramp so that your weight will now fully compress the ramp. Do one ramp and then the other (or position them side by side and stand on both at the same time – that’s what I did). Either way, just make sure you are also (always) pushing the DOWN button on your remote control so that the hydraulic valve is open and is letting ATF/hydraulic fluid return back to the reservoir tank.
Ramp Set Up (Ramp positioning and Rubber block placement)
Just want to point out a few things here. No, you do not drive your car onto the ramps like you do with other lifts. Remember that this is a portable lift and in order to keep the weight down, it was not designed to be used as a drive on ramp. You instead park your car wherever you want to work on it, and then position the ramps into place. There’s even little “arms” that will help you position the ramps perfectly under your cars pinch welds or under the frame. The supplied rubber blocks (4 of each type) come in 1 ½” and 3” heights and have little grooves to help you line things up and the blocks themselves can be positioned as close as 28 ¾” or as far apart as 43 ¾”.
Ramp Set Up (Planning for hydraulic lines and vehicle movement)
Just think of how you want to route your hydraulic lines. Out the front or back of the car is the easiest set up. Also, you will notice that when the ramps are fully collapsed they are 5’ long but when they are in the upright position they are 44” long. You need to plan for up to roughly 8” of movement of your vehicle (when in the fully upright position), either moving the entire car forward or backwards, based on how you have the ramps oriented.
Just remember this! Your car will always be lifted and moving towards the direction of the BIG WHITE STICKER on the ramps. If you can see/read the sticker, then the car will be lifting up and coming toward you. As the car is lowered, the BIG WHITE STICKER will collapse and fold away from you (along with the car). Make sure you plan for that roughly 8” of movement, especially if your car is close to a wall or garage door. If you find that you screwed up and are hitting the wall/door, just lower the ramps and flip them around and lift the car up again. The ramps are light and rest on round metal/plastic feet and slide really easily, without scratching up the ramps.
O
ovilla
Plainfield, IL
Availability/Price
The QuickJack will be available by the end of this year (maybe sooner), but you can contact Ranger Products and get your name on a list right now. The price will be around $950 (and that includes shipping for those of us that live in the lower 48).
Wait, there’s more!
You like the lift but want something with a higher lifting capacity? A 5,000 pound capacity QuickJack is currently in the works and should be available early next year.
Own a bike? Yes, Ranger Products has you in mind too and already has a motorcycle adapter that turns your QuickJack into a dual purpose lift.
WARNING!!! (VERY Important)!
Before you buy a QuickJack, be prepared (mentally and physically) for mucho visitors at the track, or wherever else you set up your lift. This thing attracts a LOT of attention! YOU will be the talk of the day. Basically, your car is resting comfortably on a spaceship now and everyone wants to come check it out. Seriously, people will literally stop in their tracks when they notice that you are not up on jack stands, or when they see your car magically elevating itself in your “portable” service bay.
Get ready to make new friends – lots of them!
Finally, please let me know of any questions you might have, or any other specs you need.
O
ovilla
Plainfield, IL
Reserved for pics
O
ovilla
Plainfield, IL
Reserved for more pics
O
ovilla
Plainfield, IL
So, your main lift is already in use. What should you do? Just set up your QuickJack!
ScurvyPete
Kentucky
What are your impressions on the remote? It still looks pretty good in the picture, but what do you think of it? Seeing as this is a piece of equipment that you're loading up and moving around a lot, it would seem that a small plastic remote like that would be one of your major "wear and tear" areas
914forme
North of Dayton, Ohio
Nice very nice. I have an Ez car lift, I love that product, yet I can see an need for this one, as I have considered buying another EZ. When you own 914s you seem to put them in the air a lot. In reality it is the fact that you always seem to need a lift when you have something on the lift all ready. So having another might be a great idea.
Falcon67
Merkel, TX
It would take some convincing to spend $950 on a unit that reaches the same height and takes up 10x the floor space as my $170 Craftsman aluminum 2 ton unit with a 4x4 block on the pad and 4 jack stands. Sure, it takes me longer but I still have $700 to spend elsewhere.
