Well, its been some slow movement, but some movement none-the-less. I've been working on getting my walls upstairs laid out so that I can start putting up the siding. I'm trying not to rush it as its much easier to run wire and such behind the walls with the siding off.
I ran some lights behind the walls to light the storage space, threw in a couple of 18" doors that fit in the stud gaps, framed in my speaker system, and built a little shelf to go in the wall. I'm trying to make as much in-wall storage as possible since that space is more or less wasted in some areas upstairs and will be most useful with a built-in installed.
I also scored some fire extinguisher cabinets from a surplus place near work. They were all new, all stainless, and fire proof/insulated. The place had them for $10 each, so I bought all 5. The words on the front are stickers and can be just shaved off with a razor blade. The one in the photo I plan to have on the front wall and actually use it as a fire extinguisher cabinet. I plan to put the others on the back wall and just use as cabinets.
