What kind of safety stress testing is done to this lift before releasing it to market? Are there any standards it has to pass before selling to the public? I'm also interested in the 5,000 pound version.
When I called Bendpak/Ranger last week, the lady didn't have too much information as to when it was going to be released.
So how do you go about pre-ordering these, and approximately how much are the 5000lb lift going for? I know the $3500 is around 1K. I would think there is some additional markup for the $5000 model.
Thanks
I spoke with a retailer (http://www.gesusa.com) and they retail this lift at $995. Aditionally, the DC powered version is avialable but the AC powered unit is either not available or out of stock until March (not sure what he said, connection was bit bad.)
What prices are you finding for the 3500lb lift?
Thanks,
Ray
So it's February, is the BL-5000 around yet?
Cool, thanks...I'm looking forward to it.From an acquaintance at BendPak:
"The 5000 is still essentially in prototype-phase. We are letting the public know it is coming, but it is still being designed."
Ray
I was very disappointed to realize the BL 5000 barely fit only one of my 3 cars.
I have an E46 BMW. One support was hanging off. No other place to mount!!!
My W203 (c230) Mercedes? All plastic panels. No where to lift. Supports too far apart. My Volvo S60? Not even close. Supports 10 inches off.
I'm thinking, "these are not big cars". What is this made for? Called support.
Absolutely no help. Suggested selling to someone local. What a problem solver!!!!! Said they had plans to make a larger one in the future. Don't hold your breath.
Anyway, went to a local welder and had them build me an adapter. Increased size from 50" to 65".
Works flawless. However, for my S60 Volvo, I had to offset adapter so it extended more to the back and flush with the lift in the front.
When I started to lift, the front wheels did not leave the floor. Due to the front wheel drive the car is much heavier in the front.
Cost was $200.00 for adapters. $7.00 for paint.
Very happy camper. In your face tech support!!!!!!
Hello, Not at all. Amazingly strong. The steel doesn't flex at all. It is the same steel tubing diameter as the Quickjack. I put a 3600lb car on it no problem. Plus most of the weight is on the front. There is nothing I would change except for the placement of the 2 front guides that hold it in place. I would move them a few inches forward so as not to interfere with the support arms that swing down. In the up position they are slightly in the way so I have to move the adapter forward about 2 inches.
I then shrink wrapped some flat earth magnets on to the supports to hold them up when lowering.
Hope this helps. Don't hesitate for more questions.
The adapters each weigh 27 lbs. 14 ga sounds about right. I left one of the Quickjacks with him to work with.
Regarding the magnets, I will post a picture. Nothing needed for the adapter or for the welder to be concerned with. Didn't mean to be confusing that they are related or needed.
Just a convenient way to keep the support arms up when lowering.
Wow, that is over priced.
Just to give you an idea on what to look for, here is the guy that made mine.
Looked like he specialized in BBQ grills. They were all over.
http://www.reliableweldingandsteelsupply.com/
I did see other designs that just extended the QuickJack with an add on.
The only downside was that they modified the Quickjack itself voiding any warranty.
I wish I could help with the gauge, however no open ends to measure.