JSK
Southern CA
Nice write up. Big thanks.
The video...
<p style="text-align: center;"><span style="font-family: Tahoma;">
<iframe width="400" height="225" frameborder="0" src="//www.youtube.com/embed/WHhCVW2YexQ?feature=player_embedded"></iframe><br />
</span></p>
bry@n
Ocean County, NJ
Is it me or does it look like the frame is being stressed when the car is lifted?
O
ovilla
Plainfield, IL
bry@n - No, that's just a combination of lighting and angles from my camera. Even my rocker panels look crooked in many of my photos and they're not. Anyway, I was very curious about the lift's metal frame bending/deflecting as well, so I've been checking it against a couple of references (a straight steel cutting guide, a long 5' aluminum level, and a big steel carpenters square). I even left my in-laws Chevy Malibu (about 3,400 pounds gross weight) on it all weekend so that I could "stress" it and also validate if the hydraulic pressure would hold (without the locking lever engaged - it did).
Don't let the pics fool you. It looks very simple in design but this is a serious, very stout lift. The very first night I picked it up and showed it to a buddy (who's been a long time builder of frames and roll cages), he even commented on how thick the steel is for this lift - which is 14 gauge.
Dolfan
Greater Atlanta
I have a MaxJax and 4 post, I did some extensive write-ups on both here on GJ. I can't really see this being a tool I would want for a permanent garage tool, I'd step up to something like the MaxJax.
That being said I can see this being a useful tool for racers at the track. Being able to quickly get the car 18-24" off the ground with all the suspension hanging and wheel access that would be cool, if it is light enough and easy to setup.
It will be interesting to see if they start showing up at the track.
240sxguy
Madison, wi
A MaxJax or 4 post lift just plain won't work in my garage. This is an attractive option. My garage floor has a massive slope and I could use this in my driveway. The problem is that my cars are almost all too heavy for this thing.
JSK
Southern CA
The QuickJack was primarily designed for racers who get tired of dancing with floor jacks and jack stands after each race.
A typical support team’s duty for the weekend…
• Get car ready…floor jack, stands, tires off, floor jack, stands, car down…
• Practice…floor jack, stands, tires off, floor jack, stands, car down…
• Qualifying…floor jack, stands, tires off, floor jack, stands, car down…
• Saturday race…floor jack, stands, tires off, floor jack, stands, car down…
• Sunday race…floor jack, stands, tires off, floor jack, stands, car down…
Other added benefits…
• Many times with multiple cars under a canopy, parked side by side, there is simply little or no room to easily navigate a floor jack or long floor jack handle.
• You will have all wheels off before other teams have their cars in the air.
• You will get a lot of attention. Not sure if a good thing, but you will be the talk of the paddock area.
Opening those old spring loaded garage doors by hand didn’t take that much effort or time either. Little things like electric garage door openers and the QuickJack simply turn out to be a very much appreciated convenience.
O
ovilla
Plainfield, IL
ScurvyPete - This remote is quite frankly overkill, especialy when compared to the remote on my overhead hoist at home (or any other remote I've ever seen). It looks like something that the military would have ordered and would have cost $600/ea. It's funny that you mentiion the remote too, because it's the very first thing that I took apart. I (and many others) weren't quite happy with the orientation of the buttons (was bothering me a LOT) so I opened it up and flipped the buttons around (didn't even have to unscrew any wires). I wanted to be able to hold up the remote in my hand, have the cord exit out the bottom and have the UP button at the top, which seems to be much more intuitive and comfortable too. Anyway, that's when I noticed that this remote is made up of a 1/4" thick ABS type hard plastic/ceramic? type of body, which is way thicker than any plastic eletrical junction box I've ever seen. Finally, I've dropped it, pulled/dragged/tossed it, and it's still holding up really well. Also, it stows away quite nicely within the motor housing.
SALIV8
chicago and s/w michigan
this is somewhat similar to pro jacks, except projacks doesnt need 3" of clearance and sits inside the frame... not sure im a fan of this yet..
what the warranty?
does both sides lift the same rate and equal?
Falcon67
Merkel, TX
Just telling you what I think from how I'd use such a device. I drag race and we don't do any of that you listed. I'd be an expensive option to have in the trailer just to lift a tube chassis car and warm up the rear end. Personally, I would need a lift that lets me raise a car sufficiently to drop a transmission - hopefully on a jack - a roll it out from under. I can do that with 3 ton stands and my floor jack but I have to slide the trans off the jack and across the floor. Anything equal or less would not be worth the expense. Half price of Max Jax ought to liift at least half (24") as high.
rubber_ducky
To most people, the idea that you pay per inch of lift is just silly. Portability is worth something. I don't expect that a lightweight floor jack that costs twice as much as a steel jack have double the lift height of the steel jack. But that's just me... and everybody else who has ever purchased an aluminum jack.
rubber_ducky
what the warranty?
I'd never heard of projacks, but after a quick google search, it appears that they're not made to work with factory lift points. The products are definitely catered to different markets.
JSK
Southern CA
Our 5,000 pound capacity unit (BL-5000), expected in February of next year will lift higher - we’re shooting for 6” more. The frames will be slightly heavier (maybe 58-60 pounds each) and slightly longer.
Remember, because of the low frame, many will easily be able to use the larger rubber lift block, perhaps both, which gives added lift height.
Frank N. Stein
Denver, CO
I'm really looking forward to the 5000 lb capacity unit. Would buy right now, if available. Looking forward to more details about it. Only reason I can't go with the current version is two of my three vehicles are over 3500lbs...
volvo
PNW 45th Parallel
If you have a friend of a friend, or take one to the local cruise in. It would be nice to see one under & lifting an older car that had running boards, such as 1920-1945 Fords. Pics would be nice.
O
ovilla
Plainfield, IL
I've got a friend that has a 32 (all fiberglass) Ford with running boards. I'll try to get pics of it this weekend on the QuickJack.
phenryiv1
Martinsburg, WV
I agree, though power requirements may be an issue on busy days. At least for those without generators. I just would not want to run the pump off of the battery and risk a no-start.
felchi80
I think a lot of ppl are waiting for the 5000lbs version, myself included.
all my cars are around 3200-3800 lbs... and it would be nice to be able to lift something heavier like a mini van as well, for typical weekend home mechanics.
Unless you are into race tracks... 3500lbs just wouldn't be enough.
any ideas on how much the 5000lbs would be? I'm hoping no more than 1200 :p
PoorOwner
CA
What is the maximum apart you can place the blocks please?
I measured my cars they are about 60" apart for proper pinch points
Also my car is 3500 already, I go up and bleed the brakes, just exceeded the weight limit and not real comfortable with that
wyb2
Southern NH
To add to that, most people with an attached garage built under the house instead of next to (like mine) have low ceilings. I can't lift a car much more than 24" before I have to worry about the roof hitting the ceiling (and that's for a car, not a truck), so something like the MaxJax that lifts to 45" is a waste of money.
Like others have said, much more interested in the 5000 lb version. The 3500 lb version is really only adequate for someone working only on sports cars.
Frank N. Stein
Denver, CO
Just wondering if JSK has any updates? I know it's only been a little more than a month, but I'm ready to buy the 5000lb version...
Thanks.
felchi80
There hasn't been any reply from the op for a while....
Sent from my Nexus 4 using Tapatalk
TheMeatHead
Interesting product and thanks for sharing. :)
1. Fast lifting speed
2. Allows center access to car for transmission and exhaust work.
Deal-Breaking Dislike:
1. Inability to drive the car over the jack.
-->If I could drive cars over the jack instead of having to slide the ~60lb jacks (5,000lb version) in and out for every car, I would probably buy it if the price wasn't too high.
Although the EZCARLift has better access from all 4 sides underneath the car, I can forgo that advantage if the final version of the TrackJack allows users to drive their vehicles over the jack without damaging it. Extra weight would be fine by me if they can implement this feature.
Will they ever offer an upgrade that allows users to drive their cars onto the lift like the EZCARLift allows its users?
